RE: ASP FS400AR Radial Engine    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Moki 2.10
Seller:  thunderbolt-RCU
Details:   $250.00   |  5/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: ASP FS400AR Radial Engine
Page: <<   < prev  1 2 3 4 5 6 7 8 [9]
Login
RE: ASP FS400AR Radial Engine - 10/3/2012 9:36 AM
Reverend
Score: 100
Last Login: 5/23/2013
Status: offline
quote:
ORIGINAL: Reverend
Four years later I am in the same position as sandman was. He went with a different engine so I will pick up where he
left off and will test the fs400ar in a SiSt FW-190. I obtained a used bird after a landing accident and have fixed the damage. Engine is already in and fits like a glove. Made a motormount which fits the existing holes for the ZG62 motormount.
first tests will be coming weekend with a 22x10 and a 20x8. Really looking forward to it :-D All I need is a new set of pipes but justengines in the uk have them and they are already in the mail.
wish me luck and I will supply tach readings
Rev
quote:
ORIGINAL: Sandman Norway
Hi..
As there was difficult to find info on how well/or bad a Radial engine would work out on a 26-28lb warbird,
I have ordered a ASP -400 65ccm Radial. I guess the only way to find this out, is by trying it out for myself.
As usual on forums like this, there is different opinions. I have been told that this wil work out just fine, and some has said it
is a shure road for disaster... So there is only one way of finding it out, and that is to test it for my self.
I know that this engine is not going to make my FW-190 a speed demon, but that was never my intension. I want something
different from all the other gas engine warbirds. I have a fasination for mechanics (and WWII WB), so I will easy sacrifice
performence for the beuty of mechanical part swinging i harmony :-) Yes, I fly helis too :-)
I`ll do some serious ground testing of this engine. Testing different props and fuel to optimize reliability and performence.
I wil post my results here when I have some data to show.
And if the engine prove to not be unusable in the FW-190, I shure would like to put in the nose of Gee Bee Y :-)
Thaks for listening in..
Beste regards..
Sandman
Right, I hate loose ends so to sum it up:
The FS400 is not powerfull enough for a SiSt FW-190.
I did a lot of tests on the engine and it will fly the plane with marginal power and that is not what I want. The 400 does however fly an aeroworks stearman very well. Have had a lot of fun with that plane!
Rev
_____________________________
If at first you don't succeed, skydiving isn't for you.
Hide Signatures
(in reply to Reverend)
       Post #: 201
RE: ASP FS400AR Radial Engine - 12/24/2012 9:49 PM
DHC6
Score: 100
Last Login: 5/15/2013
Status: offline
I was just about to order one and I just saw your post saying that it's not powerful enough for your FW.  What is the weight of your FW?  I want'ed to put this on a Top Flite Giant Scale P47 ARF.  WIth out the engine the weight is around 24lbs, so I would like to make sure that this engine powerful enough in this aircraft.  Thanks for any feedback, and Merry Christmas.
Hide Signatures
       Post #: 202
RE: ASP FS400AR Radial Engine - 12/25/2012 4:50 AM
Kmot
Score: 168
Status: offline
It will fly it fine.
http://www.youtube.com/watch?v=mk-VR-5fRbI&list=PL1776ECB24B67BD29
~Tom~
Hide Signatures
(in reply to DHC6)
       Post #: 203
RE: ASP FS400AR Radial Engine - 12/25/2012 8:29 AM
vasek
Score: 147
Last Login: 5/22/2013
Status: offline
Nice !
How close was it to have the engine totally enclosed in the cowl ? Looks like just few millimeters... just wondering it the engine was centered a bit lower if it would fit (?) Thanks for info. v.
Remember: Speed is life!
Hide Signatures
(in reply to Kmot)
       Post #: 204
RE: ASP FS400AR Radial Engine - 12/27/2012 8:55 AM
Reverend
Score: 100
Status: offline
quote:
ORIGINAL: DHC6
Hey,
sorry for the late response. Off to the inlaws for a couple of days.
The SiSt Focke Wulf is full composite and will come in at about 15kg. The fs 400 is not strong enough for theat kind of weight. I am currently trying to save al LOT of weight on the bird and I hope to come in at 12kg. If that works out, I will give the 400 a shot.
Rev
Hide Signatures
(in reply to DHC6)
       Post #: 205
RE: ASP FS400AR Radial Engine - 1/22/2013 4:34 AM
retransit
Score: 125
Status: offline
Tom, I finally finished my replacement Concept Fleet. If you remember, I totaled it last April. This one came out a bit heavier than the original. It weighs 25 lbs. 6.5 oz. It's funny what a bit of tweaking on the low speed needle will do for keeping all the cylinders lit-up. It had, at no time, any tendency to drop a cylinder upon throttle advancement. The ASP ran great! Here's a short video of the maiden. My friend did the takeoff and triming and I took over for some circuits and the landing.
Bob
Click to see fullsize image.
Click for fullsize
Fleet Brotherhood #1
Club Saito #800
Hide Signatures
(in reply to Kmot)
       Post #: 206
RE: ASP FS400AR Radial Engine - 1/22/2013 7:58 AM
Reverend
Score: 100
Status: offline
Brilliant plane! the 400 suites it very nicely!
Motivates me to redo my stearman to a more scale charakter...
Hide Signatures
(in reply to retransit)
       Post #: 207
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> RE: ASP FS400AR Radial Engine
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.531RCU1
