RE: Pitts Pythons in Customs now
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Aerotech R/C Models Support >> RE: Pitts Pythons in Customs now
Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
Login
RE: Pitts Pythons in Customs now - 2/21/2007 12:48:05 PM
LowKey3D
Status: offline
Very Cool TypeRC. Let us know how the build goes..
(in reply to TypeRC)
       Post #: 76
RE: Pitts Pythons in Customs now - 2/21/2007 12:56:30 PM
Bosshossv8
Status: offline
quote:
ORIGINAL: TypeRC
To rebuttal what I said earlier I wasn't trying to talk bad about the quality of the ARF. I have heard good things about all of Aero-Tech's ARFs that is why I ordered the Pitts. I also understand Aero-Tech has no control of when they receive a product they order or have manufactured. My one and only complaint was the lack of Customer Service we where all continually kept in the dark. I can understand if John is the only one at Aero-Tech it might be hard but you'd think the website would remain up to date or e-mails answered or updates about issues/current status of things on RCU or FG...
Now the good news Order #1257 arrived via UPS today. Box was a little beat up due to the Monkeys at UPS but John has gone out of his way to try and protect the box with plywood. Thank you John!!! The quality of the ARF looks great! I can't wait to get started just need to make some room.
I'm planing to use:
DA-50R
Inverted Pitts Muffler
Slimline Showtime smoke pump
23x8 Mejzlik prop
Tru-Turn Ultimate Spinner Gold Anyodized 3-1/4"
Smart-Fly Power Expander Pro
Smart-Fly TurboReg
Smart-Fly Ignition Regulator
Fromeco Peerless 2400maH 2-Cell Li-Ion (x3)
I'm defiantly going to use carbon wing tubs to help save some weight and do anything else I can to help save some weight.
Mine went out for delivery on the truck at 4:01am this morning. My wife will be accepting it here , as I am out ot the office this morn. She will photograph the condition as it comes off the truck.....I am worried after seeing the pictures posted here.
Weight , weight ,weight,.
get rid of the pitts...gain power lose weight..5-6ozs of it. Stocker is better, so what if you gotta cut a hole in the cowl.
Wood prop...lighter.
CF spinner lighter.
Li-po 2100 2cells rx Li-p0o 1320 ign....much lighter...your Fromecos will be 9.9oz alone.
You save 5 or more oz on the Li-po.
That and the CF tubes and light wheels KAvan Chrome not grey. you have lost a pound or more.
Make that Showtime removable...it has the hardware for it. 12oz removeable.
Mine will be at or under 17lbs. It can be done.
I know having the smoke come out the little cowl hole that the pitts sticks out is cool, but 5oz is 5oz. And the Stocker is better power.
The Li-pos are great...I make little foam carriers for them and strain relief the cords and use deans plugs.
I wish I didn;t play hooky yesterday.....so I could wait for mine.....
_____________________________
"Are you brave enough to milk a Yak?"
       Post #: 77
RE: Pitts Pythons in Customs now - 2/21/2007 1:23:57 PM
LowKey3D
Status: offline
Guys.. This is a 50cc bipe with two wings. They are going to be heavier than a 50cc monoplane but, they make up for that in wing area. I would not
be to concerned with weight unless you want a 3D monster..
< Message edited by los08 -- 2/21/2007 1:24:44 PM >
(in reply to Bosshossv8)
       Post #: 78
RE: Pitts Pythons in Customs now - 2/21/2007 4:41:47 PM
edgeman55-RCU
Status: offline
quote:
ORIGINAL: los08
I agree some are going to go way overboard to get weight out of this bird.It has plenty of wing area for 18lbs.There is a flight report on **** site and at 18lbs 2 ozs it flew great.They said the DA50 had plenty of power at that weight to 3D well.Also they were flying it in a 22 knot wind!
(in reply to LowKey3D)
       Post #: 79
RE: Pitts Pythons in Customs now - 2/21/2007 9:11:24 PM
LowKey3D
Status: offline
I take that report with some optimism unless I see video. I don't think the DA-50 on a pitts muffler has
the greatest pull out from hover with a 18lb plane. If will fly it with authority with plenty of vertical. But
from a vertical standstill to rocketing skyward, which is what you need to get out of 3D trouble, I have
to see it..
(in reply to edgeman55-RCU)
       Post #: 80
RE: Pitts Pythons in Customs now - 2/21/2007 10:09:34 PM
bonedaddy41
Status: offline
I, myself, am still learning (or trying) 3D ... so all of my 3D attempts are pretty high up What do you consider enough power/thrust to be a true 3D plane? 2:1 thrust to weight ratio? 3:1? I think it would be hard for any 50-60cc engine to produce 36+ lbs of thrust. I haven't checked my Evolution 58GX .. .but I can't imagine it putting out that much. I know I have heard rumors of the 58GX putting out 45+ ... but I would have to assume that was on a pipe. I have always considered a plane to have unlimited vertical if I could fly it straight and level at 1/4 throttle ... pull it vertical and go to full throttle .. and it take it out of sight if I allowed. As far as pulling out of a hover ... or rocketing out of a hover .. .I guess I have to learn to hover first
< Message edited by bonedaddy41 -- 2/21/2007 10:11:03 PM >
Don't knock on Death's door. Instead, ring the bell and run. He hates that.
       Post #: 81
RE: Pitts Pythons in Customs now - 2/21/2007 10:35:37 PM
Aerotech
Status: offline
Hello,
Also remember Mike Elder is a top freestyle flyer. If he didnt think it would to what was in his report then he wouldnt post it I can assure you. The plane will do what you want. If you have it set it up and go fly.
John
(in reply to bonedaddy41)
       Post #: 82
RE: Pitts Pythons in Customs now - 2/21/2007 11:40:30 PM
Bosshossv8
Status: offline
Mine arrived this afternoon, I will be unboxxing it after dinner, very little box damage..1 tear on outer..but looks like it didn;t go through the second...
Thanks John.
I won;t even consider a Pitts on a DA-50. Unless I felt the model didn't need full performance. ....when that would be...I don' know.
(in reply to Aerotech)
       Post #: 83
RE: Pitts Pythons in Customs now - 2/22/2007 2:33:53 AM
edgeman55-RCU
Status: offline
3 to 1 power!! Wow you guys do want rocketships.There is a lot more to 3D then the Hover.For what I want to do I believe the DA50 will do fine.I will be using the stock DA muffler and hope to get started on it this weekend.I will report back how it does up here at 5000 ft elevation.Good luck with all your builds.
       Post #: 84
RE: Pitts Pythons in Customs now - 2/22/2007 2:44:58 AM
bonedaddy41
Status: offline
quote:
ORIGINAL: edgeman55-RCU
That is why I was asking. As I said, I am not a big 3D flyer ... cause I'm not that good Hey, I'm happy with a good knife edge, hammer head, snap roll, blender and flat spin. The closest I come to a hover is setting up for a tail slide. But I was curious what people considered a minimum requirement for thrust to weight ratio for 3D. I would think that it would be good to get a 18-20 pound plane to pull out of a hover with a 50-60cc engine. But apparently some want it to "rocket" out of a hover.
< Message edited by bonedaddy41 -- 2/22/2007 2:46:32 AM >
       Post #: 85
RE: Pitts Pythons in Customs now - 2/22/2007 3:06:16 AM
LowKey3D
Status: offline
It's a preference, I say anything more than 1:1 where it can hold a hover and can rise
vertically with some authority.. Not necessarily a rocket.. You want to have confidence
in the plane pulling out of a stalled attitude without relying on gravity to get her flying.
Before I pay 700.00 to 800.00 on a engine setup I want to make sure it is the right one
to put in this plane so for now I'm on the fence with no rush.. In the end it may be another
DA-50. Lets see some build's and video's
       Post #: 86
RE: Pitts Pythons in Customs now - 2/22/2007 3:24:31 AM
Bosshossv8
Status: offline
Edgeman we gotta compare numbers and props. Same setup. I was thinking of making an extension for the output of the stock muffler to reroute it out the hole on bottom.....
It looks like there is enough room to do it.
John, thanks man. This is one hell of an airplane.
I have a question, hole for the DA carb throat? Yes, no? Can the firewall handle it? Maybe an extra piece of that good plywood you re-inforced the box with to beef it, if you cut the hole??
I am going 1 inch away , but I think that hole makes a difference.
This thing is just too freaking cool...
       Post #: 87
RE: Pitts Pythons in Customs now - 2/22/2007 3:42:38 AM
bonedaddy41
Status: offline
quote:
ORIGINAL: los08
Ah. Ok. I feel better Since my Evolution 58GX is currently in a plane that weighs 18.5 pounds ... I can tell you it will pull out of an aborted tail slide with authority I'll have to wait to get better at hovering to answer that one
I do have a Christen Eagle electric foamie that comes with a geared 370 ... that I replaced with a brushless 450 outrunner ... and I KNOW that has about a 3:1 t/w ratio. As a matter of fact .. it is hard to NOT do a torque roll
Back to the Python .... if everything goes good, I am hoping to start stripping the Oracle Challenger this weekend and putting stuff in the Python early next week
< Message edited by bonedaddy41 -- 2/22/2007 3:48:00 AM >
       Post #: 88
RE: Pitts Pythons in Customs now - 2/22/2007 6:41:38 AM
