RE: increasing compression on Saito 4S..!?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
O.S. Engines O.S. FT-300 Twin
Seller:  thunderbolt-RCU
Details:   $600.00   |  5/18/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> RE: increasing compression on Saito 4S..!?
Page: <<   < prev  1 2 3 4 [5]
Login
RE: increasing compression on Saito 4S..!? - 4/28/2012 4:04 PM
SrTelemaster150
Score: 229
Last Login: 5/24/2013
Status: online
quote:
ORIGINAL: canardlover
SrT:, many thanks for your viewpoints which I appreciate a lot... ...regarding your second post on the pushrod length/angles I must take some time to really absorb what you said before responding. Shortening the PR is very simple I think I could take it out, shorten it and have it back in again in 15-20 minutes - no sweat.. ..provided I am fully convinced I should shorten it. Please allow me to come back on this item...Thanks..!
Of course you do realize that all this is "splitting hairs" as far as potential performance loss/gain.
The only thing that would make me seriously consider shortening the PR is if there was not enough adjustment left
_____________________________
Club Saito #785 - FA91S CDI, FA150 CDI, FA180 CDI, FA180HC CDI/BBC, FA200TI, FA300TTDP CDI
Hide Signatures
(in reply to canardlover)
       Post #: 101
RE: increasing compression on Saito 4S..!? - 4/28/2012 4:30 PM
canardlover
Score: 100
Last Login: 5/16/2013
Status: offline
quote:
In my simple trigonometric world I would prefer to have these two lines being perpendicular to each other at "half open" valve position to achieve maximum valve opening..?!?!
Oooops, sorry folks I was dead wrong with this earlier remark. Thruth is that "net valve lift" has a minimum at "perpendicular" angles not a maximum as I wrote - apparently with my brain disconnected.... ...!! I now sat down at the drawing board and found out that "net lift" increases rather dramatically when the angle increases from "square". Now, this explains why Saito has chosen to have the inlet valve PR pointing forwards rather than the exhaust PR which points slightly backwards. I hereby humbly apologise to Saito for insinuating they had "suboptimized" the engine..... ..!!..and this indicates that they also consider - as expected - that inlet valve lift is more important to engine performance.
So what I should do is to shorten the PR as much as the increased sideways movement will allow. And my measurements with pushing down the valves at TDC(fire) and TDC(overlap) shows that there is still plenty of clearance to the piston crown even for this engine.
SrT (and others) do we agree on this "net lift" topic...?!?
And then about "valve acceleration" I think we can conclude that this also should have a minimum at "square" angle..Right..!?
SrT: thank you so much for forcing me/us to dig deeper in this area....
Revver Brother #84
Hide Signatures
       Post #: 102
RE: increasing compression on Saito 4S..!? - 4/28/2012 6:32 PM
SrTelemaster150
Score: 229
Status: online
quote:
You will reap a LOT of benefits by also streamlining the exhaust port bowl. You have increased flow in the intake bowl, by doing likewise on the exhaust bowl you will positively influence scavanging, thereby further increasing the intake flow.
Yes indeed you are correct but the ''operation'' was so demanding that I hesitate to repeat it.... .. Next time I think I will rather try to preheat the cylinder unit, push out the bronze valve guide and work from above.
Why not make the flow divertor part of the valve guide itself?
Hide Signatures
       Post #: 103
RE: increasing compression on Saito 4S..!? - 4/28/2012 10:44 PM
canardlover
Score: 100
Status: offline
quote:
ORIGINAL: SrTelemaster150
Excellent idea SrT, should we not pass it on to Saito....!?!?... ..!
Honestly I have played with the idea to silver solder a brass insert to the valve guide which has a flat underside - should be doable....Cheers..
Revver Brother #84
Hide Signatures
(in reply to SrTelemaster150)
       Post #: 104
RE: increasing compression on Saito 4S..!? - 4/29/2012 2:34 AM
SrTelemaster150
Score: 229
Status: online
I think that the Saito valve seats were integral W/the valve guides @ one time.
< Message edited by SrTelemaster150 -- 4/29/2012 4:18 PM >
Hide Signatures
       Post #: 105
RE: increasing compression on Saito 4S..!? - 4/29/2012 1:14 PM
canardlover
Score: 100
Status: offline
I think so too but have no pics available on the early ABC Saitos. Very much like on this Enya.60 as I remember it...Cheers
Click to see fullsize image.
Click for fullsize
Revver Brother #84
Hide Signatures
       Post #: 106
RE: increasing compression on Saito 4S..!? - 5/6/2012 8:31 PM
canardlover
Score: 100
Status: offline
The modified .82 engine with a head space of 1.05mL giving CR=13.8 and a squish band of 0.65mm has now been run in benchtest and showed a marked improvement in power as compared to the results on the stock engine(9,500/2,700 rpm) in post #65 above.
Both modified engines .72GK and .82 were run with the same 13x8 prop. and the .82 has now "overtaken" the .72GK so the performance order is now restored:
.72 GK gave 9,500/2,400 - sweet running..
.82 engine gave 9,800/2,200 - harsh running.. ..some detonation..??
Using the .72GK as reference the modifications on the .82 has gained some 400+400rpm=800rpm gain. Why the .72 has "lost" some 400rpm since post #65 is probably a combination of warmer wheather and less nitro in fuel (5%) and both engines now have velocity stacks fitted.
However, I am not at all happy with the .82 due to harsh running and vibrations so I took it apart and put the piston back in the lathe and shaved off another 0.15mm from the crown.This increased head space to 1.10mL with corresponding CR=13.2.
As you see from the "balance act" pics the .82 is still markedly "under-balanced", the crank counterweight can only balance out the lightened conrod but not the wristpin, piston, ring and scuff pads. Further lightening of piston and conrod done - see pic. but this skeleton .82 piston is still heavier than a stock .72 piston... ...More later after new bench test..
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Revver Brother #84
Hide Signatures
       Post #: 107
RE: increasing compression on Saito 4S..!? - 5/9/2012 11:40 PM
canardlover
Score: 100
Status: offline
OK folks I am at the "end of the road" regarding the .82 engine. Still got 9,800/2,000 in bench test and still with rather rough running. The tick-over is nice though, had it going for some time at 1,600-1,800 but 2,000 is stable. All on 5% nitro, 5% castor, 10% ML70 oil-balance MeOH, brand new OS F plug and 13x8 prop.and large plastic spinner.
Ran the .72GK at the same time under identical conditions - even the prop nut/washer was the same.. ...and it gave 9,400/2,100 with much less vibrations.... ...sweet..!
That´s it for now from my "tinker shop"....the .82 now goes into the Kelly F1 Racer and the .72 into my Ultra Sport.60.....sack time..
Revver Brother #84
Hide Signatures
       Post #: 108
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Glow Engines >> RE: increasing compression on Saito 4S..!?
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.406RCU1
