Converting from gas to glow
Tower Hobbies
Logged in as Guest
  Printable Version
XYZ-50cc Gas Engine
Seller:  XYZUSA
Details:   $249.00   |  7/3/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> Converting from gas to glow
Page: [1]
Login
Converting from gas to glow - 1/1/2007 11:35:49 PM
jkhorvath
Status: offline
I am in the process of lightening one of my aircraft. One step I am taking is to swap out the Brison 2.4 gasoline engine and replace it with an OS 160 glow fuel engine. Can anyone tell me if I need to change out the fuel system, which is setup for gas, in order to start using glow fuel?
       Post #: 1
RE: Converting from gas to glow - 1/2/2007 4:06:44 AM
carrellh
Status: offline
The rubber stopper and the fuel lines are usually different for gas vs glow
_____________________________
Regards,
Carrell
(in reply to jkhorvath)
       Post #: 2
RE: Converting from gas to glow - 1/3/2007 2:39:01 AM
downunder
Status: offline
I'm not totally certain but I think you can use the gas stopper and fuel lines for glow but definitely not the other way round. Mineral based fuels/oils (petrol or kero as in diesels) attacks the silicone type rubbers used for glow fuel.
(in reply to carrellh)
       Post #: 3
RE: Converting from gas to glow - 1/16/2007 8:39:13 PM
jkhorvath
Status: offline
OK, so, I've done the conversion from Gasoline to Glow fuel using all Gasoline components in the fuel system. Here's what I found out:
Gasoline components used in the fuel system for a glow fuel setup mostly works fine. I have no problems with the glow fuel attacking any fuel system component, however, the one issue I did find is the following. In a glow fuel system setup, most of the time you will run one line to the muffler for fuel system pressure. Note that this is not true for "pumped" glow fuel systems. However, if you need to run one line to the muffler, then you need to change that line to silicone. If you leave that line as Tygon, then the heat from the muffler will melt the fuel line (pressure line). Using a silicone line for muffler pressure will not be bothered by the muffler heat.
(in reply to downunder)
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.469RCU1
