MBX5T Maniac
Joined: 12/21/2004 From: none, TX, USA Status: offline
Yes, it does look nice. Personally, if you think it looks good in those pictures, it looks even better in person. For you guys that worry about those flimsy looking shock towers, buy one of each, cut the shock mounting positions on the currently mounted one off, and screw this second one on over it. Use a screw and a nut to secure the bottom of the new shock tower to the mounted one. This way, you'll have a 4mm shock tower, with a higher shock mounting, so you can set the ride height lower. Quote from Greg him self: "I used two rear shock towers to make one, I cut the shock holes off one tower and bolted them on another tower at about 45 degrees in order to get a higher shock hole position for the rear."
_____________________________
My toys: LST, Mini Inferno, XX-CR, GrassHopper, RC10, Rustler, MBX5T Prospec, Mugen MST-1
