RE: Pitts Pythons in Customs now
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - 3D & Aerobatic >> Aerotech R/C Models Support >> RE: Pitts Pythons in Customs now
Page: <<   < prev  3 4 [5] 6 7 8 9 10 11 12   next >   >>
Login
RE: Pitts Pythons in Customs now - 3/1/2007 3:20:22 PM
bonedaddy41
Status: offline
quote:
ORIGINAL: bipeaddict
The Monokote tape is a good idea but I am not much into jury rigging my CF tubes. There are some metric size tubes offered by PBG composites.
http://www.pbgcomposites.com/
They have a 24 mm and 25 mm tube size. I just need an accurate outside dimension on the current tube.
I guess I am going to have to get a new steel rule. My initial measurement was off by .025"
My dial calipers show it to be 0.90" ... or 22.86mm
So where does that leave us? We can add 0.025" of trim tape to the 7/8" tubes from TBM .... or run the stock aluminum tubes ... or ???
How about an opinion from your structural engineers? Can we drill the aluminum tube enough to lighten it significantly? I know we would need to stay away from the load bearing areas ... but would that give us enough savings to be worthwhile?
Click to see fullsize image.
Click for fullsize
< Message edited by bonedaddy41 -- 3/1/2007 3:30:20 PM >
_____________________________
Don't knock on Death's door. Instead, ring the bell and run. He hates that.
(in reply to bipeaddict)
       Post #: 101
RE: Pitts Pythons in Customs now - 3/1/2007 9:08:25 PM
Bosshossv8
Status: offline
I have a 25mm tube and it is too big...let me go get the digital caliper....be right back.
"Are you brave enough to milk a Yak?"
       Post #: 102
RE: Pitts Pythons in Customs now - 3/1/2007 9:13:09 PM
Bosshossv8
Status: offline
tube diameter.
Very strange.
22.89 mm
.904 in
Yikes. Where the heck do they get this stuff??
(in reply to Bosshossv8)
       Post #: 103
RE: Pitts Pythons in Customs now - 3/1/2007 9:16:20 PM
Bosshossv8
Status: offline
Sorry, didnt see the other post.
No way would I drill the tube. I have no problem tape shimming if that is all we can get. I have done it before on other birds.....You just watch for wear on the tube and check it's fit everytime you assemble.
As long as the tube has no wiggle room , it will be cool. If it moves back and forth or rattles a bit...then the tape will wear faster.
       Post #: 104
RE: Pitts Pythons in Customs now - 3/1/2007 10:20:31 PM
V1 RO T8
Status: offline
No way would I drill the aluminum tubes! Imagine doing a blender with drilled-out tubes...
I'm going to go with the Monokote shim idea; like you say, check it at each field set up and monitor for excessive play, and should work fine.
V1
       Post #: 105
RE: Pitts Pythons in Customs now - 3/2/2007 1:36:38 AM
bipeaddict
Status: offline
Bosshossv8,
It sounds like the tube might be a 23mm tube. That indeed would be an unusual size. I have searched the web and can't find a tube in that dimension. I was kind of hoping your caliper was off and it was a 24mm tube.
(in reply to V1 RO T8)
       Post #: 106
RE: Pitts Pythons in Customs now - 3/2/2007 1:49:40 AM
Bosshossv8
Status: offline
Bosshossv8,
LOL. Sorry, I do not know what crazy dimension it is SUPPOSED to be, but it is odd for sure.
I had to hang my Python unfinished a few hours ago, I am doing an engine review, and had to get the test plane on the war table.
But, my Python has a lot done to it, the hard stuff, at least. I have not tried to put the cabanes on her, so she is tied up pretty close to the ceiling ...
I will have her done by Mid March.
       Post #: 107
RE: Pitts Pythons in Customs now - 3/3/2007 3:57:10 PM
Doc. insane
Status: offline
Are the planes still being send out? Still waiting for mine
Maarten De Moor aka Doc. insane
-> http://www.docinsane.com <-
       Post #: 108
RE: Pitts Pythons in Customs now - 3/4/2007 7:34:08 PM
Aerotech
Status: offline
Hello,
A quick note. We noticed after 25 flights, the hatch tabs needed some CA. Please run a dab of glue on each to prevent this.
Aerotech Support
(in reply to Doc. insane)
       Post #: 109
RE: Pitts Pythons in Customs now - 3/4/2007 8:08:42 PM
Bosshossv8
Status: offline
THanks for the heads up , John. A little epoxy and microballoons can reinforce them from the start.
On other Bipes I have had, the little strut connector tabs usuually crack at the bend....John, can you inspect those closely for us?? Sometimes the chroming process hardens them, then they become brittle.
(in reply to Aerotech)
       Post #: 110
RE: Pitts Pythons in Customs now - 3/4/2007 8:29:49 PM
Aerotech
Status: offline
Hello,
So far those look fine. We will update anything if it arises.
Aerotech Support
       Post #: 111
RE: Pitts Pythons in Customs now - 3/5/2007 7:56:28 AM
pinto
Status: offline
How did you mount the servos in the top wing?, do the arms point outward or inward?, because the hard points for the servo horns are on the outside on my airplane and that interferes with the cabane mounts (the aluminun mounts for the wires). can you post pics? Thank you.
       Post #: 112
RE: Pitts Pythons in Customs now - 3/5/2007 6:49:23 PM
Aerotech
Status: offline
Hello,
Heres the one inhouse for your review.
Aerotech Support
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 113
RE: Pitts Pythons in Customs now - 3/6/2007 12:26:50 AM
sukhoi-26
Status: offline
One thing you should know the arms on the top wing are 1 inch and the bottoms are 1.25. The reason is the top ailerons are bigger and don't need as much arm to keep up with the bottom. I found that out by accident. Long story short, if you have any questions on the radio install or the set up don't hesitate to ask. John and i are still trying to put a video together but the weather hasn't be that great the last couple of weekends. We'll see about this weekend. Rob
       Post #: 114
RE: Pitts Pythons in Customs now - 3/6/2007 3:24:39 AM
daren
Status: offline
do you need flying wires on the wing?
(in reply to sukhoi-26)
       Post #: 115
RE: Pitts Pythons in Customs now - 3/6/2007 3:44:32 AM
sukhoi-26
Status: offline
Hello,
We have five flights on my python so far John has flown it once and myself. Mike Elder flew it the rest of the flights and he put it threw some pretty intence flying. I
