Kmot
CA, USA Status: offline
I can't be sure yet. The first time I ran it, I had the HS needle leaned for normal power, but I was running it at only 4000 rpm on a small prop. At that first run, it consumed 15 ml per minute. Which is amazing economy. The second run, I enrichened the HS needle quite a lot so that it would be using excess fuel and hence excess oil. At that point it went to 59 ml per minute. The third run, I leaned the HS needle slightly, and the fuel consumption dropped back to 21 ml per minute. All indications so far are that it will not really be a fuel hog. But we can't be sure until it is actually flying a 20-30 pound aircraft!
_____________________________
Ahhh......screw it!
