Bobby Folsom
Joined: 3/11/2005 From: Vicksburg, MS, USA Status: offline
quote:
ORIGINAL: STG quote:
ORIGINAL: Bobby Folsom I went round and around wtih the programmer this morning trying to get the settings to "take". The neither the servo dB width nor the servo speed would stay from what I had dialed in. I tried the input button, the M button, both together - nothing worked. Everytime I turned the know with a different program, the settings changed. I followed the instruction sheet that came with the programmer exactly. What gives? I appreciate any help you can give me on this. Thanks. Bobby Bobby does your Reset or Program cw/ccw function work on your programmer? Do you have the newer software loaded on yours(V1.4). I spent about 1/2 hour trying to get something to happen this morning, but came away with nothing new. Only function seems to be S-test manual, voltage & measure pulse(last two with radio in the loop). Everything else starts searching and loops back to beginning without moving on. STG, the number on the end of the programmer is 06.3. I haven't seen any menu where the version number showed up. One thing though, I think the settings take because they show up in the "X" side of the reading. The key strokes are confusing to get there but I think it does finally work. Persevere and hang in there. Bobby Bobby
