RE: *** CLUB SUPER TIGRE ***
Tower Hobbies
Logged in as Guest
Users viewing this topic: ianwynne, HangarRash
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: *** CLUB SUPER TIGRE ***
Page: <<   < prev  29 30 31 32 33 34 [35] 36 37 38   next >   >>
Login
RE: *** CLUB SUPER TIGRE *** - 3/21/2008 6:07:55 AM
TROY01
Status: offline
I removed the needle and spray bar. I did not flish it with alcohol but I checked that it was all clear and I could blow air through. The fuel is new and I used the same fuel and tank on the test stand with another engine. Could it be both glow plugs are defective? They light up fine.......
(in reply to rcdude7)
       Post #: 851
RE: *** CLUB SUPER TIGRE *** - 3/21/2008 6:27:50 AM
w8ye
Status: offline
What plugs are you running? If they are "cold" plugs you could be seeing your phenomena. Try one in the other engine
_____________________________
I've attended the CutFinger Institute of DirtNap University for years but never did graduate....
Club Saito Member #7
Original AMA #31261
(in reply to TROY01)
       Post #: 852
RE: *** CLUB SUPER TIGRE *** - 3/21/2008 6:52:19 AM
TROY01
Status: offline
I had an old plug in it from years ago (not sure what type) after starting it up and having problems I put a new OS #8 in it and it was worse. A guy at the field gave me a four stroke plug and that was better for a flight, but now it is worse than ever. The other engine I am running is a four stroke also so that may not be the right plug. I thought the OS #8 was a good plug for this engine......
(in reply to w8ye)
       Post #: 853
RE: *** CLUB SUPER TIGRE *** - 3/22/2008 12:14:36 AM
mr.scale
Status: offline
what's the difference beetwen the .61 abc and the ringe besides the $10.00 difference an the slight increse of power? what is the better buy?
Fernando
GRAVITY WORKS IN MYSTERIOUS WAYS, SOME PEOPLE LIKE IT, SOME PEOPLE DONT.
(in reply to XJet)
       Post #: 854
RE: *** CLUB SUPER TIGRE *** - 3/22/2008 12:41:51 AM
N1EDM
Status: offline
This is sort of off the wall, but you said that you fired up the engine after not running it for 15 years. I wonder if you had some 'gunk' inside the engine that is now loosening up and getting on the plug as it makes its way out of the engine.
I wonder if a tank or two run on the ground with a something to keep the plug hot might help out a bit?
Just my $.02
Bob
An expert is someone who has been doing it for 15 minutes longer than you.
(in reply to mr.scale)
       Post #: 855
RE: *** CLUB SUPER TIGRE *** - 3/22/2008 1:49:11 AM
TROY01
Status: offline
I c,eaned the engine well. And now I am trying it on a test stand. I just tried yet another glow plug (Mcoy) and it is the same.
(in reply to N1EDM)
       Post #: 856
RE: *** CLUB SUPER TIGRE *** - 3/22/2008 2:01:01 AM
N1EDM
Status: offline
Let us know how it works, Troy01. I'm curious how this will play out...
Bob
       Post #: 857
RE: *** CLUB SUPER TIGRE *** - 3/22/2008 2:01:54 AM
pc55bomber
Status: offline
If the engine has been sitting for 15 years, the problem may be that all the seals/o rings may be perished and sucking air, check all the carby o'rings or replace them.
Hope this helps.
Cheers
Paul
       Post #: 858
RE: *** CLUB SUPER TIGRE *** - 3/22/2008 2:42:52 AM
TROY01
Status: offline
Running like a champ now. Looks like the new OS #* glow plug was not hot enough and the first plug was not either. I bought a new Mcoy HOT plug and that did it. I mixed them up at first and put the wrong plug back in. Relized my mistake, put the Mcoy in and she is sreaming now!
Thanks guys!
(in reply to pc55bomber)
       Post #: 859
RE: *** CLUB SUPER TIGRE *** - 3/22/2008 5:43:22 AM
HaveBlue
Status: offline
Can any one tell me which way the conrod sits on a GS45, I accidentially dropped the rod and piston out before i had a chance to notice,didn't really expect it fall right out like that..I noticed the rod has a dimple or punch mark on one side, does this mark face the back plate or do you face it towards the front of the engine?
anyone know what these should turn on a 10 x 6, 10, x 7 as a rough estimate
if your still in control....you aint goin fast enough
**Revver Bro 95**
       Post #: 860
RE: *** CLUB SUPER TIGRE *** - 3/23/2008 3:15:33 PM
N1EDM
Status: offline
Hi HaveBlue,
I just took the backplate off my GS045 and I don't see a dimple on the conrod. I presume that it faces foreward. I tried to take a photo but couldn't focus quite tight enough.
I can't recall what RPM's my GS-45 ran with a 10x6 prop, but it was probably somewhere approaching 10K. The GS-45 is not a strong engine. It's good for sport planes though. You might try a 11x5 on it too. An 11x6 might be too much prop for this engine.
Bob
(in reply to HaveBlue)
       Post #: 861
RE: *** CLUB SUPER TIGRE *** - 3/23/2008 9:17:47 PM
blw
Status: offline
Does one end of the rod have a chamfer? That would go against the crankshaft.
The ultimate responsibility of pilots is to fulfill the dreams of the countless millions who can only stare skyward...and wish.
(in reply to N1EDM)
       Post #: 862
RE: *** CLUB SUPER TIGRE *** - 3/23/2008 10:55:39 PM
speedster 1919
Status: offline
That 10x6 is the perfect prop for a ST 45 and you should get about 12-13,000 RPM. The chamfered end of rod goes to the inside of engine so it doesn't rub the radius of crank pin. Ignore the dimple because it may have been taken apart before.
Hey Buddy -That was the most spectacular crash I've ever seen , That rolling cart wheel with parts slinging out was cool...
       Post #: 863
RE: *** CLUB SUPER TIGRE *** - 3/24/2008 1:15:59 PM
HaveBlue
Status: offline
quote:
ORIGINAL: N1EDM
Hi HaveBlue,
Bob
I know what you mean about the performance..I actually like my GS40's much better...this engine will become an experiment, when I get the replacement rod I will run the engine in, and then modify the the liner on the external surface to help air/fuel entry, I will post a thread on the so called porting mods that can be done with some basic tools. It is not really porting as I see it as I am not raising the exhaust port..basically just improving flow of gases into the cylinder..some threads have been posted recently about doing these mods..I am going to put them into real time tests and post the results
As for removing your back plate , thank you for having a look...I am thinking the same because I dont remember seeing the dimple when I first removed mine..I am pretty sure I would have noticed it then
quote:
ORIGINAL: blw
I did look for that, but the rod looks identical from either side apart from the the small dimple/punch mark that's near the big end, there is no apparent chamfer on one side, the bush has a slightly bevelled edge but again identical on both sides, if I had my full internet speed I would post a photo..but my kids have used all my download up and I'm on 56k access till the end of the month...sucks
quote:
ORIGINAL: speedster 1919
That 10x6 is the perfect prop for a ST 45 and you should get about 12-13,000 RPM. .
I get more out my GS40's ..this engine is a bit of a dissapointment as far as ABC design and displacment goes. I owned the GS 40's first, but I guess it's not designed for speed... when I'll put it togeter I'll get my degree wheel on it and check the timing specs, I expect something along the 140 -145 degress
the rod looks identical from either side..no chamfer that is particular to one side, and this engine is a brand new one that had a big end failure due to lack of enough tolerence between piston and bore during the first break in procedure..thats why I am asking about the dimple on the rod..there is no other clue to suggest which way the rod goes...might have been able to see if the engine had more run time on it ..then I could match up the wear pattern on surfaces to determine which way the rod goes
< Message edited by HaveBlue -- 3/24/2008 1:21:47 PM >
**Revver Bro 95**
(in reply to speedster 1919)
       Post #: 864
RE: *** CLUB SUPER TIGRE *** - 3/24/2008 8:43:38 PM
iAlex
Status: offline
Does anybody know what is going on with Tower Hobbies and Super Tiger? I've been looking at buying a GS-40 for the last couple of months now. On Tower Hobbies web site the stock status was given as late Feb, then Late March, and now it's late April. I would really like to give this engine a try but that won't happen if I can't buy it.
