Carden and range check
Tower Hobbies
Logged in as Guest
  Printable Version
Great Planes CAP 232 - 27% - RTF
Seller:  nwyninegar
Details:   $1,000.00   |  10/1/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Carden Aircraft >> Carden and range check
Page: [1]
Login
Carden and range check - 12/18/2006 8:43:34 PM
rjklein
Status: offline
I have read several threads about people have dificulty getting thier carden to range check. I had this same problem with one of my cardens, so I started to think of what all cardens have in common that other planes do not. THE SPLIT COWL, check your screws. Depending on the cowl, if the screws are too long they can rub the spark cap or wire and create RF interference.
Rob
       Post #: 1
RE: Carden and range check - 12/20/2006 6:14:08 PM
DMichael
Status: offline
I have had two Cardens- a 35% Cap and a 40% Extra 330. No problems whatsoever.
Being familiar with the Carden construction- balsa, ply and foam with fiberglass cowl/wheepants- I cannot think of any reason why a Carden would exhibit any issues with range. Split cowls, screws, etc. are common to many designs. If your cowl screws are rubbing against your ignition wires it's not because it's a Carden- it's a build issue.
Dave
_____________________________
Team ZDZ
www.rcshowcase.com
(in reply to rjklein)
       Post #: 2
RE: Carden and range check - 12/20/2006 6:49:57 PM
as722
Status: offline
What he said!
Albert
Carden Aircraft
(in reply to DMichael)
       Post #: 3
RE: Carden and range check - 12/29/2006 1:59:55 PM
rjklein
Status: offline
I understand it is a build issue, but it is a build issue that some builders/modelers may not be aware of. As if
(in reply to as722)
       Post #: 4
RE: Carden and range check - 12/29/2006 7:38:51 PM
extratorker
Status: offline
Sorry, nothing to do with it being a Carden. Someone just isn't paying attention to their setup.
       Post #: 5
RE: Carden and range check - 12/29/2006 10:49:36 PM
matus777
Status: offline
That's why C/F screws are best!
       Post #: 6
RE: Carden and range check - 12/29/2006 11:39:21 PM
T. Bob
Status: offline
quote:
screws are too long
Thats a mighty long screw
"This plane has no limits as to performance with this engine except vertical"
(in reply to matus777)
       Post #: 7
RE: Carden and range check - 12/30/2006 12:42:18 AM
exeter_acres
Status: online
Darn... I knew I shouldn't have bought the piece of **** Carden that I ended up with....
sheeesh
I would like to earn your vote for IMAC Southeast Regional Director
(in reply to T. Bob)
       Post #: 8
RE: Carden and range check - 12/30/2006 1:13:49 AM
Flyin Woodbutcher
Status: offline
I'll take that POS off your hands
quote:
ORIGINAL: exeter_acres
sheeesh
(in reply to exeter_acres)
       Post #: 9
RE: Carden and range check - 12/31/2006 4:17:16 AM
OnTheEdge
Status: offline
quote:
ORIGINAL: rjklein
Can you post a link to these threads?
Avoid zen aerobatics...when the ground........and the plane.......become as one.
       Post #: 10
RE: Carden and range check - 12/31/2006 1:02:18 PM
as722
Status: offline
rjklein,
When Dave said it is a build issue he meant who ever built your particular airplane put the cowl screw there, dennis did not do it.
I would spend more time searching for the actual problem and not searching for common things to a carden.
Albert
Carden Aircraft
(in reply to OnTheEdge)
       Post #: 11
RE: Carden and range check - 12/31/2006 1:11:03 PM
Boatnik
Status: offline
I've had engines rubbing cowls, loose cowl screws, pipes banging stuff on my Cardens and no glitches!
Any interfernce I've had on a Carden was ignition related or the long extension wires to the tail.
(in reply to as722)
       Post #: 12
RE: Carden and range check - 12/31/2006 6:15:35 PM
rjklein
Status: offline
Albert,
what is your deal. I never said anything about Dennis or his kits. I have had several, I was letting people know that you can have a problem with the split cowel if your screws are too long. In fact they do not have to be that long if you have slack in the spark wires. This was a FYI, but you my friend are out of line
(in reply to as722)
       Post #: 13
RE: Carden and range check - 12/31/2006 7:36:56 PM
Flyin Woodbutcher
Status: offline
sand box
       Post #: 14
RE: Carden and range check - 12/31/2006 8:17:39 PM
as722
Status: offline
How I'm I out of line? Me as well as everyone else is trying to tell you that it has nothing to do with it being a carden.
Albert
quote:
ORIGINAL: rjklein
Albert,
