Crazy4Flight
MI, USA Status: offline
http://www.kyoshoamerica.com/airplanes/gp/11075B.asp The same KELLY that competes in the F1-class at the Reno Air Races has been reproduced for the first time as a 70-class R/C model. The giant scale air races that are popular in the U.S. are becoming more popular in 70-class. The mostly pre-assembled structure features a fiberglass fuselage that comes complete with basic coloring and a cowl that produces stunningly realistic form - the slanted engine mount contributes to the slim nose. The pre-covered balsa main wing Features one-piece winglets just like on real airplanes, which increases efficiency and prevents stalling for increased stability at low speed. The fully featured kit also includes fuel tank, linkage parts and tires, leaving very little assembly time and cost to get airborne. The KELLY is the perfect entry point into the world of big-scale air racing. The FRP fuselage is complete with basic coloring and cowl, which produces stunningly realistic form. The slanted engine mount also contributes to the slim nose. The main wing features one-piece winglets, just like on real airplanes, which increases efficiency and prevents stalling for increased stability at low speed. The fiberglass fuselage is factory finished with the base color, so exterior detailing is simple and takes about an hour to complete. The Kyosho Kelly F1 Racer also features factory-finished fiberglass wheel pants that cover the legs to the tires for better aerodynamics and smooth flight. A unique one-piece vertical fin and main fuselage balance the upper and lower areas. The kit also includes wire linkage parts for rudder. Steering tail wheel gives free taxiing control. SKU: 11075B Street Price: $259.99 (approx.) Available - End of Feb 2007 Features: Engine mount Main gear Rudder connected to tail gear Decals Tires Linkage parts FRP fuselage sets the benchmark in scale detail and quality. Balsa main and tail wings are expertly pre-covered in film. Main parts of fuselage are factory assembled. Simply connect the main wing halves and set the servo linkages to complete. Required for operation R/C System: 4ch transmitter, 5 servos, receiver Engine: 4 stroke.52~.70 class engine Propeller: D6~12×P13~7 Spinner: 62mm Fuel, receiver battery pack Pilot figure (SV-5) is sold separately. Technical Data Length 49.6 in. (1260mm) Wingspan 55.1 in. (1400mm) Total Weight 2,500~2,600g/88~92 oz. (approx.) Wing Area 518 sq. in. (33.4 dm2) Engine four-stroke 52~70 class
