airborne
OH, USA Status: offline
Hello all, Having used the types of lenses mentioned here - Sigma, Tamron and Canon - as well as the Nikon and Canon cameras - I'd like to weigh in on a few things. First, having used lots of equipment over the years, I have settled on Canon - currently using a Canon 20D, a 100-400mm f/4.5-5.6L IS for the long distance and aerial shots (Model Aviation product review and contest coverage), and a 70-200mm f/2.8L IS for the closer stuff (and indoor shooting without flash). To get back to the subject of this original thread, I believe that the lens choice depends on 2 things. First is your budget. Obviously, the Canon lenses are high dollar in comparison to the Sigma and Tamron, but there are reasons for that. This leads me into the 2nd thing which is: Can you tell the difference for the extra money? Definitely! The Sigma and Tamron lenses are fine for everyday vacation shooting or basically shooting things that don't move too much or don't require the utmost in sharpness. The Sigma lenses I have used were fairly sharp, but took a while to focus - sometimes having to focus to infinity and then come back to the proper subject focus. If you're trying to take a photo of a moving object, it's hit and miss at best. Tamron lenses are a bit faster to focus, but there seems to be more lenses out there which aren't as sharp as they should be. In both cases, neither focused anywhere near the speed of a Canon lens and also showed quite a lot of vignetting at the larger f-stops. The Canon lenses with the "L" series glass are a totally different breed, but you have to be able to appreciate the difference. Canon lenses focus extremely fast and extremely accurately. The also offer image stabilization which can give you an extra stop or two. The build quality is also much better since they don't rely on plastic for the casing. They are weather sealed and just plain awesome lenses. The problem in all this is that if you only go on price, you'll never know the true difference. You have to use a Canon lens to know why it costs so much. If you're lucky enough, find a camera store in your area that allows you rent the lens for the day. Hands on experience can answer a lot of questions that you won't be able to find off the internet. Also note, that I called out "L" glass Canon lenses. Canon also makes non-"L" glass lenses that are less expensive, but they are not as sharp, fast or built anywhere near as good as the "L" lenses. As for the bodies themselves, I have to agree with what has been posted. If you have a 20D (like I do), don't opt for the 30D. There's not enough to justify the difference. If you don't have anything, for the 30D. Yes, the Rebel XTi (400D) does have slightly better resolution, but the 30D has many more features and is not that much more in price for the performance. Of course, if money is not an option, you could always go for the EOS-1DS Mark II, (16.7 Megapixel) - at just under $7000! :-) Hope this helps.
