GTX SlotCar
ME, USA Status: offline
quote:
ORIGINAL: N7115T ...only operates at full throttle and then only intermittently, like on for 1/2 second, off for 2, on, off, on, off, etc.... These work on a pulse system. In other words, your motor speed isn't actually controlled by how much voltage it receives. Full volt pulses are sent to your motor in (probably) around 600 micro second pulses. The pulse is broken down into part full voltage, and part zero voltage. So, let's say that at 1/2 throttle the motor received 200 micro seconds of full voltage, and 400 micro seconds at zero volts. As your approach full throttle, these pulses get reversed. So you may have 400 microseconds full voltage and 200 at zero. This is called pulse width modulation, or PWM. Since your motor seems to be running in pulses that have gone haywire, I'd assume your 4in1 or 3in1 is faulty. This doesn't mean that there isn't some other problem or something you're doing wrong, but it doesn't look good.
_____________________________
Gary SuperSkids® www.super-skids.com
