V1 RO T8
Joined: 10/7/2004 From: Copley, OH, USA Status: offline
I crashed mine two days ago, and in similar manner. Was doing touch and goes in mostly calm conditions, with an occasional gust of 10KTS, or so. Approaches were pretty much directly into the wind. Just starting the round-out at about 2 feet, and it suddenly nose dived. Not sure why. I've never had anything like it happen in all my RC expereince. Ripped the right main gear off, and trashed the cowl and one wheel pant. No other damage. Luckily did not bend the muffler, which had buried both pipes in the dirt. Plane flipped on its back, but the tail did not break. I had strengthened it as a result of a previous landing flip damage resulting from catching a wheel in a rabbit hole. After consultation with John at Aerotech-rc, we suspect a too-forward CG. I am using 3" standoffs, and have 4 lithium ion batteries in the motor box. Three landing flips, severe knife edge coupling, and too much forward stick required during inverted--all add up to likely nose-heavy condition. After all repairs done, I'll move the batteries rearward, and really hone in on the correct CG. John says the proper way to balance this plane is to: transfer a line under the top wing center section, at the recommended CG. Hold the completely assembled aircraft under the top wing center section at that line. DO NOT attempt to balance at the wing tips. Can overstress the wings, and accuracy can suffer due to difficulty of transferring CG location out to the wing tips. This is my first Aerotech-rc plane, and I am very pleased with the customer service of the company. John got the parts out to me right away, and was helpful during phone support about the CG issue.
