RE: Walmart Submarine = Cool ! Part II
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> RC Submarines >> RE: Walmart Submarine = Cool ! Part II
Page: <<   < prev  7 8 9 10 11 12 13 14 15 [16]
Login
RE: Walmart Submarine = Cool ! Part II - 4/28/2008 1:49 PM
MERLIN V12
Score: 100
Last Login: 4/11/2009
Status: offline
New London we have a problem!
My Chicago ran for about 3 minuets with fresh batteries while I was getting it trimmed. It than sank to the bottom of the pool in 5 feet of water. When I got it back I checked the battery comp and it was dry. Problem is I now have to touch the transmitter antenna to the Sub's antenna to get it to work. It has a range of about 6 inches now. Any ideas guys?
MERLIN
Hide Signatures
(in reply to jeffropaige)
       Post #: 376
RE: Walmart Submarine = Cool ! Part II - 4/28/2008 4:35 PM
normanski
Score: 100
Last Login: 10/27/2009
Status: offline
Hello Merlin,
The same thing happened to my Chicago before I turned it yellow. Water must have gone inside somewhere! Water could be in the RX compartment or one of the 3 motor boxes. In my case, the side motor box developed a hair-line crack & I have described it in more details here:
http://www.rcuniverse.com/forum/m_6086994/tm.htm
Hope it helps.
Regards
Normanski,
_____________________________
An Average Kind of Guy with A Stock Kind of Truck.
Hide Signatures
(in reply to MERLIN V12)
       Post #: 377
RE: Walmart Submarine = Cool ! Part II - 5/25/2008 5:48 AM
t warne
Score: 100
Last Login: 5/24/2009
Status: offline
Has anyone seen subs at walmart yet this season? When do they usually hit the shelves?
Hide Signatures
(in reply to normanski)
       Post #: 378
RE: Walmart Submarine = Cool ! Part II - 5/25/2008 6:27 AM
CrunchyFrog
Score: 100
Last Login: 11/21/2009
Status: offline
They hit the shelves when summer and pool toys come out, right after Easter I guess. If they don't have a new model, they roll out what's left from prior years. Last year they had a sub (available as Shark or Gator) that was a notable improvement on prior years, but it had an odd look and seemed to have a shorter production run than the previous model (seawolf/conny). There's a conspicuous absence this year !
Hide Signatures
(in reply to t warne)
       Post #: 379
RE: Walmart Submarine = Cool ! Part II - 5/25/2008 1:46 PM
MERLIN V12
Score: 100
Status: offline
I found out where the water got in. All The motors,the RX and wire tubes! Everywhere except the battery comp. Sorry to say,what a piece of junk. I'll dry it out and if by some stroke of luck it works i'll seal it up and try again. I think I can see why wally world stopped selling them.
MERLIN
Hide Signatures
       Post #: 380
RE: Walmart Submarine = Cool ! Part II - 5/25/2008 7:56 PM
CrunchyFrog
Score: 100
Status: offline
Sorry to hear about your totalled Wally boat! I have had a similar experience, every tube full of water. Ugh.
I think the idea of the design with those rubber tubes is that as pressure increases, those junctions should seal themselves tighter...but how well does that protect when the sub is only a few inches down (unless you've actually opened up the sub and sealed everything with silicone, which is more than Wal-Mart does)
Seems like it would be more effective design to have fewer connections and make the thing just one watertight compartment inside, so when it leaked you could open one lid and let the whole thing dry . But then they couldn't do the vertical thruster through the hull. And the easy-access bolt-closed battery box at center-of-gravity would be hard to keep Probably Wal-Mart is betting most parents aren't going to want to maintain the sub beyond replacing AA batteries for their kid the sub skipper.
Hide Signatures
       Post #: 381
RE: Walmart Submarine = Cool ! Part II - 5/27/2008 3:01 AM
Captain Nemo12
Score: 100
Status: offline
Woohoo! I finally got my sub trimmed to just about right. She dives steadily and cruises nicely at full throttle, once underwater, the tail sinks deeper but this is not a problem. To surface, I simply have to engage the vertical thruster a bit and throttle ahead, the sub jumps out of the water like a dolphin! P.S: I re-installed the stock battery setup and the range problem was gone, so it's gonna remain as that from now on. Here are some pics taken in the tub (yes, the sub IS floating on the surface! ), perhaps I'll have time this week to test her out in open water.
Click to see fullsize image.
Click for fullsize
Click for fullsize
< Message edited by Captain Nemo12 -- 5/27/2008 3:03 AM >
In the works: HL Panzer III, Type VIIb U-boat
Hide Signatures
(in reply to CrunchyFrog)
       Post #: 382
RE: Walmart Submarine = Cool ! Part II - 7/19/2008 6:15 PM
Aslvrfrost98csvt
Score: 100
Last Login: 11/19/2009
Status: online
i just got a walmart seawolf off ebay tried it in my pool .It runs fine on the surface but will not submerege. the dive thruster works it just wont go under . any suggestions would be great .this is my first sub so im not that familiar with rc submarines and the weight adjustments.it has the little weights in the foward and rear horizontal fins. whats the proper set up (were the water comes to when on the surface0
[url=http://www.cardomain.com/ride/2914633/][b][color=red][size=5]Cardomain[/color][/size][/b][/url]
Hide Signatures
(in reply to Captain Nemo12)
       Post #: 383
RE: Walmart Submarine = Cool ! Part II - 7/22/2008 8:48 AM
normanski
Score: 100
Status: offline
Hello Aslvrfrost98csvt,
If you take a closer look at the photos posted by Captain Nemo 2 threads above, you should see the water level is at the bottom of the tower.
The sub should come with several pieces of weight, which you can insert inside the fins to achieve the desirable buoyancy. One more thing you need to also bear in mind, that is this submarine is a 'dynamic diver', which means it will not dive when it is static.
If you are sure the Dive thruster is working, then engaging the dive thruster only causes the front of the boat to tip downward. That alone however, will not get the sub to dive. You should then engage the forward thruster so to push the boat into the water. And when you stop the forward thruster, the sub should slowly rise back to the water surface. I hope this helps.
Let us know how you get on.
Normanski
Hide Signatures
(in reply to Aslvrfrost98csvt)
       Post #: 384
RE: Walmart Submarine = Cool ! Part II - 8/19/2008 3:39 AM
cameraz
Score: 100
Last Login: 5/31/2009
Status: offline
For those of you who haven't seen my sub video yet, you can see it here:
http://www.youtube.com/watch?v=w8Lht0qkJUA
Feel free to leave comments. BTW, once the sub was 10 feet from shore I could hardly see it it blended in with the water. My GF had the advantage of the zoom on the video camera. Also, the sub is relatively slow ... compared to ducks and geese, that is.
Hide Signatures
       Post #: 385
RE: Walmart Submarine = Cool ! Part II - 9/7/2008 4:17 AM
CrunchyFrog
Score: 100
Status: offline
Not r/c, I know, but I thought I'd show the sub my son picked out at Cracker Barrel.
Any toy we pick up at Cracker Barrel, you can safely bet my son will have broken in a day. This six-dollar wonder was no different: Charlie stepped on it in the first hour.
I patched it up: glued back the broken fin, and trimmed a big tab of excess plastic I found on the propeller that had made the sub slower than a half-dead sea slug. After that junk plastic was gone, it could keep pace with a stock Wally sub, at least a Wally sub past the peak of battery charge. (The motor pod attaches under the keel, I forgot to include it for the photos) Not bad for a single AA cell.
The thing's trim was horrible out-of-the box, always flip-flopping. a) It only had three big vent holes b) it is one lengthwise chamber inside, c) the sail is supposed to hold onto the last bit of air so it stays afloat, d) with all air removed for stability, the hull is negatively buoyant. Combine those four factors, and its normal trim condition, if not sinking, is that about 3/4 the hull has filled with water but there's still a bubble trapped that slips from stem to stern or vice versa, eventually popping bow or stern out of the water and hanging suspended but never staying level. What a dull design.
I changed lines that were meant to suggest "free-flood holes" into real free-flood holes and holed the sail top as well, so all air was free to escape, not trapped as a bubble that would shift back and forth. Then I set buoyancy a tad positive with foam, stabilizing center-of-buoyancy in the middle. Stays level now, actually dives powered by just the one AA cell if I push the fins to full dive.
Better than our usual time with a Cracker Barrel toy, fully functional after Day One !
Looks a lot like the old-school Soviet subs, doesn't it?
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by CrunchyFrog -- 9/9/2008 3:19 AM >
Hide Signatures
(in reply to cameraz)
       Post #: 386
RE: Walmart Submarine = Cool ! Part II - 9/7/2008 5:18 AM
CrunchyFrog
Score: 100
Status: offline
Man, Cameraz, you sure scared those ducks !
The only wildlife I ever chased, chased back.
The sub was a Chicago, prop modded for nice power and trimmed near perfect neutral buoyancy for great maneuverability.
The fish was a koi, a bit bigger. He seemed to consider the sub an intruder.
The koi , too, seemed optimized for great power and maneuverability. That fish was one big muscle from head to tail.
As I tried to close in on him, he won every round, angling in from the beam for another look at the clumsy newcomer. He never startled.
I kept chasing him, but felt more and more anxious he was going to trash my toy !
Hide Signatures
       Post #: 387
RE: Walmart Submarine = Cool ! Part II - 10/1/2008 4:35 PM
cameraz
Score: 100
Status: offline
quote:
ORIGINAL: CrunchyFrog
Hi Crunchyfrog,
Thanks for viewing my video. I was up against several problems while making it. First, my girlfriend had never, ever operated a video camera before, so while I was operating my sub I had to direct her what to do! Secondly, the water in the pond was pretty murky and, with my sub being grey, I couldn't see the damn thing once it was more than 10 feet away. The only thing I could see was the 2 inches of black wire sticking out of the conning tower. I think the next time I will put some reflective tape on the sub so I can see it better.
BTW, that Koi you were chasing sounded pretty big! Of course, these subs will never outmaneuver a fish ... or a duck or goose for that matter!
They're lots of fun anyway!
Hide Signatures
       Post #: 388
RE: Walmart Submarine = Cool ! Part II - 10/3/2008 5:02 AM
MERLIN V12
Score: 100
Status: offline
Anyone want to buy a Chicago cheap and try to put it back together? It's dry now and seems to work.
MERLIN
Hide Signatures
       Post #: 389
RE: Walmart Submarine = Cool ! Part II - 3/28/2009 1:42 AM
thomasjohnmurphy
Score: 100
Status: offline
How is the connecticut different than the dallas?
Hide Signatures
       Post #: 390
RE: Walmart Submarine = Cool ! Part II - 3/28/2009 2:47 AM
MERLIN V12
Score: 100
Status: offline
Thats a good question as it seems they are all pieces of junk!
Hide Signatures
(in reply to thomasjohnmurphy)
       Post #: 391
RE: Walmart Submarine = Cool ! Part II - 3/28/2009 3:50 AM
Wheelnut
Score: 101
Status: offline
It's amazing how this thread keeps on going year after year I almost fogot about it. But it is time for some good sub weather
Fly Like an Eagle
Hide Signatures
       Post #: 392
RE: Walmart Submarine = Cool ! Part II - 3/28/2009 4:40 AM
junglelord
Score: 100
Last Login: 9/24/2009
Status: offline
I have been fortuante then. My Dallas is four years old I think, and it works perfect.
I am very happy with my fleet of two Dallas and a Chicago.
One Dallas has a Seaview piggyback like the shuttle on the 747 and it works great two.
Thats just my experience, not a speck of ceral, individual milage may vary.
Hide Signatures
       Post #: 393
RE: Walmart Submarine = Cool ! Part II - 3/28/2009 2:29 PM
thomasjohnmurphy
Score: 100
Status: offline
I'm in Florida on vacation right now and just picked one up on ebay. I always wanted one so when it arrives I'd like to take it out for some test runs.
Hide Signatures
(in reply to Wheelnut)
       Post #: 394
RE: Walmart Submarine = Cool ! Part II - 4/1/2009 4:38 AM
RSEA
Score: 100
Status: offline
It has been a long time since I have posted on this thread.
Recently I have acquired two hobby grade U-Boat kits and a highly recommended (by RC sub operators) hobby grade radio to run them. The radio has already been sent back to the manufacturer once since bought new and it still does not work properly. One U-Boat kit has a questionable pressure hull that I am trying to figure out what to do with and the other has appendage alignment issues that make propeller selection troublesome. So I have two boats that need problems solved before they can go anywhere near a body of water and a radio system that, so far, might make a good door stop.
On the other hand, my Walmart Gator sub that I purchased two years ago still runs like a champ! It will probably be the only RC submarine that I will be able to run this spring...possibly even this summer.
Hide Signatures
       Post #: 395
RE: Walmart Submarine = Cool ! Part II - 4/10/2009 9:52 PM
liftmys10
Score: 100
Last Login: 4/17/2009
Status: offline
You can still find these subs on ebay... Just do a search.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MESELX:IT&item=220393860051
My Sub http://www.cardomain.com/ride/224451/10
Hide Signatures
(in reply to RSEA)
       Post #: 396
RE: Walmart Submarine = Cool ! Part II - 4/11/2009 4:30 AM
Wheelnut
Score: 101
Status: offline
It is interesting how the sub in the ad is in Granada hills CA and so are you Busted
Fly Like an Eagle
Hide Signatures
(in reply to liftmys10)
       Post #: 397
RE: Walmart Submarine = Cool ! Part II - 5/31/2009 11:50 PM
cameraz
Score: 100
Status: offline
Today I put my submarine video back up. YouTube had taken it down, saying the music was a copyright infrngement.
You can see the video here:
http://www.youtube.com/watch?v=X_ilVnEdlAA
cameraz
Hide Signatures
       Post #: 398
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
2.828RCU1
