Sport Jett 50 in Patriot?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> Jett Engineering Support >> Sport Jett 50 in Patriot?
Page: [1]
Login
Sport Jett 50 in Patriot? - 1/30/2003 11:03:22 AM
controlmech
Status: offline
I was able to get a one of the GP Patriot kits and am looking for a power plant. I'm going to build with retracts so the plane will be clean in the air. The Sport Jett 50 looks promising. I looked at the web site and saw a stated rpm of 17,000 with an APC 10x6. Is this engine intended for higher rpm operation? Would going with the 8-9" dia APC's and changing pitch to get the engine rpm in the 17,000+ range be a good application of the 50?
       Post #: 1
Sport Jett 50 in Patriot? - 1/30/2003 10:57:52 PM
mtthomps
Status: offline
My Jett .50 turns 18,000 with a 10x6 APC. It is not fully broken in yet. The docs say 17,000+ as the main power band. I think that an 11x7 would be better, because the RPM is likely to go up from there once the plane gets up to speed. If you want FAST, then a 10x8, 10x9 would probably be ok. I would not go smaller than a 9x. I left a full gallon of fuel at the end of the picnic bench about 7 feet behind the engine. It blew it right off!
(in reply to controlmech)
       Post #: 2
Sport Jett 50 in Patriot? - 1/30/2003 11:53:57 PM
bob27s
Status: offline
Hi,
Thank you for writing.
I personally fly a SJ-50 in my Patriot ARF. It is the perferct powerplant for that airplane.
Pleanty fast, very reliable.
The engine and muffler will work in a good power band up to about 18000 rpm. You can experiement with props that keep you in the 16,500 to 18,000 rpm range.
Always set the mixture on this engine slightly rich on the ground. Breifly find peak rpm (by ear, or tach) then back the needle out a serious 1/4 turn to drop about 500 rpm.
From my experience with the combination, my favorite prop is still the good ole APC 10x6. It provides wonderful all-around performance. I have experiement with APC 10x7, 10.5x6, 9x8, 9x7 and a few of the APC D1 serise Q-500 props. Of the racing props, the 8.8x9.0 and 8.8x9.25 work quite well. Initial take-off performance will suffer a bit, but they unload quite nicely in the air.
You will see props 9" dia or less mentioned for the SJ-50 in a lot of posts for the Whiplash and such. They work well there, but the Patriot is just a bigger plane, and will not achieve enough speed to let the little props unload and do their job well.
Hard to provide much more detail info, because I just leave the 10x6 on the Patriot most of the time and enjoy the plane
An 11x7 is too much prop (per other post) for the SJ-50. The engine will not unload as well in the air. An 11x5 or 11x6 would be better choice, and will actually give you excellent take-off and landing performance, but lower top end flight speed. Ground clearance is an issue for me, so I have not attempted this with the sj50
An APC 10x8 might be ok, as long as it will peak near 16,500 on the ground, and you can launch it at about 16,000. Engine will unload quite a bit in the air. Only try this after proper engine break-in, and then about 30 min of flight time.
I hope this is helpful
Bob Brassell
< Message edited by bob27s -- Jan 30 2003 7:07PM >
       Post #: 3
Sport Jett 50 in Patriot? - 1/31/2003 6:24:52 AM
controlmech
Status: offline
Well, the carb and muffler are red so I wonder if I can talk the wife into making it a Valentines present???
Must be the CA fumes......
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.656RCU1
