crashcrash
MI, USA Status: offline
quote:
ORIGINAL: rayelljay Ray 'ere, I realise I may be regarded as somewhat of a traitor for this but...... The CPs are demanding a bit too much of my flight time and it's getting on my bloody nerves. I've been seriously considering purchasing another CP size machine with better mechanics and I've seen references to the Honey Bee King as being on a par or better than the Blade.....Oh! Heresy....burn the bugger at the stake......... I can read all the "paid for by the company" reviews I need but Gentlefolk like you have opinions I would hold with more value. Crash and Arrow, you know me as being a mite finnicky but the attraction to a belt or shaft drive to the tail cannot be resisted for long....I love the Rex and the 400 and I've seen these helis HBs for less than a new Pro. Can I use the Blade LiPos in the HB...?...The servos look similar....are they interchangeable.....if possible, I'd like to take advantage of the organ donor system. I've seen some good photos of the machine and it seems quite solid....what do you guys think. I've seen references to a shaft drive to the tail somewhere or am I off the wall here. For me, the Rex needs our local flying field, the 400 can be flown in my front yard but the CP sized machine is just about perfect for what I have at home. Any guidance you may offer would be very much appreciated...... Oh, anyone know if the ball links are the same diameter as the CP Pro. (No tools available for working with 'em) I think that's what killed the CNC swashplate balls causing my problems....I think the balls are aluminum and not stainless and my fingernails being too flexible had me make a wedge shaped tool from tool steel to separate the link from the ball and it probably gouged them....oh well, one lives and learns and goes on. Enough of this rambling...I'll leave you alone now....gonna rain this weekend so I'll have my On3 2-8-0 in surgery. Be safe..... Ray Ray...the HoneyBee King v2 is a good choice in the 300 class heli. Be advised, you must upgrade to a brushless motor and ESC. A good bet is the E-Sky 3800kv motor and 25a ESC as a starter. I've owned a total of 3 or 4 HBKII's, they're great. As far as using the S-75's or other stuff off the CP-Pro....I don't advise it (that's what makes it junk in the first place is the electronics). Here is a link: http://www.jaghobbies.com/rc_planes/17a_3900.htm He has pretty good prices. The servos for this heli are like $7.00 ea and take a whipping. I'm running them in my MX-400, they're fine. Personally, I'll be latching on to a T-Rex in a month or so, and I'll most likely stick to that for a long period. The HBKII is GOOD, parts are cheap, but it has a real problem with any wind above 3mph. The MX-400, I've had in the air in 20mph winds (wasn't fun...but do-able). The "Belt CP" is another viable option and it has wind tolerence but is more in the 400 class than the 300 class. Arrow had no luck with the HBKII, mine (all 3 of them) were great. All I can say is.....scope them out. Dollar for Dollar, the HBKII is hard to beat.
_____________________________
RTF is a mis-nomer...no plane or heli is RTF
