JB Rekit
TX, USA Status: offline
quote:
ORIGINAL: OnTheEdge John, I see you added flying wires to your tail on the Yak. Any reason other than added strength? That's all. I have had tails in the past get play in them after a couple hundred flights (not Cardens, but same tube and foam sheeted tail) and haven't had the slightest bit of play even after several hundred flights since using a set of flying wires. And I don't take a weight penalty either since it is the only thing I use to hold the tail on with (no other bolts/ hardware or L brackets). I'm sure there are a lot of people on here that have not had any issues with this, it just lets me know that I won't have to spend time taping or clear coating my tube to get everything snug again ever.
_____________________________
Build a man a fire, he'll be warm for a day. Set a man on fire,he'll be warm for the rest of his life www.jkbraziel.com
