RE: 40% 260 on a Diet    Gallery
Logged in as Guest
    Search This Thread
Printable Version
S&W 2-6S LCD Battery Capacity & Checker ***FREE SHIPPING US ONLY*****
Seller:  swgiantscalemodels
Details:   $19.89   |  4/2/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Carden Aircraft >> RE: 40% 260 on a Diet
Page: <<   < prev  1 2 3 4 5 [6] 7 8 9 10   next >   >>
Login
RE: 40% 260 on a Diet - 1/10/2007 6:15 AM
260 Man
Score: 100
Last Login: 5/1/2007
Status: offline
quote:
ORIGINAL: as722
Is that bondo you used around the vertical fin fairing ?
Albert
No Albert its not bondo, its like mud that you put on drywall, except it the lite stuff. Home Depot sells it..... I'll look up the name later and let you know.....
(Lite Spackle found at Home Depot)
< Message edited by 260 Man -- 1/11/2007 2:51 PM >
Hide Signatures
(in reply to as722)
       Post #: 126
RE: 40% 260 on a Diet - 1/11/2007 1:21 AM
Matt_McCarty
Score: 100
Last Login: 5/21/2013
Status: offline
This is an awsome build....keep us posted!
Hide Signatures
(in reply to 260 Man)
       Post #: 127
RE: 40% 260 on a Diet - 1/12/2007 4:20 PM
Desertrat
Score: 100
Last Login: 5/1/2013
Status: offline
Hey George, do you have any more pictures of what you guys did to lighten up the wings and stabs? What did you use to pattern out the drill holes on the stabs?
Roger
Hide Signatures
(in reply to Matt_McCarty)
       Post #: 128
RE: 40% 260 on a Diet - 1/13/2007 10:22 AM
260 Man
Score: 100
Status: offline
Roger,
The wings have not been done as of yet. The stabs pattern were drawn (laid up) on the foam and then cut (drilled) out. There was no pre defined pattern...
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Desertrat)
       Post #: 129
RE: 40% 260 on a Diet - 1/13/2007 10:24 AM
260 Man
Score: 100
Status: offline
8 lbs 7 oz as she sits in this photo....
Cowl
Canopy
Landing Gear (Main and Tail)
Click for fullsize
Hide Signatures
       Post #: 130
RE: 40% 260 on a Diet - 1/14/2007 9:55 AM
260 Man
Score: 100
Status: offline
DA 100 installation tonight.......... Notice the weight of the bolts and the 2.5 deg right thrust in the mount...
Needless to say the aluminum bolts were used to mount the engine....
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 131
RE: 40% 260 on a Diet - 1/14/2007 8:22 PM
gbrod
Score: 100
Last Login: 3/9/2013
Status: offline
This is a learning experience for me, great work, keep us informed.
My Carden 260 is at 39.3 lbs and it flyes like a dream with a DA 150.
Happy flying
George
Hide Signatures
       Post #: 132
RE: 40% 260 on a Diet - 1/14/2007 10:43 PM
as722
Score: 100
Status: offline
260 man,
If it doesn't balance and or doesn't have enough power with the 100 will it be strong enough for a 150 ?
Albert
_____________________________
Carden Aircraft
Hide Signatures
(in reply to gbrod)
       Post #: 133
RE: 40% 260 on a Diet - 1/14/2007 11:30 PM
sailing1
Score: 100
Last Login: 5/24/2013
Status: offline
260 Man,
Could you tell me where to pick up the aluminum mounting bolts.
PS really enjoying the build thread.
Hide Signatures
(in reply to as722)
       Post #: 134
RE: 40% 260 on a Diet - 1/15/2007 3:22 AM
260 Man
Score: 100
Status: offline
quote:
ORIGINAL: as722
260 man,
Albert
Yep, but it will fly just fine on the 100..............
Hide Signatures
(in reply to as722)
       Post #: 135
RE: 40% 260 on a Diet - 1/15/2007 3:30 AM
260 Man
Score: 100
Status: offline
quote:
ORIGINAL: sailing1
260 Man,
Aluminum Fasteners supply Inc
239-643-4551
PN 1448HHB205 (2024-T4)
Hide Signatures
(in reply to sailing1)
       Post #: 136
RE: 40% 260 on a Diet - 1/15/2007 3:32 AM
260 Man
Score: 100
Status: offline
On its wheels with motor in and spinner, prop, ignition, throttle servo all installed it sits at 16 lbs 6.4 oz..........Kavan Tires, Titanium Axles
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 137
RE: 40% 260 on a Diet - 1/15/2007 4:03 AM
sensei
Score: 176
Last Login: 5/23/2013
Status: offline
Hello Albert
The C/G as it sits now with power plant, prop and spinner installed is @ 2.5" behind former 2, this means I will probably be placing some of the radio gear behind the C/G to get it balanced.
Fly It Like You Stole It!!!
Hide Signatures
(in reply to as722)
       Post #: 138
RE: 40% 260 on a Diet - 1/15/2007 5:27 AM
Desertrat
Score: 100
Status: offline
quote:
ORIGINAL: 260 Man
Roger,
Thanks George, looking forward to seeing what you guys do with the wings.
Stay warm!
Hide Signatures
       Post #: 139
RE: 40% 260 on a Diet - 1/15/2007 7:12 AM
RC_Pattern_Flyer
Score: 105
Last Login: 4/28/2013
Status: offline
I guess what we did not consider is that fat that you would have to mount the 100 urther forward because of a shorer crank.. therefore, more engine weight further forward to help compensate for the small engine.
Good for you guys...
Talk to you later!!
Chuck
Mark Hunt Designs
Hide Signatures
(in reply to as722)
       Post #: 140
RE: 40% 260 on a Diet - 1/15/2007 1:22 PM
rcplanefan
Score: 100
Last Login: 9/29/2011
Status: offline
George - do you worry about the aluminum mount bolts galling in the steel nuts? I've been thinking of using titanium bolts for this application basically to eliminate the possibility of them galling (and then not being removable!). Obviously, if I could use aluminum, I would from both a cost and weight standpoint. Thoughts?
Thanks!
Ken
Hide Signatures
       Post #: 141
RE: 40% 260 on a Diet - 1/15/2007 9:50 PM
sensei
Score: 176
Status: offline
Aluminum to aluminum usually locks up unless you use anti seize lubricant generally used in full scale applications. Aluminum to steel with silicone won't pose as a problem.
Bob Sawyer
Hide Signatures
(in reply to rcplanefan)
       Post #: 142
RE: 40% 260 on a Diet - 1/16/2007 12:47 AM
as722
Score: 100
Status: offline
2.5" behind F-2 is 1/4" in front of the leading edge of the wing. I'm assuming you meant F-3, if so 2.5" behind F-3 would be 1 7/8" in front of the recomended CG which is way nose heavy. If you are balancing 2.5 behind F-2 you'll probably be placing all of the radio gear and the kitchen sink behind of the recomended CG.
Albert
quote:
ORIGINAL: sensei
Hello Albert
< Message edited by as722 -- 1/16/2007 4:44 AM >
Carden Aircraft
Hide Signatures
(in reply to sensei)
       Post #: 143
RE: 40% 260 on a Diet - 1/16/2007 6:37 AM
sensei
Score: 176
Status: offline
No, like I said, 2.5" behind F2 where the cowling meets the fuse, also with the 4 servos in the tail and the horizontal stab in place, along with batteries behind the canopy this will be a stroll in the park.
Bob Sawyer
Hide Signatures
(in reply to as722)
       Post #: 144
RE: 40% 260 on a Diet - 1/16/2007 7:12 AM
AU cary
Score: 100
Last Login: 2/15/2008
Status: offline
this is awsome, i havent been on RCU in a while and this is the kind of stuff that gets my blood running all over again. awsome job man!
Hide Signatures
       Post #: 145
RE: 40% 260 on a Diet - 1/17/2007 12:06 AM
as722
Score: 100
Status: offline
Yeah, ok !
quote:
ORIGINAL: sensei
Bob Sawyer
Carden Aircraft
Hide Signatures
       Post #: 146
RE: 40% 260 on a Diet - 1/17/2007 6:24 AM
sensei
Score: 176
Status: offline
Albert,
The recommended C/G is 11.3" behind F2 and this thing balances at 2.5" behind F2 equaling 8.8" in front of the C/G as it sits Ok, there is 1 LB 12 ozs. in tail feathers, servos and hardware at 60" behind the C/G; moving the C/G aft about 8.00" Because of the project target weight and power plant choice, the aft portion of the fuse had to be fabricated very light or the recommended C/G would have been unattainable without led in the nose; killing the target weight in the first place. Remember that 60" arm is very sensitive to the C/G.
Bob
Hide Signatures
(in reply to as722)
       Post #: 147
RE: 40% 260 on a Diet - 1/17/2007 6:52 PM
RC_Pattern_Flyer
Score: 105
Status: offline
Just a prediction here, i bet we will find out as progress is made, i just dont understand why people cant help to keep the b.s. comments to themselves about ow it wont work or it gonna blow u or whatever. Let the man build, let the man fly, if it fails, you will have your turn to say i told you so...
BUT... if it flys great, makes weight, balances where it should, i bet no one has the balls to admit they were wrong.
Bob, wish it wasnt so cold, i know the garage has got to be freezing right now, not good to build in
To sunny skies and warmer weather, i anticipate the rest of your build.
Chuckles
Mark Hunt Designs
Hide Signatures
       Post #: 148
RE: 40% 260 on a Diet - 1/17/2007 11:36 PM
as722
Score: 100
Status: offline
So are you saying that you put the whole airplane together, wings, stabs etc. and it balances at 2.5" behind F-2 or are you saying that your fuse balances at 2.5" behind F-2 ?
Albert
quote:
ORIGINAL: sensei
Albert,
Bob
Carden Aircraft
Hide Signatures
       Post #: 149
RE: 40% 260 on a Diet - 1/18/2007 2:37 AM
RC_Pattern_Flyer
Score: 105
Status: offline
oh good grief, will someone send this guy a picture with a big freaking aow as to where it balances and what is attachd to the plane when it blances at this position.
argh.... there are no horzontal stabs in the plane at this point. as he said, look at the picture and you can see what is there. no hrdware or electronic in tail yet. duh.
try www.hookedonphonics.com
Mark Hunt Designs
Hide Signatures
(in reply to as722)
       Post #: 150
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.453RCU1
