csp1971
MO, USA Status: offline
Leave the diff installed on the car to do this. Use silicone. First clean the chassis in front and behind the alloy sleeve (yes, you will probably have to remove the engine or move it out of the way). Smear a light coating of grease around the alloy sleeve, over the ENTIRE sleeve. This will prevent the silicone from sticking to it. Squeeze a bead of silicone between the sleeve and chassis, with care NOT to get it on the diff teeth. Let it dry overnight. Spin the diff and clean the sleeve off with a rag. Pretty simple solution. See pics. There are other ways to do it, but I chose this way.
_____________________________
Proud owner of an HPI Baja, Firehammer MT, Losi Aftershock, Wild Willy 2, Blackfoot, and Hornet.
