Ralpher
OH, USA Status: offline
Wow, thank you Bo for the prompt response. The set up you are using will work fine with my own installation, and when I get it completed I will post a picture for other stock hardware "SpringAir" users. I also removed the graphics and your airplane looks very nice. I am not sure if you have flown it yet, so I would be curious as to the performance. I am using two smooth running, well broken in OS46FXs with APC 10 x 6 props, which should provide for some exciting performance. If you haven't done so already, please consider using a dremel cut off wheel and cutting down those screws extending from the control horns. They are very sharp and will cut your hand or wrist if you don't watch out (I already cut my hand just casually handling the wing, as I made a note in my final "punch list" to get to it and it got me before I had a chance!) When doing it, please use a portion of a file folder (with hole cut out) or other method to pervent any hot debris from damaging the covering. Other than that, you have a great looking machine and a nice, tidy installation. Thank you again for your prompt, detailed response.
