ChaRX
GA, USA Status: offline
I got the upgraded CF v1 with the newer style slipper(with the V2 style spring setup), rear hubs, and whatever else was special about it... If I set the slipper at anything less than pretty tight, it would just slip completely at anything more than about 10% throttle, even on level ground. I had to play around with both diffs and the slipper to get it to go when I told it to, instead of just crawling along slipping...Is this just something I did wrong during assembly, or what? It wouldn't be so bad if Academy didn't want so much $$ for a new diff set...
