A123 pack life in real world uses?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> A123Racing Support >> A123 pack life in real world uses?
Page: [1] 2 3   next >   >>
Login
A123 pack life in real world uses? - 12/24/2006 3:35:17 AM
everydayflyer
Status: offline
I have studied all of the vendors graphs, read hundreds of post in many different forums on several different Users Sites including ,RCU,RC Groups ,Traxxas and a few smaller ones. I have read post by car /truck,aircraft ,fixed and rotory wing and even boat RCers.
I have read post of those charging at 6A,10A and even 25A and discharge rates from about 5C (12 min) runs to 10C ( 6 min). flights .
The one thing that remains a mystery is real cycle life data at rates other than 10C max..
I will start it off with my results to date.
I have a 3S which I have routinely discharged to 8 volts resting ,charged at 6-8.35A mostly at 8A plus. I have pulled 70A peaks from it and most runs have been in my CC Mamba Max 5700 powered Rustler. Most runs last 8 to 9 minutes so 7 to 8C average discharge rate.
I now have 60 cycles on the pack and it has lost next to nothing.
Discharges 20 and 35 were down due to pack being cool.
Second graph shows comparison of 3S A123 and GP3300 6 cell
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by everydayflyer -- 12/24/2006 1:41:55 PM >
       Post #: 1
RE: A123 pack life in real world uses? - 1/2/2007 6:31:27 PM
everydayflyer
Status: offline
Sure good to see a post generate so much interest. I guess I am the only one around here who is putting any serious cycles on these cells.
Well I just completed discharge # 73 in my CC MM Powered Rustler and Dsch. #74 on my CBA so here is an update which shows that these cells do lose capacity if you run them hard / deep enough and charge them hard enough.
Voltage after charging 2,270 mAh on graph are incorrect. Those were the voltage after charging 100 mAh only. At the end of complete charge 3.512 / 3.517 / 3.502
I just hate it when I do that.
Click for fullsize
Click for fullsize
< Message edited by everydayflyer -- 1/8/2007 1:01:05 AM >
(in reply to everydayflyer)
       Post #: 2
RE: A123 pack life in real world uses? - 1/3/2007 12:25:19 AM
SS Pede
Status: offline
So it appears the drop in run time is modest compared to GP3300's, as one might expect for lithium cells. Are you charging any of your packs at the recommended charge rate? Maybe you can't do that perfectly if you don't have the "official" A123 charger. Or do you?
EDIT: Do you have any similar data from other lithium packs like some LiPo's? Charge/discharge rates might be different due to LiPo's lower tolerance for abuse. But a comparison would be interesting.
< Message edited by SS Pede -- 1/3/2007 12:27:30 AM >
       Post #: 3
RE: A123 pack life in real world uses? - 1/3/2007 1:14:39 AM
Marv829
Status: offline
I don't track my cycles. When I ran NiMh I usually replaced them every season or two at the most.
I had a cell getting very weak in one of my 3s packs so I took it apart and charged each cell separately with my Sonic charger. Then I discharged each cell separately at 10A with my ICE charger set to stop a 2v. The weak cell only had a capacity of 760mah. The other two were in the 2100+mah range. When I tore apart the Dewalt pack to build these packs the cell with the red wire on it was at ~1v. I don't know if this was that cell because I did not mark them at the time. So I took apart my three A123Racing 2s packs and tested each cells capacity the same way. I then turned them into 3s packs by matching the capacities as close to each other as possible. I ended up with one 2s pack matched as well. I ran that 2s pack tonight in my Rustler (MM7700, 14/87, 4" tires, 4v LVC). I did not time the run but it seemed longer than my ~6min run times I get with my 3s packs on the same setup. It was ~38° air temp outside (all components were at room temp, ~70°), after the run: Batt-112°, motor-86°, ESC-80°. I put the pack on the charger as soon as I could get it out of the truck. The start amps for the charge were +15A for almost 1min. I've never seen it that high before. It stayed in the 9A-11A area for most of the charge which took only 12min for the "Charged" light to come on at which there was 2155mah in the pack. When my meter showed 0A going to the pack about 2.5min later there was 2202mah in the pack. The pack was at 91° when I took it off the charger. Wow, who thought we would see the day where you could watch an entire charge cycle without toothpicks in your eyelids.
With the MM5700 in my Stampede I average ~9min runs also and much cooler temps all around with my 3s packs vs. 3s in the MM7700 Rustler, which is so darn tooting fast and powerfull on my back street.
Keep posting cycle data Charles. I want to see a 500+ cycles discharge graph.
       Post #: 4
RE: A123 pack life in real world uses? - 1/3/2007 1:27:54 AM
Marv829
Status: offline
I forgot to put in the post that the pack with the weak cell took forever to charge because when the bad cell reached it's 3.6 volt first the charger slows way down to balance mode. It would still balance them though.
(in reply to Marv829)
       Post #: 5
RE: A123 pack life in real world uses? - 1/3/2007 3:32:31 AM
everydayflyer
Status: offline
I have lots of CBA test graphs of LiPolys on RC Groups Batteries and Chargers Forum in the Battery Graph Vault. Many of my Threads have life cycle test. The most cycles I have on a LiPoly is just over 400 but it has not been pushed nearly as hard as these A123 cells have.
Most LiPolys would not last 5 cycles if 30 plus C burst were pulled from them or if they were completely discharged even once. A LiPoly discharged to below 2.5 volts per cell will most often lose 20% or so capacity.
Believe me when I say that I have the proper charging / balancing equipment and know how to use it.
I have an Astro Flight 109 modified for A123 charging , I have a TP-1010C with Rev. 2.0D<Edit now 2.1A as I suggested some changes> firmware for A123 charging, I have four Thunder Power Balancers and a Hyperion Balancer,an Astro Flight Blinky balancer,a VamPower Balancer and several sets of Li-Po Balancers which were the first balancers every marketed.
I have many other chargers as well.
I have a CBA discharge test unit, a BNB Products BPR-100 In flight Data Logger and an Eagle Tree Micro Power in fligh Data Logger and should have yet another new Data Logger to test in another week or so.
I do not do much guessing when it comes to my batteries be they NiCd,NiMH,LiPoly or A123.
I am not easy to impress but these A123 cells are really impressing me.
< Message edited by everydayflyer -- 1/7/2007 12:52:58 AM >
(in reply to SS Pede)
       Post #: 6
RE: A123 pack life in real world uses? - 1/3/2007 6:56:55 AM
Marv829
Status: offline
(O/T)
Charles, do you know how accurate the Eagle Tree brushless rpm sensor is?
< Message edited by Marv829 -- 1/3/2007 6:57:47 AM >
       Post #: 7
RE: A123 pack life in real world uses? - 1/3/2007 4:07:36 PM
everydayflyer
Status: offline
Once correct calibration factor is entered it is extremely accurate. It matches my Digital Optical Tach which reads exactly 3600 on a 60 cycle lite source.
       Post #: 8
RE: A123 pack life in real world uses? - 1/3/2007 9:28:13 PM
jhouvener1
Status: offline
How about the e-moli battery? Has anyone used these as yet? Results?
jhouvener1@tm.net
       Post #: 9
RE: A123 pack life in real world uses? - 1/3/2007 11:21:04 PM
everydayflyer
Status: offline
They are the same voltage as LiPoly 3000 mAh heavier and can only be used at approx. 40A max.
If you are really interested
http://www.rcgroups.com/forums/showthread.php?t=594726
however this really is the A123 Support Forum.
< Message edited by everydayflyer -- 1/3/2007 11:29:07 PM >
(in reply to jhouvener1)
       Post #: 10
RE: A123 pack life in real world uses? - 1/11/2007 8:28:08 PM
everydayflyer
Status: offline
I have a feeling my Rustler will wear out before the battery does. I mean I run this thing flat every run ,charge it at 10A while it is still warm and every recharge is right at 2300 mAh.and 17 min.
Dsch. 1 was 2,190 mAh # 54 was 2,150 # 74 was 2,110 & # 99 was 2,110 mAh.. All of these to a LVC of 7.5V (2.5 per cell).< Edit> CBA Discharge Test to 7.5V pack ran flat in Truck. MambaMax ESC set to LVC None and truck ran till it stops.
Charles
Click for fullsize
< Message edited by everydayflyer -- 1/17/2007 1:31:53 PM >
       Post #: 11
RE: A123 pack life in real world uses? - 1/11/2007 11:17:27 PM
Marv829
Status: offline
Wow your on #99, thanks for the update. I have my LVC set to 6v (3s), would you recommend I increase that to 7.5v? Some of my packs seem to get more unbalanced then I would like and this can really slow down the Sonic charger. Would having the higher LVC help this at all?
-Marv
< Message edited by Marv829 -- 1/11/2007 11:21:02 PM >
       Post #: 12
RE: A123 pack life in real world uses? - 1/12/2007 1:54:39 PM
High Speed Dirt
Status: offline
quote:
ORIGINAL: Marv829
-Marv
Wouldn't one (long) balancing-charge after a day of use solve that problem?
Or does this problem occur after only a few discharges (when you're still flying or at the track)?
       Post #: 13
RE: A123 pack life in real world uses? - 1/12/2007 2:59:08 PM
