Steven H
Joined: 4/17/2002 From: Longview, WA, Status: offline
quote:
ORIGINAL: joeflyer CA. I had about 1/4" overlap, roughed up the shiny side with some fine sandpaper, then applied the CA. Make sure your seam is on the top. Mylar works well with a Byron fan. For a tractor fan I'd use something stiffer like a thin fiberglass sheet, similar to the polyply that BVM sells. Joe Well I just fire the engine for the first time after makeing a thrust tube out of mylar. It started to come unglued at the tail end after just a short run. I roughed up the mating faces just as was suggested. Should I have let it set up overnight? Is there another type of glue that would work better? thanks, Steve
_____________________________
You can't fix dumb
