greengoose
NM, USA Status: offline
Ok Gentlemen; Just One more time, I totaly understand oil clearance in mechanical things which is if that freeplay so to speak in layman's terms does not exist then there simply is no room for lubrication and therefore you get very high temp friction heat that will really mess up your day in just a few short seconds. I failed to say in my last complaint on page 33 that this clickety clack noise increases in volume every time you go through a tankful of fuel. You see that noise is almost non existent when the engine (Super Tigre) is new in the box, the only way you can hear it is with a stethescope. but again as you go through tankfuls so does the clickety clack and that noise is apparent at 90 degrees BTDC and 90 degrees ATDC. now here is my question Bax-does the ring get hammered into place by the ports as you stated or why is a SuperTigre rod clearance incorrect out of the box when new, Does the crankpin need to wallow out the conrod to get the proper clearance for oil when bench running? I have owned OS, Rossi, GMS, Tower Hobbies, Royal,Magnum,webra, ASP, FOX with super tigre carb. And not one of these engines had the con rod clickety clack like the super Tigre. I ran that poor rossi till it screamed for an overhaul (almost 30 gallons of fuel) and it still didn't have slop in the conrod. and neither did the rest of the listed engines owned by me and I ran the living daylights out of all of them and I won't buy another Super Tigre until the conrods improve in them. Now this is my opinion and I know I'm right, all of you st fans don't let what I think scare you about a SuperTigre engine, keep flying and having fun, I might be expecting something to be too pefect, I don't know, you be the judge.......
< Message edited by greengoose -- 2/16/2008 3:33:21 AM >
