Where To Buy Ether For Diesel Fuel?
Tower Hobbies
Logged in as Guest
  Printable Version
XYZ-26cc Gas Engine
Seller:  XYZUSA
Details:   $219.00   |  4/26/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> Where To Buy Ether For Diesel Fuel?
Page: [1]
Login
Where To Buy Ether For Diesel Fuel? - 2/11/2002 11:42:43 PM
Volfy
Status: offline
As if I don't have enough projects going on at the same time already, I'm thinking about mixing my own diesel fuel. Kerosene is easy to get, but where can I buy ether? When asked the same, the guy at the Home Depot paint dept looked at me like I was an aspiring terrorist.
       Post #: 1
Where To Buy Ether For Diesel Fuel? - 2/12/2002 8:34:58 AM
Vince
Status: offline
I believe that ether is a controlled substance, may be hard to get.
Vince
(in reply to Volfy)
       Post #: 2
Where To Buy Ether For Diesel Fuel? - 2/12/2002 11:05:07 AM
Miniair
Status: offline
Starter Fluid for automobiles, not the starter fluid for BBQes.
You have to drain the can into a bottle - glass prefered and be very careful as it is extremely explosive.
_____________________________
Jim Rea
jr@miniair.com
(in reply to Volfy)
       Post #: 3
Why Ether - 2/12/2002 11:27:40 AM
NdFrSpeed
Status: offline
I dont think you will find Ether in diesel you buy at the pumps,Ether is used in starting diesel engines when there cold,not for running them.kerosene is just a fine grade of diesel.In a diesel engine to much ether starting them ive seen them blow up,and also lock up the motor.Ether in a Diesel motor is a big no no.
(in reply to Volfy)
       Post #: 4
Where To Buy Ether For Diesel Fuel? - 2/12/2002 6:10:05 PM
Elwood
Status: offline
At least in full-sized diesel engines, ether will fry a glow plug. Most big rig diesels do not use glow plugs, so ether is not a problem in moderation.
Born in the U.S.A.......Not quite as long ago as Art!!!!!!!
(in reply to Volfy)
       Post #: 5
Where To Buy Ether For Diesel Fuel? - 2/12/2002 6:10:46 PM
Ed Smith
Status: offline
Maybe times have changed or other fuel materials are now being used. We always used ether in Model Diesel Engine fuel. We then used to buy it at the pharmacy. If they will not sell it to you now they might give you a lead. Somewhere in the US is a supplier called "Dr. Diesel" he sells diesel engines and associated supplies. I do not have an address. He is always at the Toledo show.
Ed S
(in reply to Volfy)
       Post #: 6
Re: Why Ether - 2/12/2002 9:06:16 PM
Miniair
Status: offline
[QUOTE]Originally posted by NdFrSpeed
I dont think you will find Ether in diesel you buy at the pumps,Ether is used in starting diesel engines when there cold,not for running them.kerosene is just a fine grade of diesel.In a diesel engine to much ether starting them ive seen them blow up,and also lock up the motor.Ether in a Diesel motor is a big no no. [/QUOTE]
I'd love to see you get a model diesel engine started on pump diesel fuel . They won't; model diesel fuel has ether in it to help the ignition.
Jim Rea
jr@miniair.com
(in reply to Volfy)
       Post #: 7
Ether for fuel - 2/13/2002 1:09:50 AM
FrancisPerson
Status: offline
Go to your local John Deere Tractor store and buy a couple of cans of "John Deere 80% starting fluid". The name says it all. The cheeper stuff is much less ether.
Oily in Germantown
Francis Person
(in reply to Volfy)
       Post #: 8
Where To Buy Ether For Diesel Fuel? - 2/13/2002 11:30:55 PM
Volfy
Status: offline
Thanks for the replies. Yes, model diesel engines do typically require something that is more volatile and has a lower flash point to "kick start" the combustion, especially when cold. Ether does this quite well. Automotive sized and larger diesels often have glow plugs that do the same thing, so ether is neither required nor beneficial.
(in reply to Volfy)
       Post #: 9
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.532RCU1
