ser00
TX, USA Status: offline
Hi everybody, I hope this is the best place to ask this question. I purchased a g51 ringed engine new in the box several months ago for a P51 mustang that I was building. Since the mustang is almost done, I placed the engine on the test bench to begin breaking it in. To my dismay, I noticed that fuel is coming out from underneath the cylinder head. I carefully removed the head to look for any defects in the copper gasket or machining of the head cover or sleeve top. From what I could see, I saw no defects. I carefully replaced the head cover and restarted the engine. The engine continues to leak. On the advice of a friend, I continued to break in the engine in the hope that everything will seat itself properly(heated metal expands, ect). It seems to me as I leaned out the high speed mixture and the engine got hotter, the leak lessened. After about 45 minutes of break-in time, the engine runs great - great idle, smooth transition to full throttle and no sputtering. I tached the engine between 11500 to 12000 rpm with a MAS 11x6 prop. The engine only seems to leak when it is first started and is cold. After about a minute of running, the leak seems to disappear. Is this normal for this engine? This is the only engine that I have that leaks (also, the only Super Tigre I have). The engine seems to run fine. I still have the receipt for the engine and the hobby shop told me to send it back for repairs. Does anybody think that I should send the engine back in to have it look at? The engine runs great and I would like to keep it since I have already ran 8 tanks of fuel through it. Finally, how many rpms will the engine safely swing a MAS 11x6 prop and a APC 11x6 prop? Thanks in advance. Also, if this post should be in another Happy flying!
