brentp76
CA, USA Status: offline
Any idea which canopy is the correct one from Sig.. I am trying to get it ordered.. I have collected all the remaining parts so my build continues.. When I ordered the retracts from Century Jet I noticed that they were around 2 inches to long for the nose wheel, and about 1 1/2 inch for the mains.. I called CJ and they are fixing them for me. Is there a diference in gear length between the different copies of plans? I also picked up the engines. One thing that did kind of dictate the engine choice was the size of the pod. There is really just over 3 inches of depth. This limits the engine choice. At first I was considering an RCV engine, also 91 4 strokes were a consideration, but after I discovered the issue, I decided to go with 2 of the new OS 75 engines. I also picked up the twin sync system, with glow drivers, and LCD readout. I still need to find the spinners, and get a couple more servos.. I am going with HS 225mg on the wing, and probably hs 635, or 645 on the tail. I have decided to go with the Glacier Girl scheme, mainly because of the olive drab scheme is easy to paint, and it is a notable plane.
