blvdbuzzard
Joined: 6/16/2002 From: boulevard, CA, USA Status: offline
Need help with radio glitches. Mine is un-flyable do to the glitches. It is sitting there, on, throttle stick all the way down, and about every 20-30 seconds it will blip the throttle and spin the blades. When i do try and hover it, it will bounce around like a cat on a hot tin roof. Up, down, left, right, tail right, left. I have re-routed the antenna and motor leads. Not sure what to think. I have a second AXE on the same channel, 36 and I have swapped the RX's and TX's and it still does it. Both have the same glitch. That sort of rules out the RX and TX. It gets bad when it slams into the ground from 3 feet up and you have full throttle and it acts like it is in idle up and drives into the ground. This is driving me crazy. I know it is a short trip. But I want to fly and this radio glitch is killing my wallet and stability. Any ideas will be looked into. I am sending an email to Hobby Services to see what they say. Thanks. Dru.
