RE: Fastest Engine    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Extreme Speed Prop Planes >> RE: Fastest Engine
Page: <<   < prev  2 3 4 5 6 7 8 [9] 10 11   next >   >>
Login
RE: Fastest Engine - 5/19/2008 4:46 PM
bob27s
Score: 105
Last Login: 5/7/2013
Status: offline
(upload the photos here ... my firewall has fits with photobucket )
_____________________________
Bob Brassell
Jett Engineering - Engine Mfg Support Forum Host
Hide Signatures
(in reply to hooty301)
       Post #: 201
RE: Fastest Engine - 5/19/2008 6:14 PM
proptop
Score: 130
Last Login: 5/9/2013
Status: offline
That's awesome man!
It is bad luck to be superstitious...
Steuben Red Barons, Paradise R/C Flyers, RAAM
Hide Signatures
(in reply to bob27s)
       Post #: 202
RE: Fastest Engine - 5/19/2008 11:09 PM
FASTCRASHER
Score: 100
Last Login: 3/10/2013
Status: offline
WOW THATS AWSOME!!
CANT WATE TO SEE VIDEO OF IT ON THE WATER!!! GOOD LUCK!!
FASTCRASHER: REVVER BRO#.221
FLYEM FAST- CRASHEM HARD!!!!
Hide Signatures
(in reply to proptop)
       Post #: 203
RE: Fastest Engine - 5/20/2008 8:48 AM
hooty301
Score: 100
Last Login: 5/14/2013
Status: offline
Thanks fellows
I went back in and reloaded them to this sight, sometimes it gives me trouble so I just use photobucket.
Hide Signatures
(in reply to FASTCRASHER)
       Post #: 204
RE: Fastest Engine - 5/21/2008 6:56 PM
bob27s
Score: 105
Status: offline
Man this has been one fun project !!!
Its a seaplane without the wings
Let me know how the finished fuel system and engine work out.
Bob Brassell
Hide Signatures
       Post #: 205
RE: Fastest Engine - 5/25/2008 6:51 PM
FASTCRASHER
Score: 100
Status: offline
OK HOOTY ITS BN A WHILE WHATS HAPPEND?? HAVE U SAILED HER YET ??
IM IMPATINT I FELL IN LOVE WITH UR BOAT... I USETO MAKE FOAM FLAT BOTTOM AIR BOATS THAT REALLY LOOKED COOL !!
AND THEY R REALLY AWSOME IN THE SNOW (this was way b4 the flying boat came around)[image][/image] SO TELL US WHAT HAPPEND!!
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 206
RE: Fastest Engine - 5/26/2008 6:14 AM
hooty301
Score: 100
Status: offline
Hey thanks fellows!
Fastcrasher thats a nice lookin airboat, how did it run?
I havent put her in the water yet had a little challenge getting the Jett to run right with the tanks mounted so low, got it perty much dialed in now though.
Heres a little dry test run, running rich on the breakin prop.
Test run
http://rcuvideos.com/item/HSQQ074MZN3FZ6MM
Hide Signatures
       Post #: 207
RE: Fastest Engine - 5/26/2008 9:48 AM
vasek
Score: 147
Last Login: 5/23/2013
Status: offline
That thing wants to move! Can't wait to see it on the watter.
Remember: Speed is life!
Hide Signatures
       Post #: 208
RE: Fastest Engine - 5/27/2008 8:27 AM
FASTCRASHER
Score: 100
Status: offline
quote:
ORIGINAL: hooty301
Hey thanks fellows!
well if i recall it was slow on the water it only had a OS.15 on it and it was flat bottom so there was a lot of drag ..... but on the snow and ice wow it was fun!!
that boat of yours is going to haul a$$ bro cant wate to c it on viedo on the step !!
Hide Signatures
       Post #: 209
RE: Fastest Engine - 5/27/2008 8:21 PM
bob27s
Score: 105
Status: offline
Sounds like its running very well ..... !
If you are going to change the prop up from a break-in size, now is the time to do it.
Don't over-tweek the midrange if you intend to upsize the prop a bit. Sound perfect as is. The extra load will be a different rpm transtion.
With an agressive pipe (yours is an agressive higher rpm setup), its hard to get a 100% perfect up-and-down throttle. It will never be smooth and linear. The pipe step is just a throttle position to be avoided. Throttling up onto the pipe is at a different rpm and different fuel draw than when you throttle down off of the pipe into mid/low power.
If you think you have the "up" size dialed in perfect, the engine will go lean and sometimes blow a plug throttling off of the pipe (engine is screaming, it is hot, higher rpm the pipe is demanding of it, and then you quickly throttle down and reduce fuel.... poof!). So take the best compromise. And then work with glowplugs to deal with a slightly rich "up" transition. (the OS type F plugs sometimes help in extreme situation here.... ).
Let me know when the first flight is. (its going to run in ground effect most likely )
Bob
< Message edited by bob27s -- 5/27/2008 8:22 PM >
Bob Brassell
Hide Signatures
       Post #: 210
RE: Fastest Engine - 5/28/2008 9:08 AM
hooty301
Score: 100
Status: offline
Thanks for the advice Bob, Ive always loved to read your post. I will let you guys know when I run it on the water.
< Message edited by hooty301 -- 5/28/2008 9:10 AM >
Hide Signatures
       Post #: 211
RE: Fastest Engine - 5/28/2008 9:15 PM
wahoo
Score: 147
Last Login: 5/24/2013
Status: offline
Hooty are you in Columbiana or Clark county ?
When ever I feel like expressing my own opinion... I just ask an RCU moderator. Better safe than sorry I always say.
Hide Signatures
       Post #: 212
RE: Fastest Engine - 5/30/2008 1:21 AM
hooty301
Score: 100
Status: offline
wahoo wrote:
Columbiana county.
Hide Signatures
(in reply to wahoo)
       Post #: 213
RE: Fastest Engine - 5/30/2008 6:04 AM
wahoo
Score: 147
Status: offline
Great... I'm right across the line in Pa. Used to do some drinking in Mr. D's country Lounge years ago. Met up with a few women from Lisbon.
I'd love to be there when you run it.
John
Hide Signatures
       Post #: 214
RE: Fastest Engine - 5/31/2008 10:46 AM
hooty301
Score: 100
Status: offline
Your more than welcome to come. Ill let you know when get her on the water.
Hide Signatures
(in reply to wahoo)
       Post #: 215
RE: Fastest Engine - 6/8/2008 6:23 PM
FASTCRASHER
Score: 100
Status: offline
ANYTHING NEW TO REPORTE HOOTY?
HOW ABOUT SOME PICS OF IT IN THE WATER,OR VIDEO BRO???
Hide Signatures
       Post #: 216
RE: Fastest Engine - 6/11/2008 10:16 AM
hooty301
Score: 100
Status: offline
Nothing yet, Ill post a vid as soon as I get her on the water.
Hide Signatures
       Post #: 217
RE: Fastest Engine - 6/23/2008 12:20 AM
FASTCRASHER
Score: 100
Status: offline
hooty ur killen me i want to c some pics of that baby in the water!!
Hide Signatures
       Post #: 218
RE: Fastest Engine - 6/23/2008 3:45 AM
Craig-RCU
Score: 100
Last Login: 5/15/2013
Status: offline
I second that emotion. Even if it's only in your bath tub or a puddle in the road or ditch.
Hide Signatures
       Post #: 219
RE: Fastest Engine - 6/24/2008 10:01 AM
hooty301
Score: 100
Status: offline
Shortly, very shortly.
Hide Signatures
(in reply to Craig-RCU)
       Post #: 220
RE: Fastest Engine - 6/27/2008 2:57 PM
FASTCRASHER
Score: 100
Status: offline
hooty!!!....
go sail that boat!!
told u i was impatant!!!
lol
Hide Signatures
       Post #: 221
RE: Fastest Engine - 8/15/2008 1:14 AM
hooty301
Score: 100
Status: offline
Well guys heres a little water vid during some testing. The wind wouldnt let up, making the water a little too choppy for my liking.
http://rcuvideos.com/video/Testing-rigger-90-Jett
Hide Signatures
       Post #: 222
RE: Fastest Engine - 8/15/2008 1:18 AM
vicman
Score: 189
Status: offline
I think you need a bigger pond!
Bigger Badder Meaner Faster!
Revver Brotherhood & NMPRA #41
Hide Signatures
       Post #: 223
RE: Fastest Engine - 8/15/2008 6:52 AM
daven
Score: 100
Last Login: 5/16/2013
Status: offline
Definately, that thing needs to stretch it legs
Always look forward to Hooty posts, as well as Rmenke's.
I think you need a body of water with Salt to get the most out of that motor.
Looks very nice.
Dave Norman
29w
Hide Signatures
(in reply to vicman)
       Post #: 224
RE: Fastest Engine - 8/15/2008 7:50 PM
jettlag
Score: 100
Last Login: 9/1/2010
Status: offline
That was impressive. In the real old days, when we had a bad day at the field, we would say, "I'm going to buy a boat". Now I know what they really meant.
Hide Signatures
       Post #: 225
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.516RCU1
