Which Jett Engine to use?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> Jett Engineering Support >> Which Jett Engine to use?
Page: [1]
Login
Which Jett Engine to use? - 1/29/2003 5:53:50 AM
Red Baron Mike
Status: offline
I am currently setting up a World 57" Mustang for use in SWRA
racing. I am trying to decide which engine to use. Most competitors are using a Y.S. 91 or 1.20 in this plane, turning an APC 12 x 12 (11,000 RPM) or 14 x 14 (10,000 RPM) with 40-50%
nitro.
A friend is running a Rossi .61 with mini pipe and large carb., turning an APC 10 x 9 at over 15,000 RPM. His plane seems to be the fastest in the group. What engine in your line can compete with the Rossi (SAME PROP BUT HIGHER RPM). I am limited to a maximum .70 size engine due to size of plane per SWRA rules (they allow up to a .70 two-stroke or 1.40 four-stroke for this size plane).
_____________________________
Red Baron Mike
       Post #: 1
Which Jett Engine to use? - 1/29/2003 8:08:01 AM
bob27s
Status: offline
Hi,
Thank you for writing....
If you are limited to a .70 or less, you may be interested in the Sport Jett .65. This is pretty much the same as the .76 and 90L, just a few less RPMs. The only problem is, the engine was not a big seller, and has pretty much been discontinued... but, I think you can likely get one.
The .65 with the provided Jett-Stream muffler will outperform the Rossi. Usually this engine will turn a 12x6 APC up around 14K rpm. It is a high timed engine designed to turn up RPM. It should turn a 10x9 about 15,000 on the ground, and will unload big time in the air.
Nice feature, is that the engine and muffler weigh about 25 oz total.
I would suggest that you drop an email directly to Dub at [email]jett@pdq.net[/email] and ask him if he still can provide you with a .65 engine. He may also be able to give you some prop-rpm info for the smaller diameters.
too bad you can't go with a 90 2 stroke The SJ-90L and BSE 90L are real animals!
I hope this is helpful
Bob Brassell
(in reply to Red Baron Mike)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.281RCU1
