V1 RO T8 -> RE: Pitts Pythons in Customs now (4/24/2007 11:01:30 PM)
Thanks! My MVVS has a blown gasket, same as yours. I never fixed it, due to frustration. Plus, the YAK flew terrible with it. DA-50 lightness made it into a "sweet ship". Maybe one of these days, I'll fix it, and see how it runs. Wasn't your Pitts awful nose-heavy with that engine? A few more updates after today's flights: 1. After going over the black covering with a heat gun and rolled up T-shirt, there were no bubbles today, even in the bright sun. The OAT was about 72 degrees. I did lose several clear overlay strips from some of the black stripes. They were trailing behind during flight. Landed and cut them off. 2. Had the canopy crack at several screw holes. Will put washers on each screw, or maybe just glue it on. Now, a few pictures of my new rig. Got a Thule N3205 to haul my two birds in; at only 350# empty, can now drive a smaller car, save gas, and leave the planes in the trailer, ready to go to the field. I made a custom wood mounting system, and mounted it on a 4X8 sheet of plywood. Inside, the trailer is 4" 10"W by 80" long at the floor. But both end walls are relieved outward, adding maybe 6 or 7", so the 30% YAK fits in with a couple of inches to spare. The four hinged "flaps" wedge it in from side to side. I will be constructing a wing rack to fit up inside the cap. Put a $50 toolbox from Lowe's on the tongue. It holds all required equipment. I put 3 vents in each side to evacuate gas fumes while travelling.
