AirRayInc
Joined: 12/30/2001 From: San Pedro, CA, USA Status: offline
quote:
ORIGINAL: crg13 Ray, Blueprint? If you mean just clean up the stock motor a little there are a few guys who can probably give you the basics. If you want it hotrodded there are a couple of guys who do it, Fred French in Texas being one. An alcohol motor may not be too great for sport flying however. For stock racing we run the APC F1GT prop, it's 20" diameter. It's also not great for sport flying, we usually land deadstick to try and get slow enough. Otherwise just run whatever would suit the GT80. There's not really an exhaust that works within the GR7 cowl. The exhaust ports are very close to the cowl, so a muffler system would probably have to exit the cowl then re-enter before exiting somewhere else. We run straight exhaust stacks and cut them flush with the cowl. That thread/blog may have been mine, if it was at RCG and showed the airplane pink before being white. The ducts exit on the underside of the cheek cowls a few inches before they end. Craig. quote:
Craig, no not a full blown race prep, but deffinately something with more umph, on just pump gas. Considering the cost of props, what is the "best" prop for a mildly prepped gt 80? Yeah you are right, I did see the plane on RCG, a shot in the California Desert I think. I make it out to Rabbit Dry Lake every now and then. Thanks for all the information, I am pretty excited about this plane. Gonna shoot for a Army Racing Replica Scheme when all done. Ray ok all great info, still wondering, Who can blueprint the Z twin/ either before or after I have bought one What the best prop choice would be What exhaust works within the cow. Can I get a couple of shots of the engine and cooling set up please. I stumbled across a thread/blog where a guy built his own cooling ducts. But I could not see the exit
_____________________________
My Blog http://www.rcgroups.com/forums/member.php?u=9311 http://airrayinc.com
