RE: CMP Cessna 182 Building Thread>the best scale Cessna 1.20 size ARF that is on the market!!!    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> RE: CMP Cessna 182 Building Thread>the best scale Cessna 1.20 size ARF that is on the market!!!
Page: <<   < prev  39 40 41 42 43 44 45 46 47 [48]
Login
RE: CMP Cessna 182 Building Thread>the best scale Ce... - 11/14/2012 8:08 PM
Tarolog1974
Score: 100
Last Login: 5/17/2013
Status: offline
If possible, please send me the address chtil@rambler.ru
Hide Signatures
(in reply to Tarolog1974)
       Post #: 1176
RE: CMP Cessna 182 Building Thread>the best scale Ce... - 11/14/2012 11:25 PM
richjanz
Score: 100
Last Login: 11/15/2012
Status: offline
My E-mail address is ....... richjanz@aol.com
Hide Signatures
       Post #: 1177
RE: CMP Cessna 182 Building Thread>the best scale Ce... - 11/15/2012 3:24 AM
GhostWhisperz
Score: 100
Last Login: 2/4/2013
Status: offline
Hi, If you need help in the build, I have a complete guide with included pics, Page 40 Posts 990 - 999. Hope they help, glad people are still using this thread. happy building, if you need any help just ask
Hide Signatures
(in reply to richjanz)
       Post #: 1178
RE: CMP Cessna 182 Building Thread>the best scale Ce... - 11/16/2012 4:02 PM
Tarolog1974
Score: 100
Status: offline
Thank you for your help. I do not know much English, translated by Google. I look forward to your help. Yesterday I put the main landing gear, and tomorrow I want to install the motor. It needs to be moved forward so that it came out of the hood. What can you offer? Wood, dural or iron? Iron will have extra weight. Аs shown here photo from your computer?
P.S.(Translation
turned bad)
Hide Signatures
(in reply to GhostWhisperz)
       Post #: 1179
RE: CMP Cessna 182 Building Thread>the best scale Ce... - 11/17/2012 11:57 AM
GhostWhisperz
Score: 100
Status: offline
@ Tarolog1974.
Your translation is very good, easy to understand, use wood like plywood as this is the best way. iron will be to heavy, if you use iron it will be hard to remove excess weight, using wood you can always add if needed.
Hide Signatures
       Post #: 1180
RE: CMP Cessna 182 Building Thread>the best scale Ce... - 11/20/2012 3:06 AM
bobbydee
Score: 100
Last Login: 4/11/2013
Status: offline
quote:
ORIGINAL: GhostWhisperz
Howdy Ghostwhisperz and friends!
Im greatful for this thread! and plan on following it. Im starting my re-build of a cmp cessna 182/140 size.And I have started the re-build by starting at the begining. the begining of this thread.and already I have gottin very good, plane saving info.Im gonna read it all.
By the way...any windshields, wing struts or light kits layin around? Thanks somuch guys.....bob
Hide Signatures
       Post #: 1181
RE: CMP Cessna 182 Building Thread>the best scale Ce... - 11/27/2012 3:52 AM
bobbydee
Score: 100
Status: offline
Started repairing my cmp cessna 182/140.Ive read all the posts up too page 21 and glad I did.I read were there is a possible update for the rudder and now I see why while fixing the rudder hindges.nothing to glue too.so I am trying to get 3 small piece's of hard wood in place in the rudder instead of one long piece. because of wieght.want to go pull-pull on the rudder with the servo up front and "Y"shaped control rod for elevator.then I gotta go up front and put the firewall back togetherwith fiberglass. loks like the motor got ripped off.Need to build a one inch firewall box to mount my supertigre 3000 too. the motor has a big round backplate too so that will put me out to the end of the cowl with the prop backplate.I wont spare the fiberglass on the firewall repair. I was thinking of lowering the fuel tank because of the inverted motor.the front wheel settup apears stock and its not bent so this plane must have takin a nose dive on the maiden!didnt get a cowl with it.bought a used one and glad to havit!hope the pics load.....bob
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to bobbydee)
       Post #: 1182
RE: CMP Cessna 182 Building Thread>the best scale Ce... - 11/27/2012 8:56 AM
Tarolog1974
Score: 100
Status: offline
Hi guys. Who can find a picture of Cessna 182 with tail number N 1750 P?
Hide Signatures
       Post #: 1183
RE: CMP Cessna 182 Building Thread>the best scale Ce... - 11/27/2012 10:12 PM
SDCrashmaster
Score: 121
Last Login: 5/15/2013
Status: offline
quote:
ORIGINAL: Tarolog1974
Belongs to a 1954 Piper PA-18 in N. Dakota
_____________________________
Yeah, I use mixing... Balsa & Dirt. ©
Hide Signatures
       Post #: 1184
RE: CMP Cessna 182 Building Thread>the best scale Ce... - 1/1/2013 4:32 AM
bobbydee
Score: 100
Status: offline
Howdy boys
Im trying to level the fuse to set up my engine.would appreciate any help on levelin the fuse.best to go off the inside braceing or top of fuse? thanks a bunch....bob
Hide Signatures
(in reply to SDCrashmaster)
       Post #: 1185
RE: CMP Cessna 182 Building Thread>the best scale Ce... - 1/25/2013 10:03 PM
Tarolog1974
Score: 100
Status: offline
Someone tell me what the correct centering of the plane?
Hide Signatures
       Post #: 1186
RE: CMP Cessna 182 Building Thread>the best scale Ce... - 2/3/2013 2:28 PM
phakur
Score: 100
Last Login: 5/19/2013
Status: offline
Okay all-
I have searched through this thread and found several comments on folks intending on using a DLE 20 and several folks commenting that it is probably not enough engine. I happen to have DLE 20 available and it is looking for a homeI really like this plane but don't want it to be a dog (that is what I took the DLE 20 off of).
Has anyone actually put a DLE 20 on the plane and can they comment on how the plane flies, general maneuvering, prop size, etc.
Thanks much!!!
Larry
Hide Signatures
       Post #: 1187
RE: CMP Cessna 182 Building Thread>the best scale Ce... - 2/3/2013 2:56 PM
GhostWhisperz
Score: 100
Status: offline
 Hi there, Many have said thriugh this extensive thread that the power to weight ratio will not be enough, most mut a 26cc in, it will give the extra power to get you out of trouble if youneed it, ie abort landing. I have put a DLE 30 in mine, plenty of power and no extra weight. Please have a look through this if you would like to get a recommended engine size.
Hope this helps
Hide Signatures
(in reply to phakur)
       Post #: 1188
RE: CMP Cessna 182 Building Thread>the best scale Ce... - 2/3/2013 3:14 PM
cannonball200
Score: 105
Last Login: 5/18/2013
Status: offline
I fly a GP Waco 72" ARF with a Dle 20 and it weighs 16#+. Has plenty of power. A Dle 20 would be plenty of power for this 182 and would be very scale like also. No need to fly it like a jet and hover, etc. I just bought one and it will get a Dle 20 for sure. An easy install also. All my flying friends that use the Dle 20 say it has more power than the 26's out there also. I use a 16/8 wood prop on my Waco and a 16/6 wood prop on my 1/4 scale Hanger 9 106" ws J-3 Cub also with the Dle 20 (weighs 14#'s). The J-3 fly's excellent with the Dle 20 also.
Eddie of OKC, OK
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by cannonball200 -- 2/3/2013 3:35 PM >
cannonball200
Waco" Brother #191 @ Cub Brother #122
Hide Signatures
       Post #: 1189
RE: CMP Cessna 182 Building Thread>the best scale Ce... - 2/3/2013 3:31 PM
GhostWhisperz
Score: 100
Status: offline
Thanks for replying to him with actual facts, I was only going by what others have said regarding the engine.
Hide Signatures
(in reply to cannonball200)
       Post #: 1190
RE: CMP Cessna 182 Building Thread>the best scale Ce... - 2/3/2013 10:00 PM
HUNTERANDJEFF
Score: 100
Status: offline
I have a fuji bt 24 in mine and it is a gutless pig! I hate it and wish that I would have put a 30cc in it. In fact, I am going to sell the motor soon it is hardly broke in and runs excellent but it just isn't the motor for me...
http://www.youtube.com/watch?v=VI3lplIVkOM&list=UUFkZ-Nt9DGeJ5HXp1sDFYyg&index=39
Jeff
The only yard sales I go to is when I pick up my plane from all over the runway!!!!
Hide Signatures
       Post #: 1191
RE: CMP Cessna 182 Building Thread>the best scale Ce... - 2/4/2013 3:10 PM
phakur
Score: 100
Status: offline
Just to continue onI am not interested in unlimited vertical or anything close to 3D. Just want to make sure that I can do some loops and rolls, immelmanns, etc type maneauvering with a 20 cc engine.
I was really hoping that there was folks out there who have actually stuck a 20 cc DLE on the plane and can talk about it.
Thanks-
Larry
Hide Signatures
(in reply to HUNTERANDJEFF)
       Post #: 1192
RE: CMP Cessna 182 Building Thread>the best scale Ce... - 2/4/2013 3:30 PM
HUNTERANDJEFF
Score: 100
Status: offline
Ok to continue on,
The dle and others are very light engines (which is great!). My fuji 24cc has a magneto and is heavy (about 4 lbs) and I didn't need weight up front. This plane requires alot of nose weight so with that engine, you may have to add up to 1 1/2 pounds up front to get her to balance. Wouldn't you rather have more engine up there instead of dead weight? You don't have to fly at full throttle all of the time but the power is there if you need it. Just sayin'
< Message edited by HUNTERANDJEFF -- 2/4/2013 8:18 PM >
Jeff
Hide Signatures
       Post #: 1193
RE: CMP Cessna 182 Building Thread>the best scale Ce... - 2/4/2013 4:23 PM
GhostWhisperz
Score: 100
Status: offline
I agree with HUNTERANDJEFF,
 also to quote you
 "I was really hoping that there was folks out there who have actually stuck a 20 cc DLE on the plane and can talk about it"
I believe cannonball200 has already answered your question as he has stated he has put a DLE 20 in his Cessna 182
Hide Signatures
       Post #: 1194
RE: CMP Cessna 182 Building Thread>the best scale Ce... - 2/4/2013 5:25 PM
cannonball200
Score: 105
Status: offline
I have not flown the 182 with the Dle 20 but, I have flown the heck out of my 16 lb GP Waco arf with the Dle 20. Pics are in a few posts above as well as the 14 lb Hanger 9 1/4 scale J-3 Piper Cub. The Waco has plenty of power with the 20 and will do large loops, barrel rolls and climb great. The 182 is not going to be anywhere close to the Waco weight. I fly the Cub and Waco at about 1/2 throttle most of the time also. I'm telling you all that the Dle 20 will be plenty of power to fly the 182 with athority and will fit good in the plane. I use a 2400 nicad 6 volt for radio and a 1500 nicad 4.8 volt for engine and you can shove them as far forward as possible for balance. Just install that Dle 20 on that 182 and go fly it.
Eddie of OKC, OK
cannonball200
Hide Signatures
       Post #: 1195
RE: CMP Cessna 182 Building Thread>the best scale Ce... - 3/25/2013 10:25 AM
asif143
Score: 100
Last Login: 4/9/2013
Status: offline
does any one tell me if i have o.s 46 la  max engine . then what should be the daimention  of cessna 182
Hide Signatures
(in reply to Kmot)
       Post #: 1196
RE: CMP Cessna 182 Building Thread>the best scale Ce... - 4/5/2013 3:31 PM
asif143
Score: 100
Status: offline
 hello sir
can you tell me if i am using os 46la engine in cessna 182. so what should be the diamention of cessna 182 and weight
Hide Signatures
(in reply to nicolau)
       Post #: 1197
RE: CMP Cessna 182 Building Thread>the best scale Ce... - 4/6/2013 5:47 AM
nicolau
Score: 100
Last Login: 4/24/2013
Status: offline
Hi asif.
If that 46 you want to use is a glow engine. I belive will not be powerfull to even get this plane rolling. I have 2 182 and I'm using Saitos4 cycle 150 ,This is what I had availlable for power source and they provide more than enoughf power. This is a very tail heavy plane, move all you can as far fordward as you can, balance carefully, have your front landing gea a litle short of what it says on instructions and give about 4 degrees rake and you will have a very rewarding airplane, with a 10 degree flap for landing she will land beatifully . Does not have any bad traits.. I believe this plane was made for a 140 glow engine.
Good luck
Thanks Jose.
Hide Signatures
(in reply to asif143)
       Post #: 1198
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.625RCU1
