WhtBronco
VA, USA Status: offline
Rez, I plan to make the templates for the top wing tomorrow night and will take some pics then for ya. It's not hard to do it's just very time consuming. Basically all I do is put strips of tape on a cutting board, over lapping them by about 1/2" until it's as wide as needed. Then tape the paper drawing over the top of the tape and start cutting with a sharp X-acto blade. 1 thing I have found that helps is to then, using Scotch tape, secure the piece or pieces you just cut out back into the template. It helps to keep the template in shape when doing multiple colors. I have found that Shurtape CP-28, purple painters tape, works the best for me. It's just sticky enough to stay on, comes off fairly easy and sticks to itself well. Regular masking tape can stick too much and tear the foam, and doesn't come off the cutting board well. Nor does the painters tape at the local stores work for me. You might be able to get away with 3M blue painters tape, the tape for delicate materials that's low tack. I haven't tried the low tack blue tape since it's the same cost as the purple tape shipped to me and I know the purple works. It's $11 a roll BTW and this plane will take about 1.5 rolls. FWIW, I proved my theory of too much paint causing it to run under the tape this evening. I painted the silver on the H stab and elevator and in 1 spot I got too much paint and it ran under the tape. The other lines look very nice. I already knew I wasn't very good at spray painting and apparently I need to be a little more careful.
_____________________________
Chris Wish I was flyin'!
