CM Pro Discus CS    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> RC Gliders, Sailplanes and Slope Soaring >> CM Pro Discus CS Page: [1] 2   next >   >>
Login
CM Pro Discus CS - 1/4/2007 3:13 PM
Slope Flyer UK
Score: 100
Last Login: 5/15/2007
Status: offline
Hi all.
Does anyone own the above ?.
I'm coming to the end of my assembly, and would like to hear some comments please..
Hide Signatures
       Post #: 1
RE: CM Pro Discus CS - 1/4/2007 6:59 PM
daveosoar
Score: 100
Last Login: 5/12/2008
Status: offline
Not Yet!
I,m waiting on delivery from my LHS so will be pleased to keep in touch. There's been plenty of input on RC Groups. Mostly better than that on its predecessor, the DG1000.
Got your PM - my reply seems to have got lost but I'm in daily touch with Terry and Biggles Terry.
Feel welcome to use my email -- enticott3@aol.com
Happy new year.
Dave.
Hide Signatures
(in reply to Slope Flyer UK)
       Post #: 2
RE: CM Pro Discus CS - 1/5/2007 8:20 AM
Slope Flyer UK
Score: 100
Status: offline
Hi Dave.
Happy new year, too !.
Overall, its a nice kit......with some nice features.
I have noticed though, there seems to be a bit of anhedral in the wings, when they are mounted onto the fuz ?. This should level out though, in flight.
My recommended gear installation is:-
2 x Hitec HS-85MG's in the wings
1 x Hitec HS-55 in the fin, operating the elevator.
1 x Futaba S148 operating the rudder (via closed loop)
I'm using a Multicell 4.8v, 1000mAh, 2/3AF Ni-Mh battery............which is powering a JR RS77S "synth" Rx.
Hide Signatures
(in reply to daveosoar)
       Post #: 3
RE: CM Pro Discus CS - 1/5/2007 1:29 PM
Slope Flyer UK
Score: 100
Status: offline
Here you go Dave...
This is what it looks like, straight out of the box !!
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 4
RE: CM Pro Discus CS - 1/6/2007 2:16 AM
jak2998
Score: 100
Last Login: 3/18/2008
Status: offline
hi slope flyer.jak2998 here. would like details on where to purchase the discus
jak
Hide Signatures
       Post #: 5
RE: CM Pro Discus CS - 1/6/2007 2:25 AM
daveosoar
Score: 100
Status: offline
jak2998,
Its distributed by J Perkins. The arrival date in the UK was 03.01.07 according to their website. I have one on order from my LHS (PLUG-- Channel 4 Bournemouth) and hope to get it as soon as Customs release the import.
Dave.
Hide Signatures
(in reply to jak2998)
       Post #: 6
RE: CM Pro Discus CS - 1/6/2007 4:04 AM
Slope Flyer UK
Score: 100
Status: offline
Hi Jack.
Great to have you here..............at least I'm not banned from this forum !!.
I got mine from Punctillio Model Spot, who had a stall at the BARCS soaring market.
Any reputable Perkins dealer in the UK, should be able to get one.
Have a word with Steve Webb Models, thats probably the best shop near to you !
Hide Signatures
       Post #: 7
RE: CM Pro Discus CS - 1/6/2007 7:12 PM
jak2998
Score: 100
Status: offline
thanks steve will have a trip to steve webb for bits and pieces. will enquire while i am there.. i am getting rid of the carbon mini blade. and getting a semi-scale job for the summer. if you know of anyone who wants a swop>>
jack
Hide Signatures
       Post #: 8
RE: CM Pro Discus CS - 1/7/2007 1:20 AM
daveosoar
Score: 100
Status: offline
Still waiting! Please keep the thread running, I need all the help I can get.
Dave.
Hide Signatures
       Post #: 9
RE: CM Pro Discus CS - 1/7/2007 6:52 AM
Slope Flyer UK
Score: 100
Status: offline
Hi Jack.....
I can't blame you about the Mini Blade !
I'm gonna be at SWM on Thurs Jan 18th, if you fancy meeting me there.
Hide Signatures
       Post #: 10
RE: CM Pro Discus CS - 1/7/2007 6:56 AM
Slope Flyer UK
Score: 100
Status: offline
quote:
ORIGINAL: daveosoar
Dave.
I'm not going anywhere !!
The fittings that it comes with, look a little weak, if you ask me......the horns especially.
Hide Signatures
       Post #: 11
RE: CM Pro Discus CS - 1/9/2007 12:51 AM
daveosoar
Score: 100
Status: offline
SFUK, Thanks. I'm sure 25 year old BOB will see me covered for doubtful items
Dave.
Hide Signatures
       Post #: 12
RE: CM Pro Discus CS - 1/9/2007 10:06 AM
Slope Flyer UK
Score: 100
Status: offline
If you want more pics on here.......let me know
Hide Signatures
       Post #: 13
RE: CM Pro Discus CS - 1/9/2007 5:21 PM
TFLG
Score: 100
Last Login: 3/19/2008
Status: offline
Most of the hardware is adequate. I did end up replacing the clevices and I made my own carbon fiber control horns but the ones that came with it looked fine. I just prefer my usual hardware. The part that does not look up to the task is the wing rod and the wing tubes. I did replace the wing tubes on mine with carbon tubes beacuse one side was loose and was flopping around inside the wing. The anhedral is due to the wing rod flexing under the weight of the wings. In flight it goes the other direction but because it is so weak there is a fair amount of wing flex. Applying spoileron or flaperon will also cause the wings to flex a fair bit. I have ordered some 6mm steel rods to replace the carbon joiner on mine. Hopefully that will reduce the flexing. I may bed the rod to add a bit of dihedral. The kit looks just plain stupid with the wings hanging down like saggy titts on an old tart.
TFLG
< Message edited by TFLG -- 1/9/2007 5:22 PM >
Hide Signatures
       Post #: 14
RE: CM Pro Discus CS - 1/10/2007 1:33 PM
Slope Flyer UK
Score: 100
Status: offline
Cheers for that.
I've replaced all the horn on mine, as the standard ones look too thin. I have used them on the rudder though, as with the standard "closed-loop" set-up.
The pushrods and clevises were also replaced, as they looked way too flimsy to me...........and new servo covers were made too, as the kit ones were too thick !.
For the price, its a reasonable kit.............but as they say, you get what you pay for.
Hide Signatures
(in reply to TFLG)
       Post #: 15
RE: CM Pro Discus CS - 1/10/2007 8:48 PM
daveosoar
Score: 100
Status: offline
Saggy ****, old tart
Sounds like my double X. I'm hoping the new model (in both senses) will be a great improvement.
Or am I just an old romantic - again in both senses?
Dave.
Hide Signatures
       Post #: 16
RE: CM Pro Discus CS - 1/12/2007 9:25 AM
TFLG
Score: 100
Status: offline
Well I did get my stainless steel 6mm rod I have installed it in the plane. I bent a few degrees of dihedral into the rod and the plane looks much much better. No more old saggy's. I did not think I would get a bent rod through the tube in the fuse. But the tube is so flimsy that it just conforms to the bend in the rod. The wings are ever so slightly up now when it sits on the bench and once in flight they should take a more scale look. The wings are also a little less flexy with the steel rod. If your gonna slope it I highly recommend switching to a steel rod with a few degrees of dihedral in it.
TFLG
Here's a few pics of the fix. The pics are my DG-1000 but the Discus is the same.
Pic 1 is the stock carbon rod. pic 2 is the steel joiner with the dihedral bend in it. Pic3 is the plane with the steel rod installed
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by TFLG -- 1/12/2007 9:48 AM >
Hide Signatures
       Post #: 17
RE: CM Pro Discus CS - 1/12/2007 8:04 PM
Slope Flyer UK
Score: 100
Status: offline
Hiya...
Woah........thats waay too much anhedral !.
My Discus doesn't have that much. I am going to try it with the standard joiner rod first, and if need be.......will change it
Hide Signatures
(in reply to TFLG)
       Post #: 18
RE: CM Pro Discus CS - 3/25/2007 10:25 PM
Slope Flyer UK
Score: 100
Status: offline
I bit the bullet, and sold the Discus £127.......without even flying it !
Hide Signatures
       Post #: 19
RE: CM Pro Discus CS - 5/30/2007 8:43 AM
bigman
Score: 100
Last Login: 6/20/2013
Status: offline
Hi TFLG
Recently, I have bought CMPro Discus and have the same problem as you had before. You have replaced the origin carbon rod with a steel rod and bent it to make dihedral for both wings. I would like to know
How many degrees to bend the steel rod? and
How can plug this steel rod into the fuselage because it has been bent?
Click for fullsize
Hide Signatures
       Post #: 20
RE: CM Pro Discus CS - 9/24/2007 3:04 AM
JeanLucPicard
Score: 100
Last Login: 9/18/2008
Status: offline
why sell discus?!
Hide Signatures
       Post #: 21
RE: CM Pro Discus CS - 10/7/2007 2:38 AM
Aientonni
Score: 100
Last Login: 5/17/2011
Status: offline
I was wondering if this glider is purely for the slope or can it be thermaled. And if so, would a hi-start launch be adequate. I'm interested because I don't have any hills in the area and this plane just looks so cool!!
_____________________________
Clint Jacobs
Hide Signatures
       Post #: 22
RE: CM Pro Discus CS - 10/8/2007 12:29 AM
daveosoar
Score: 100
Status: offline
After a couple of very iffy flights put the thing away until last week. With friends (6) rented a house in Devon for a week's sloping off the 400ft cliffs. Went to Start Point, a lovely site but with somewhat restricted landing area. Tested the air with an Xit - 10 knots and 400ft altitude ALG - so, after adding a little lead to bring the CoG 1/8in forward, plus 2-3 degrees of reflex on the ailerons off she went --- perfectly, stacks of altitude, stable and predictable in all senses. A transformation! BUT using Half Crow (airerons up) instigated a vertical dive! So no more of that. A 30 minutes flight and I brought her in to a perfect landing even within the limited landing area. After flying a few other models including ASW15, 110in Wing, Filip 600, GWS P38 (as PSS) etc. etc. had another go with the discus. Now seemed even better. This little model now lives in rhe car!!
Daveosoar
Hide Signatures
(in reply to Aientonni)
       Post #: 23
RE: CM Pro Discus CS - 10/25/2007 1:30 AM
Aientonni
Score: 100
Status: offline
Has anyone launched this sailplane off of a hi-start? Is it strong enough to handle it?
Clint Jacobs
Hide Signatures
       Post #: 24
RE: CM Pro Discus CS - 1/21/2008 12:20 AM
CarreraGTSCS
Score: 100
Last Login: 5/27/2013
Status: offline
Daveosoar-- If you don't mind my asking, what mods did you perform on your Discus? Mine's intended for aerotow and highstart launching and not for the slope. I'm wondering if I really need to strengthen the fuselage as has been discussed over on the RCG thread. I'll be landing on mowed grass and not a rocky slope site. I'll replace the carbon rod with a steel one if I can find 6mm here in the US.
Glad to hear that yours flies well as I'm eager to get mine in the air.
Mike
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.953RCU1
