Gearhead8
quote:
ORIGINAL: lcyrace Finally put my kelly back in the air today. Been wrestling with motor options but settled for an OS 50 Hyper heli motor I had lying around. First off, the CG seems to be too far forward. What are most you seeing? From what I read the 65mm is too nose heavy. Also, I need to get my MAC pipe mounted but here is my dilema. I have to use the OS 3/4 inch extension that comes with new bolts. Problem is they are 3mm bolts but the MAC pipe uses 4-40 bolts. I was getting 13,400rpm with the stock pipe and 11x6 apc, files great with tons of verticle, but I want the 500 more rpms and 2oz less weight that the MAC has to offer. Hope the lighter pipe will help the CG issue. Problem is I cannot find any 4-40 x 2.5 inch hex cap screws anywhere. Anyone got any ideas? All my local hardware stores only have 1 inch or less. Please point me in the right direction if you can. I really want to fly this plane seeing as I have had it for months. Thanks in advance for any replies..... What cg issue? How can you has a CG issues?...LOL just seems odd. I don't think you are going to find a 4-40 screw that long...... Use allthread with locking nuts.
