choppersrule
IN, USA Status: offline
Hi Guys, Choppersrules here, I've been to busy to help all of ya, sorry for that. PM me if you have a major problem . Anyway, heres' a link from HobbyZone.com that gives a lot of useful information on the Blade. I've posted it a zillion times and seems to help a lot of the guys. The thing I like most is the motor, pinion. battery combinations info. Link: http://www.hobbyzone.com/articles_efl_blade_bulletin.html Arrow: When you get the lipo's it will make a big difference in performance. And yes you'll more than likely have to adjust the Proportial and Gyro trim. It's in the manual and it's pretty well spelled out. It may take several attempts to get it right. Never happens on the first try. Turn on TX, don't plug in battery to RX yet. Turn the gyro gain all the way off, counter clockwise, turn Proportional about half way. Plug in battery. Spool up and notice which direction the nose is turning, left or right. Unplug battery, turn Proportional screw the opposite direction of the nose turning. Nose right, Proportinal left, just a tiny bit at a time. Follow the above until, you can get the heli light on the skids without turning left or right. A tad left or right is okay, but not alot. Always unplug battery when making proportinal adjustments. Once your satisfied with the proportinal setting, now time for the gyro. This can be adjusted with the battery always plugged in. Turn full clockwise and back it off about 1/4 turn. Test flight. Tail wagging, turn a tad to the left, counter- clockwise Hope this helps ya, Dave / Choppersrule
_____________________________
Left skid low....
