RE: Nitro Engine Troubleshooting and Tuning    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> RE: Nitro Engine Troubleshooting and Tuning
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: Nitro Engine Troubleshooting and Tuning - 2/29/2008 10:24 AM
garyedwards
Score: 100
Last Login: 11/10/2012
Status: offline
one question should u start the car with the wheels on the groung or off.
Hide Signatures
(in reply to codokas)
       Post #: 26
RE: Nitro Engine Troubleshooting and Tuning - 2/29/2008 10:35 AM
webbl19
Score: 100
Last Login: 9/4/2009
Status: offline
if you are new do it off the ground until you get a feel for how it starts if you are using your throttle trim and stuff sometimes they like to start up and take off if it is on the ground.
_____________________________
Exceed Razor, RedCat Tsumani and wanna be Volcano
Hide Signatures
(in reply to garyedwards)
       Post #: 27
RE: Nitro Engine Troubleshooting - 4/4/2008 4:12 AM
radford512
Score: 100
Last Login: 4/5/2008
Status: offline
hi i have a shockwave and it is all wheel drive and the front wheels only spin and the rear does not can you help?
Hide Signatures
(in reply to Chubbysdad)
       Post #: 28
RE: Nitro Engine Troubleshooting and Tuning - 4/4/2008 4:59 AM
pede_187
Score: 100
Last Login: 8/10/2012
Status: offline
Check the rear dogbones, and rear diff first
< Message edited by pede_kid -- 4/4/2008 5:00 AM >
Hide Signatures
(in reply to radford512)
       Post #: 29
RE: Nitro Engine Troubleshooting and Tuning - 4/4/2008 5:21 AM
Lordmik
Score: 100
Last Login: 1/22/2010
Status: offline
CHeck the grub screw that holds the drive cup to the center trans. make sure the driveshaft that turns the rear turns with the spur. If not, it's probably that grub screw backed out.
The Revolution Has Begun...
Himoto Eldorada, Syclone, MXT-2S
Hide Signatures
(in reply to pede_187)
       Post #: 30
RE: Nitro Engine Troubleshooting and Tuning - 11/18/2008 10:57 PM
JEF1971
Score: 100
Last Login: 6/17/2009
Status: offline
IM WORKING ON A SHOCKWAVE I PUT A FEW DROPS OF FUEL IN THE CARB AND THE CAR STARTS IMMEDIATELY BUT CUTS OFF WHEN THIS FUEL BURNS OFF-IT DOES NOT PULL FUEL FROM THE TANK. IF I TAKE THE FUEL LINE LOOSE FROM THE CARB AND START THE CAR, IT PUMPS FUEL THRU THE LINES...PLEASE HELP
Hide Signatures
       Post #: 31
RE: Nitro Engine Troubleshooting and Tuning - 11/19/2008 6:10 AM
chevyderek72
Score: 100
Last Login: 11/8/2010
Status: offline
ok what you need to do is put the fuel line to the carb on, then take off the fuel line that goes to the pipe and blow in it, it will push fuel to the carb, right when fuel hits the carb stop blowing. then put a couple drops of fuel in the carb. then make sure your settings on your carb are fine. put the hsn at 2.5 turns out, and the lsn flush with the collar. those are base settings so tune from there. then it should start up. if it doesnt start up i hold the car down with the radio, and pull the throttle, put the glow ignitor on, and then pull start it, it gets more fuel to the carb and that way it will start if its being stubborn
Redcat Racing - Dunerunner, Hurricane XP, Aftershock 8e, Volcano, Volcano epx, Vortex epx, Tremor 18e pro
Its me ti**ta
Hide Signatures
(in reply to JEF1971)
       Post #: 32
RE: Nitro Engine Troubleshooting and Tuning - 11/30/2008 12:58 AM
Rene1977
Score: 100
Last Login: 2/9/2009
Status: offline
Need some help here- my pullstarted won't pull and the clutch bell won't turn, it's been like this for a while and I know it's not flooded. Help please!
Hide Signatures
(in reply to chevyderek72)
       Post #: 33
RE: Nitro Engine Troubleshooting and Tuning - 12/14/2008 7:54 AM
ohhalecks83
Score: 100
Last Login: 1/1/2009
Status: offline
wen i open the throotle more than half way it bogs out. but less than that it doesnt. whts wrong. any help
Hide Signatures
(in reply to Rene1977)
       Post #: 34
RE: Nitro Engine Troubleshooting and Tuning - 12/31/2008 1:40 AM
benandedie
Score: 100
Last Login: 12/31/2008
Status: offline
I have a volcano truck and it was not tuned well, I began to tune according to instructions and no when I try to pull start it is very hard! I need help so that I dont throw it.
Hide Signatures
(in reply to ehroof)
       Post #: 35
RE: Nitro Engine Troubleshooting and Tuning - 12/31/2008 2:49 AM
chevyderek72
Score: 100
Status: offline
its probably hydro locked, aka flooded. take the glow plug out and flip it and pull the cord.
Its me ti**ta
Hide Signatures
(in reply to benandedie)
       Post #: 36
RE: Nitro Engine Troubleshooting and Tuning - 1/10/2009 6:40 PM
AZMIN
Score: 100
Last Login: 1/30/2009
Status: offline
Hi guys. I'm newbie here and have some problem tuning my buggy engine.I know some basic stuff (high needle - clockwise will lean and vice versa.....idle needle- clockwise will high idling and vice versa) but my current problem is:
1) What is the function of low needle?
2) My engine is one gallon old and idling fine (it was broke in by LHS). However, when I give some throttle...my buggy runs smoothly and when I give full throttle for the first time...it runs nicely..BUT when I give another full throttle....the engine sounds like going to die/stall and when I continue giving full throttle..it will die/stall. Whats should I do?
Hope to get some help here.Thanks
P/s: Anyone knows any link/website that teaches how to troubleshooting/tuning nitro engine comprehensively???..
Hide Signatures
       Post #: 37
RE: Nitro Engine Troubleshooting and Tuning - 1/11/2009 12:30 AM
perhamrocks
Score: 100
Last Login: 2/9/2011
Status: offline
1) the low speed needle determines how rich or lean it is between 0 and 50% throttle so leaner equals more acceleration and also will stay idling longer.
the best way to check the low speed needle is to get your car running rund the car in a circle or two, then bring it back to you and pinch the fuel line. if it takes longer than 5 seconds to died then it's too rich, if it takes less then 3 seconds to die then it is too lean.
2)sounds like your high speed needle is too lean and it's getting starved of gas when your going full throttle. set it back to factory settings, which is all the way in, but don't tighten it!!!!!, then 2 1/2 turns out. Then re- tune it.
3)the redcat site has something about tuning but also take a look at this
http://www.youtube.com/watch?v=pEGjExP9GkM&feature=channel_page
edit: also make sure that your engine doesn't go over 260 degrees fahrenheit
< Message edited by perhamrocks -- 1/11/2009 12:34 AM >
Hide Signatures
(in reply to AZMIN)
       Post #: 38
RE: Nitro Engine Troubleshooting and Tuning - 1/11/2009 11:13 AM
AZMIN
Score: 100
Status: offline
Thanks man..will try to do as what you suggest..cheers
Hide Signatures
(in reply to perhamrocks)
       Post #: 39
RE: Nitro Engine Troubleshooting and Tuning - 1/12/2009 12:56 AM
jambafromhell
Score: 100
Last Login: 11/26/2009
Status: offline
Help!, Does anybody know that stock settings for the vx.18 engine on the tornadobb!?
Hide Signatures
(in reply to AZMIN)
       Post #: 40
RE: Nitro Engine Troubleshooting and Tuning - 1/12/2009 2:02 AM
codokas
Score: 100
Last Login: 5/25/2013
Status: offline
2 1/2 out from closed on high
flush with collar on the low
DOUG
quote:
ORIGINAL: jambafromhell
Hide Signatures
(in reply to jambafromhell)
       Post #: 41
RE: Nitro Engine Troubleshooting and Tuning - 1/12/2009 4:22 AM
jambafromhell
Score: 100
Status: offline
Dude thanks for the quick response, u are a life saver, i think i would have ****ed up my engine with out the stock settings
Hide Signatures
       Post #: 42
RE: Nitro Engine Troubleshooting and Tuning - 1/26/2009 5:47 AM
AZMIN
Score: 100
Status: offline
Guyss..another help needed!!!
When I give full throttle and straight away release back to neutral position , the engine will scream BUT hang for like 2 seconds before it idles to neutral. Why it hang for 2 seconds and not straight away back to idle position?..Usually..once I release the throttle to neutral position..the engine will straight away back to neutral/idle position.
What should I do?..How do I troubleshoot this kind of problem?..Hope someone would help me out here...Thanks
Hide Signatures
       Post #: 43
RE: Nitro Engine Troubleshooting and Tuning - 1/28/2009 4:28 AM
AZMIN
Score: 100
Status: offline
PINCH TEST
I did the pinch test and the engine stop in 3 seconds which means the setting is ok. However ..usually the engine will ramp up a little bit before it stops BUT this time it did not not ramp up at all. Whats wrong?..Any suggestion to rectify this OR it is normal for the engine not to ramp up before it stops?
Hide Signatures
(in reply to AZMIN)
       Post #: 44
RE: Nitro Engine Troubleshooting and Tuning - 2/11/2009 3:25 AM
Geoff78
Score: 100
Last Login: 3/16/2009
Status: offline
I am new to the R/C world and I have had the Tsunami for a few months now but I broke it within the first 10 minutes of owning it back in November. I finally decided to get the parts to fix it and want to operate it. My problem is though that I cannot get it to stay running once I take the Glow stick off of it. I followed all of the carb settings I found on here hoping that would work but it is not. Can anyone give me some insight as to what the problem may be?
Hide Signatures
       Post #: 45
RE: Nitro Engine Troubleshooting and Tuning - 2/11/2009 4:11 AM
perhamrocks
Score: 100
Status: offline
more than likely your settings are too rich, because the factory settings is just a general setting to get it running, but you will have to lean it out to get it to performing form. But if u are still breaking it in keep it as rich as possible while still keeping it running at the same time
Hide Signatures
(in reply to Geoff78)
       Post #: 46
RE: Nitro Engine Troubleshooting and Tuning - 2/11/2009 4:13 AM
Geoff78
Score: 100
Status: offline
What adjustments do I need to make to keep it running without the glow stick in place, while attempting to keep it "running rich"
Hide Signatures
       Post #: 47
RE: Nitro Engine Troubleshooting and Tuning - 2/11/2009 5:14 AM
perhamrocks
Score: 100
Status: offline
well first of all make sure the idle adjustment is good by taking off the air filter and making sure the opening in the carb is about 1mm. Then turn the highspeed needle all the way in, but do not tighten it, then take it 2 1/2 turns out. Then the low speed needle should be flush with the collar. if the car still loads up with fuel and dies after u take out the glow plug, lean out the low speed an 1/8 of a turn at a time. Also always make sure your exuast is spitting out plenty of blue smoke, and it should also be dripping unused fuel (for a rich setting).
Hide Signatures
       Post #: 48
RE: Nitro Engine Troubleshooting and Tuning - 2/12/2009 1:33 AM
rjsdad
Score: 100
Last Login: 3/23/2011
Status: offline
the rpm should raise a 1.5-2 seconds then shut off. If you are doing the pinch test and the rpm does not increase then you are running to lean. This is not good for the engine. Also look at your glow plug, if the coil are white then it is running hot (lean) The fuel is a lubricant as well for the engine.
Hide Signatures
(in reply to AZMIN)
       Post #: 49
RE: Nitro Engine Troubleshooting and Tuning - 2/12/2009 5:39 AM
RedcatRacing
Score: 115
Last Login: 5/20/2013
Status: offline
You can go HERE to check out some new videos we have to help you get going and help with engine adjustments.
Darin
< Message edited by RedcatRacing -- 2/12/2009 5:42 AM >
Darin Oreman
REDCAT RACING / CEO
Hide Signatures
(in reply to rjsdad)
       Post #: 50
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.484RCU1
