Why does my arm feel like i am trying to start a 350 V8 with a pul string???    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Redcat Racing Support >> Why does my arm feel like i am trying to start a 350 V8 with a pul string???
Page: [1] 2   next >   >>
Login
Why does my arm feel like i am trying to start a 350 V8... - 1/6/2007 1:52 AM
kyl3sv
Score: 100
Last Login: 2/7/2007
Status: offline
I think I have pulled my arm out of its socket for the last time trying to get me Volcano sv stared! I have tried everything to get it to run right except take it to a hobby shop and have a tech or someone who knows what they are doing help me out! I just dont get it i have built a 10.5 second 1/4 mile mustang but i cant get a nitro truck to idel!! Any way enough crying from me my question is where can i get a starter for the truck. I want something that will start the truck 100 times and burn out 100 glow plugs so i can tune the thing with out feeling like i just left golds gym!!! any Help
Hide Signatures
       Post #: 1
RE: Why does my arm feel like i am trying to start a 3... - 1/6/2007 2:22 AM
ehroof
Score: 105
Last Login: 5/16/2013
Status: offline
make sure the carburator has a 1mm opening, if not adjust it using the screw below the opening, its the one with the spring on it, the idle may be set to low. Your cluch spring may be broken, you can check by starting with the wheels off the ground. see if this helps, if not read the nitro troubleshooting thread
_____________________________
125 characters and 2 lines is not enough to list my RC obsession!!!
Hide Signatures
(in reply to kyl3sv)
       Post #: 2
RE: Why does my arm feel like i am trying to start a 35... - 1/6/2007 4:23 AM
Chubbysdad
Score: 100
Last Login: 12/22/2009
Status: offline
ALso, I know this sounds stupid, but make sure you are priming it.
Cen truggy, Bigfoot 1/5th, Cen buggy, Mg16, Redcat Earthquake, Redcat Drifter
Hide Signatures
       Post #: 3
RE: Why does my arm feel like i am trying to start a 3... - 1/6/2007 4:47 AM
dclintonh
Score: 100
Last Login: 7/5/2009
Status: offline
if the spring is not broken, and you get it to start. its not very good for it but run it fast in a big parking lot, 2or3 tanks.
and once its broken in, it will be alot better. these motors are so tight new they hardly run at all. i had to run mine pretty hard the 1st day to keep it from cutting off.
i had the hard to pull prob too. alittle 3in1 oil helps to.
hope it gets going 4 ya.
Hide Signatures
(in reply to Chubbysdad)
       Post #: 4
RE: Why does my arm feel like i am trying to start a 3... - 1/6/2007 7:04 AM
mozzzy_2000
Score: 100
Last Login: 4/24/2011
Status: offline
Not tyring to discourage you but thats a bad bit of advice!! No its not very good at all!! Do not run it fast for the first 2-3 tanks!! that will very much likely kill your engine off very very fast. Take it easy for the run in. It should never been run fast during breaking in.
Use the advice from the guys above and if you are unsure of the run in procedure, just ask.
Hide Signatures
(in reply to dclintonh)
       Post #: 5
RE: Why does my arm feel like i am trying to start a 3... - 1/6/2007 7:30 AM
nitrospeed33
Score: 100
Last Login: 2/19/2007
Status: offline
could it be that its flooded or is this a brand new car? also you could open up the back plate where the pulstart is. look and there and it could be something very simple.
Hide Signatures
(in reply to mozzzy_2000)
       Post #: 6
RE: Why does my arm feel like i am trying to start a 3... - 1/6/2007 7:37 AM
mozzzy_2000
Score: 100
Status: offline
just sounds ike a tuning issue to me. Base settings should be around 3 turns from closed on the HSN' and the LSN should be about flush with the throttle collar. That should be the ball park setting for getting the engine to start.
There are easier ways to start including a rotostart or starterbox. Saves you an arm and knuckles!!
Hide Signatures
(in reply to nitrospeed33)
       Post #: 7
RE: Why does my arm feel like i am trying to start a 3... - 1/6/2007 7:39 AM
giddyuperic
Score: 110
Last Login: 5/20/2013
Status: offline
They are all right. I take it it's a new motor. So get out the old hair dryer and warm the engine up and then it should be much easy to start and break in there is a breaking thead that's the best on here. So good luck and enjoy
F9, hunter hawker,F-22,yak55 30% DLE55,Extra260,300.sabre F86,bae hawk,Cessna 182. GoldWing extra300LM 30CC Velox20cc
Hide Signatures
       Post #: 8
RE: Why does my arm feel like i am trying to start a 3... - 1/6/2007 7:57 AM
dclintonh
Score: 100
Status: offline
im not saying to run the he!! out of it. im just saying run it hard enough to keep running.
its gotta stay runnig to ever loosen up. in my case it was so tight and sounded very metalic when i pulled the starter, i could tell it was cutting off cause of the fricton in the motor.
i never said to run wide open.
or even close to it.
sorry to miss lead someone on that.
Hide Signatures
(in reply to giddyuperic)
       Post #: 9
RE: Why does my arm feel like i am trying to start a 3... - 1/6/2007 9:36 AM
kyl3sv
Score: 100
Status: offline
no it ran sweet for the breakin period then i crashed it. hasnt been the same sence.
Hide Signatures
       Post #: 10
RE: Why does my arm feel like i am trying to start a 3... - 1/6/2007 10:27 AM
mozzzy_2000
Score: 100
Status: offline
still running?
Hide Signatures
       Post #: 11
RE: Why does my arm feel like i am trying to start a 3... - 1/8/2007 6:28 AM
kyl3sv
Score: 100
Status: offline
still havent herd if there is a starter for my truck? i really think if i dont need to pull it i can get the carb dialed in and can stop complaining to everyone! i dont know much about this stuff but i think i have herd about startters that replace the pull strat system is this true?
Hide Signatures
       Post #: 12
RE: Why does my arm feel like i am trying to start a 3... - 1/8/2007 6:29 AM
zack221
Score: 100
Last Login: 1/20/2013
Status: offline
yea its a roto start you use a drill to start the car
Hide Signatures
       Post #: 13
RE: Why does my arm feel like i am trying to start a 3... - 1/8/2007 6:30 AM
kyl3sv
Score: 100
Status: offline
where do i get it?
Hide Signatures
(in reply to zack221)
       Post #: 14
RE: Why does my arm feel like i am trying to start a 3... - 1/8/2007 6:38 AM
ehroof
Score: 105
Status: offline
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXFET0&P=M, this is a direct bolt on, i have it on one of my redcats, if you have the engine tuned correctly you wont need to pull like crazy, i would suggest getting this one because it has the starter wand, a cordless drill doesnt really have the rpm's to turn it over fast like the rotostart wand.
< Message edited by ehroof -- 1/8/2007 6:39 AM >
Hide Signatures
       Post #: 15
zack221
Score: 100
Status: offline
here is a link
http://cgi.ebay.com/TIGER-DRIVE-S686-7-32-STARTER-PROBE-SHAFT-HEX-WAND-NIB_W0QQitemZ280065114816QQihZ018QQcategoryZ44028QQcmdZViewItem
http://cgi.ebay.com/TIGER-DRIVE-S680-CEN-HPI-OFNA-FORCE-O-S-ORION-NIB_W0QQitemZ280061399111QQihZ018QQcategoryZ44028QQcmdZViewItem
Hide Signatures
       Post #: 16
RE: Why does my arm feel like i am trying to start a 3... - 1/8/2007 6:39 AM
zack221
Score: 100
Status: offline
either one of these that me and ehroof posted will work
Hide Signatures
       Post #: 17
RE: Why does my arm feel like i am trying to start a 3... - 1/8/2007 10:42 PM
kyl3sv
Score: 100
Status: offline
Its not that i have to pull hard to get it to run, or that it takes a long time its just that i am lazy nothing else just lazy!!
Hide Signatures
       Post #: 18
RE: Why does my arm feel like i am trying to start a 3... - 1/8/2007 10:44 PM
ehroof
Score: 105
Status: offline
LOL, at least your honest!!!!!
Hide Signatures
       Post #: 19
RE: Why does my arm feel like i am trying to start a 3... - 1/8/2007 10:50 PM
kyl3sv
Score: 100
Status: offline
so sence we are on the honest subject which one of the roto starters is more for a novice like my self to install?
Hide Signatures
(in reply to ehroof)
       Post #: 20
RE: Why does my arm feel like i am trying to start a 3... - 1/8/2007 10:53 PM
ehroof
Score: 105
Status: offline
i am more partial to the one i posted, it comes with everything including the wand for a few dollars more that the sullivan one. You will need a 7.2 battery and charger for it to work though. they are operate pretty much the same way and are very easy to install.
Hide Signatures
       Post #: 21
RE: Why does my arm feel like i am trying to start a 3... - 1/8/2007 10:56 PM
kyl3sv
Score: 100
Status: offline
sweet just ordered it thank you guys for all the imput! E you rock.
Hide Signatures
       Post #: 22
RE: Why does my arm feel like i am trying to start a 3... - 1/8/2007 11:40 PM
ehroof
Score: 105
Status: offline
Thanks bro, you should be happy with it.
Hide Signatures
       Post #: 23
RE: Why does my arm feel like i am trying to start a 3... - 1/10/2007 9:43 PM
MiniCwik
Score: 100
Last Login: 4/22/2010
Status: offline
Will this pull starter replace the stock one when it goes out? http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXGEG6&P=7
If not, can anyone please link me to one that will?
Trying to prepare a spare parts inventory of some of the common things I would need to replace.
Thanks!
Nitro Trk - Himoto Eldorada 1:10 4WD (w/bling)
EP Helis - T-Rex 500 CF (401/9257) & 450 SE V2 (Scorpion -8V2/401/9257)
Hide Signatures
       Post #: 24
RE: Why does my arm feel like i am trying to start a 3... - 1/11/2007 1:40 AM
ehroof
Score: 105
Status: offline
that will fit
Hide Signatures
(in reply to MiniCwik)
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.469RCU1
