Brushless Profisherman project going
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Boats >> Speed - Electric >> Brushless Profisherman project going Page: [1] 2 3   next >   >>
Login
Brushless Profisherman project going - 1/1/2007 9:41 PM
Wheelnut
Score: 101
Last Login: 11/8/2009
Status: offline
I had this idea a while back but before I was going to put a 400 brushless motor in the outboard. This time, I just got finished stripping out my old grey profisherman and putting all the gear in the red one that great planes shipped me for free So instead of throwing the old grey hull away and since I have a 540 Feigao brushless motor laying around, I thought I'd try something that I don't think has been done yet. I am going to install a surface drive for it and go from there. I like the red alot better anyway. When I bought mine it was on sale and the only color that the LHS had.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Fly Like an Eagle
Hide Signatures
       Post #: 1
RE: Brushless Profisherman project going - 1/1/2007 9:59 PM
Wheelnut
Score: 101
Status: offline
First I need help positioning the motor. Where should it be? I hope I don't have to cut the middle section out because then I wll need to find a way to seal the hatch again and I'm not really into fabing lexan.
Fly Like an Eagle
Hide Signatures
(in reply to Wheelnut)
       Post #: 2
RE: Brushless Profisherman project going - 1/1/2007 10:22 PM
CadillacDTS2001
Score: 100
Last Login: 10/28/2009
Status: offline
put it near the transom
And to keep the scale look of the boat . use the out drive as a steerable out drive.
like where the prop is . drill it out all the way there and put a brass tube of the rite size and then the motor shaft and coupler . and no one will be the wizer.
"brushless motors have to have a rudder on it"
the best quote of 2008 ^^
Hide Signatures
       Post #: 3
RE: Brushless Profisherman project going - 1/1/2007 11:10 PM
Orange Crush
Score: 100
Last Login: 1/11/2009
Status: offline
...or just send me the outboard for my new "bouy barge" project.
Aeromarine Mean Machine/Aquacraft Supervee27/
5700kv Mamba Powered Ruslter
Hide Signatures
       Post #: 4
RE: Brushless Profisherman project going - 1/1/2007 11:35 PM
Wheelnut
Score: 101
Status: offline
They sent me the red hull not the motor. The motor off the grey one is on the red one now and going to stay there
So lets start over. You said put it near the transom right? Where should the balance point be? and is that with batteries? I would guess so. With that said, if that is so then The placement of the motor is not so crucial right? because I can use the placement of the batteries to shift the balancing point right?
Fly Like an Eagle
Hide Signatures
(in reply to Orange Crush)
       Post #: 5
RE: Brushless Profisherman project going - 1/1/2007 11:53 PM
CadillacDTS2001
Score: 100
Status: offline
quote:
ORIGINAL: Wheelnut
the placement of the motor isn't that critical . because you can off set it with the weight of the battery
But think of it this way . where is the stock motor? hanging over the transom.
so put it far back and the battery in the stock position. and it will be set up just like it was stock with the motor wight near the transom and the battery at the front
Hide Signatures
       Post #: 6
RE: Brushless Profisherman project going - 1/2/2007 12:00 AM
Wheelnut
Score: 101
Status: offline
Cool, thanks, that is exactly the info I was looking for. I will get it started.
Fly Like an Eagle
Hide Signatures
(in reply to CadillacDTS2001)
       Post #: 7
RE: Brushless Profisherman project going - 1/2/2007 7:00 PM
GregS
Score: 100
Last Login: 9/18/2009
Status: offline
What about getting another outboard unit and using that. It would be a lot simpler than trying to convert it to an inboard and would look realistic and still be a "bass boat". If you had to have it set up as a surface drive it is possible to raise the motor by modifying the mount.
Hide Signatures
       Post #: 8
RE: Brushless Profisherman project going - 1/2/2007 7:02 PM
CadillacDTS2001
Score: 100
Status: offline
quote:
ORIGINAL: GregS
it wouldn't be that much simple. the other OB of that size wont handle the power and the max sized prop you can put on the OB is was to small for the BL any way.
Also there are inboard bass boats to .
i have seen one with a merc 525 at 110 mph.
as a matter a fact i raced it later that day.
Hide Signatures
(in reply to GregS)
       Post #: 9
RE: Brushless Profisherman project going - 1/2/2007 8:01 PM
Wheelnut
Score: 101
Status: offline
Thanks Greg, but thats not really what I was looking for. I am doing this just to see how it turns out as a inboard surface drive. After all I was going to throw the hull away, this is the one I crashed into a wall and could not repair it to my own liking.
Fly Like an Eagle
Hide Signatures
       Post #: 10
RE: Brushless Profisherman project going - 1/2/2007 8:04 PM
CadillacDTS2001
Score: 100
Status: offline
quote:
ORIGINAL: Wheelnut
this hull might end up like you sun storm or what ever it was called . *bouncy bounce*
Hide Signatures
       Post #: 11
RE: Brushless Profisherman project going - 1/2/2007 9:10 PM
GregS
Score: 100
Status: offline
Wheelnut: Fair enough. I figured the inboard conversion was likely a part of your project in itself.
EyeKandy: I'm not sure how familiar you are with the outboard but its durability should not be an issue and there should be no reasonable limit to the power it can handle. The gears and shafts are solid metal (not plastic) and should be able to withstand a lot more torque than a flexshaft. A 35 mm prop is about the largest that can be used and the largest motor that will fit is 600 size. One day when I have the time and money I may put a brushless in mine.
Didn't know there were non-outboard bass boats but I believe you. Is the one you mention a stern drive?
Hide Signatures
       Post #: 12
RE: Brushless Profisherman project going - 1/2/2007 9:42 PM
CadillacDTS2001
Score: 100
Status: offline
quote:
ORIGINAL: GregS
hey yeah. the prop for the brushless motor would be about 40 mm so that won't work
the bass boat was a nitro bass boat conversion one off.
factory built .
it has a 525 and a bravo one XR sport drive.
pretty quick considering that a 300 on the same boat does about 90 mph.
it ran fast . crazy acceleration. my cat does 0-100mph in 12 seconds and i almost lost to him. ALMOST. but then i just flew bye him. Once he hit max rpm i still had 2100 rpm more to put out.
< Message edited by eyekandyboats.inc -- 1/2/2007 9:47 PM >
Hide Signatures
(in reply to GregS)
       Post #: 13
RE: Brushless Profisherman project going - 1/2/2007 10:00 PM
Wheelnut
Score: 101
Status: offline
quote:
ORIGINAL: eyekandyboats.inc
quote:
ORIGINAL: Wheelnut
I hope not and I have a feeling its not, because the bottom is not round like the Sunstorm was. the profisherman has a completely different hull with a good flat spot in the rear of the hull.
I'll keep my fingers crossed. It will take me a couple of days to get the drive set up. I'm in the middle of cutting a shaft now.
Fly Like an Eagle
Hide Signatures
       Post #: 14
RE: Brushless Profisherman project going - 1/3/2007 2:18 AM
Quicksilver1
Score: 100
Last Login: 12/28/2007
Status: offline
deleted
< Message edited by Quicksilver -- 1/3/2007 5:34 PM >
Jet Villain IV (Graupner 29mm drive 700sc motor)
v(8.0) coming soon
Hide Signatures
       Post #: 15
RE: Brushless Profisherman project going - 1/3/2007 2:20 AM
CadillacDTS2001
Score: 100
Status: offline
quote:
ORIGINAL: Quicksilver
One thing, if you use the outboard for vector steering, it looks like it would have to be modified due to the position of the motor on the transom. It seems like its about 1/4 to a 1/2 inch below the bottom of the hull. The shaft would have a wicked angle being the motor will be set by the transom(which I completely agree with). Cutting the lower unit off the outboard would fix this, it wouldn't look real at all out of the water, but would look fine racing around. Also doing it that way, you could put the shaft in at the optimum angle. At the same time, maybe the motor will be a pain and perhaps buying a dummy motor later on would be a better idea.... I'll keep thinking
he doesn't have a out board ?
and vector steering ? there is only one motor on the boat
Hide Signatures
(in reply to Quicksilver1)
       Post #: 16
RE: Brushless Profisherman project going - 1/3/2007 2:30 AM
Quicksilver1
Score: 100
Status: offline
deleted
< Message edited by Quicksilver -- 1/3/2007 5:35 PM >
v(8.0) coming soon
Hide Signatures
       Post #: 17
RE: Brushless Profisherman project going - 1/3/2007 2:31 AM
CadillacDTS2001
Score: 100
Status: offline
bah, for some reason I thought someone said something about making the outboard a dummy to look scale, guess I read it wrong, and I guess I used the wrong terminology, I meant vector as in a villain IV type drive.... get me. Obviously I realize that is not a great setup....since a rudder is better, got confused.
lol
the villian isn't vector .
it is a steerable out drive
< Message edited by eyekandyboats.inc -- 1/3/2007 2:32 AM >
Hide Signatures
       Post #: 18
RE: Brushless Profisherman project going - 1/3/2007 2:44 AM
Wheelnut
Score: 101
Status: offline
FYI, as I am sure most of you know but just for the record, I will be installing a servo controlled rudder.
Fly Like an Eagle
Hide Signatures
       Post #: 19
RE: Brushless Profisherman project going - 1/3/2007 2:46 AM
CadillacDTS2001
Score: 100
Status: offline
any progress on it yet .
picture picture pictures!
Hide Signatures
       Post #: 20
RE: Brushless Profisherman project going - 1/3/2007 3:03 AM
Wheelnut
Score: 101
Status: offline
Sorry, I was watching Future Weapons. Really cool stuff.
Anyway. I wanted to test the red stock one since I just put it back together and I just ruined the stock esc that came with it by accidentaly putting the connector from the esc into the receiver backwards. Now it only works in reverse and I only get about half throttle. So even if I switched the wires to have forward only I still would only have half throttle. So I will need a cheap esc for the stock boat now which by the way is running a 19 turn quad motor.
I will get back on the brushless surface drive conversion on the grey one tomorrow night with Pictures.
Fly Like an Eagle
Hide Signatures
       Post #: 21
RE: Brushless Profisherman project going - 1/6/2007 8:51 PM
Wheelnut
Score: 101
Status: offline
OK, finally got the motor mounted in the boat. I just epoxied the motor mount in to keep it simple and quick. After all, I won't be keeping this boat for long, its just for a test.
Here are some pics of the progress so far.
Click for fullsize
Click for fullsize
Click for fullsize
Fly Like an Eagle
Hide Signatures
       Post #: 22
RE: Brushless Profisherman project going - 1/6/2007 11:52 PM
CadillacDTS2001
Score: 100
Status: offline
cool cool. i like it simple and easy to remember
Hide Signatures
       Post #: 23
RE: Brushless Profisherman project going - 1/7/2007 1:00 AM
Wheelnut
Score: 101
Status: offline
Ok, got some more done. The rudder assy is on and the servo is mounted with double sided tape and the connector rod is installed. the new antenna is mounted on. I just drilled a hole and siliconed it in.
Quick and dirty, GET ER DONE
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Fly Like an Eagle
Hide Signatures
       Post #: 24
RE: Brushless Profisherman project going - 1/7/2007 1:07 AM
Wheelnut
Score: 101
Status: offline
Tomorrow will be the test with video. All I need to do now is lay down some velcro tape to hold the battery in place. I am going to start with a 6 cell pack and see how it goes. If it runs good I will put in a 7 cell and see how that pushes it
Someone remind me how to set up my Garmin Forerunner 201 to read max speed. I can't find the book.
Fly Like an Eagle
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.453RCU1
