badz
UT, USA Status: offline
quote:
ORIGINAL: BuggZy99 if you think it doesnt work well on foam filters your wrong, its works extremely well. it IS sticky and it does stick very well to airfilters, again, probably cause its K&N might be a reason why you would aproove of it, or simply cause you dont use it. Thats used on alot of atv's and offroad vehicules. Buy a small can and see how it is when applied, you will be surpised. quote:
ORIGINAL: badz quote:
ORIGINAL: BuggZy99 i run K&N spray oil on mine, used it on my atv'sin the pass, useing it on my fg's for the past 2 years without any problems. Its red and sticky but washed away real good. I spray some on the inside of the airfilter and on the ends whehe it touches bothe the carb and the end of it. When sprayed well enough it gets all red, when washing it it all comes off clean as a whistle, I hate the other kinds that render the filter so sticky that there a pain to clean after. its : K&N air filter oil part number 99-0516 heres a link to there website with info : http://www.knfilters.com/search/product.aspx?Prod=99-0516 quote:
Quoted from K&N's website. K&N Air Filter Oil is the only oil specially formulated to work in combination with the cotton fabric in K&N Filtercharger® elements providing a superior air filtration system. When used as directed, it quickly penetrates the filter pleats, where it remains suspended in the cotton fabric. K&N filter oil is not made for foam air filters, it's made for cotton ones ie K&N's. That's why it is so easy to clean out of a foam filter cause it doesn't work properly and breaks down easily. I've seen many of $5000+ quad's and dirt bikes have engines destroyed cause of their crap air filters. I also had a f350 suck coal dirt into the engine due to a K&N not being able to filter it properly and cause engine failure. I've used their so called filter oil and have dealt with their support on the issue of my truck engine being ruined cause of their filters inability to work as they claimed it did. They don't impress me at all. They are fine for onroad use only thats about all. The oil clearly states it's for cotton ONLY air filters....so why do you use it on a foam filter when it isn't anywhere near the quality of real foam filter oil.
_____________________________
Club Saito #152 Revver Brotherhood #146
