onedarkhalo
Joined: 3/25/2006 From: 29 palms, CA, USA Status: offline
Fluids for shocks and differentials in a buggy, truggy, truck or what ever are silicone based and you by them at any hobby store local or over the net try tower hobbies you can save money though them different makers of the fluids mentioned are rated differently browse through tower hobbies web read what ever you are interested in and you will learn more quickly than i can do I am using mugens diff lubricant and a mix of mugens, TL and AE for shocks they can be mixed for different weights. Try what i used in the shocks maybe 40 wt. front 50wt. rear the diffs were 4000wt. front 5000wt. center 1000 to 2000wt. rear start with that set up leave everything stock except for steering servo replace from the start many to choose from, high torque steel gears,get the feel of the buggy read what you can from these forums ask alot of questions you will probably want to upgrade to a better buggy and keep the raze for back up fun. This should be your first set up it seems to work for the kids and myself you will learn more by replacing parts that are worn or need upgrading when your ready for a different feel or control of the buggy
