RE: Copperhead Aviation Venom 45-30    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: Copperhead Aviation Venom 45-30
Page: <<   < prev  43 44 [45] 46 47 48 49 50 51 52   next >   >>
Login
RE: Copperhead Aviation Venom 45-30 - 9/27/2007 1:24 AM
dubflyer
Score: 100
Last Login: 3/21/2011
Status: offline
quote:
ORIGINAL: mfuess
Dubflyer's engine is running great. The issue he had was the primer bulb leaking air. I recommend to anyone that still has the primer bulb connected to the carb... get rid if it. I solder the nipple closed, but any method will work.
I just received the engine yesterday and will fire it up againg this week-end on the test stand. I have ordered the B&B Muffler which fits this motor ..same as the Quadra 52 Type.
Mark called me while he was running my engine and it sounded Great............It should be ready for prime time as there is already about 4 gals of fuel through it by now. I am expecting a smooth idle and tons of power. I will continue to use 32:1 to complete the 5 gals of breakin mixture and then switch to Belray HR1 @ 40:1 mix.
Thanks Mark for figuring out the air leak.
I do not have an engine box on the Decathlon to mount the engine + pitts style muffler. I am afraid to build one on as I will have a hard time getting it to CG correctly. I have only to use 1" stand-offs to get the cowl and motor aligned.
I will report later when I fly the decathlon in 2 weeks time.
ciao,
Dubflyer
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to mfuess)
       Post #: 1101
RE: Copperhead Aviation Venom 45-30 - 9/27/2007 3:43 AM
mfuess
Score: 100
Last Login: 11/1/2010
Status: offline
The site is having some issues...
Hide Signatures
(in reply to JerKap)
       Post #: 1102
RE: Copperhead Aviation Venom 45-30 - 9/28/2007 12:14 AM
dubflyer
Score: 100
Status: offline
Hi Mark,
I opened my parcel with the venom 45 and found the engine mounting bracket bent where it oviously came in contact with something hard as the coating is also damaged on the edge.
The box looks OK however I need a new bracket as I do not want to risk bending the bracket as it will fracture and fail. I am unable to insert the bolt through the bracket due to it being distorted. see picture below.
How can I get a new brocket..??
Thank you,
Martin
Click for fullsize
Hide Signatures
       Post #: 1103
RE: Copperhead Aviation Venom 45-30 - 9/28/2007 1:37 AM
mfuess
Score: 100
Status: offline
quote:
ORIGINAL: dubflyer
Hi Mark,
Thank you,
Martin
Hi Martin!
NOT A PROBLEM!
I have your address here and I'll send a replacement mount tomorrow... I guess the Post Office turned the Gorillas loose on your package!
Please do not run the engine with the mount like it is. There's an extreme "possibility" that it will break from the engine running.
Hide Signatures
(in reply to dubflyer)
       Post #: 1104
RE: Copperhead Aviation Venom 45-30 - 9/28/2007 1:53 AM
mfuess
Score: 100
Status: offline
CORRECTION!
It's ALREADY on the way to you!!!!!!!!!!!!!!!!
Hide Signatures
       Post #: 1105
RE: Copperhead Aviation Venom 45-30 - 9/28/2007 5:25 AM
dubflyer
Score: 100
Status: offline
Thanks Mark,
Great service.....
Will be looking out for it ..............in the meantime I am waiting on the B&B quadra 52 side dump Muffler which has the correct bolt hole centers. Must be the same one you used ..?
Almost ready to fly.
Hide Signatures
       Post #: 1106
RE: Copperhead Aviation Venom 45-30 - 10/2/2007 6:48 AM
Mitsu1
Score: 105
Last Login: 4/23/2013
Status: offline
Man I like this engine . Don't know who taught Tim how to make an engine, but he learned well! Mine is a keeper! Took my plane out this afternoon and put 4 more flights on it, and with my V45 swinging a Xoar 21 X 8 @ 7000, I had unlimited vertical. I know the prop played a big part in that too, .. but I could take it from wide open horizontal .. pull vertical ... and the thing just kept the same constant tone while moving straight uphill with no hint of bleeding off! I could hover it, then pull out with authority! I didn't like wide open horizontal too long, because this is a new plane ... and the airframe wasn't proven yet (Had an Ultimate bipe explode on maiden once! . At the field today it was about 5 mph winds, 80 degrees, 69% humidity and elevation at sea level. My Katana is 14.4lbs.
< Message edited by Mitsu1 -- 10/4/2007 12:39 AM >
Hide Signatures
       Post #: 1107
RE: Copperhead Aviation Venom 45-30 - 10/3/2007 9:48 PM
3D_Junkie
Score: 100
Last Login: 1/10/2012
Status: offline
I'm thinking of getting a new plane. Mfuess, how well do you think the V45 will work in a OMP 92" Edge Hybrid?
Hide Signatures
(in reply to Mitsu1)
       Post #: 1108
RE: Copperhead Aviation Venom 45-30 - 10/4/2007 5:10 PM
mfuess
Score: 100
Status: offline
quote:
ORIGINAL: N7160F
I am not familiar with that aircraft other than photos. It's very very boxy looking... sort of a semi-profile airplane. It weighs 16+ pounds according to the site. To each his own, personally that's not my kind of aircraft. I'm sure it will fly nice.
Hide Signatures
(in reply to 3D_Junkie)
       Post #: 1109
RE: Copperhead Aviation Venom 45-30 - 10/6/2007 4:18 PM
w5kfg
Score: 100
Last Login: 2/28/2012
Status: offline
I would like to see your electrical setups killswitch set wiring
Bill
Hide Signatures
       Post #: 1110
RE: Copperhead Aviation Venom 45-30 - 10/6/2007 7:41 PM
w5kfg
Score: 100
Status: offline
Mark
I sent you aPM
Regards
Bill
Hide Signatures
(in reply to w5kfg)
       Post #: 1111
RE: Copperhead Aviation Venom 45-30 - 10/6/2007 11:07 PM
mfuess
Score: 100
Status: offline
Hey Bill,
I just sent you a reply...
Mark
Hide Signatures
(in reply to w5kfg)
       Post #: 1112
RE: Copperhead Aviation Venom 45-30 - 10/7/2007 1:12 AM
w5kfg
Score: 100
Status: offline
ok Mark
I got it
tnx for info
Bill
Hide Signatures
       Post #: 1113
RE: Copperhead Aviation Venom 45-30 - 10/8/2007 6:21 AM
maxime chamberland
Score: 100
Last Login: 10/14/2007
Status: offline
Hello
I want to know if someone have some info about the venom 30
I want to install it one of this plane Funtana x100
ultra giles 202 29%
I think it could be a great match!
Hide Signatures
(in reply to w5kfg)
       Post #: 1114
RE: Copperhead Aviation Venom 45-30 - 10/8/2007 9:06 PM
norbert001
Score: 100
Last Login: 3/26/2013
Status: offline
Hi Maxime
Can't comment on the Funtana i'm not to familiar with them.
The Ultra RC Giles will take a 45cc, seen one go at the British Freestyles with MVVS 45, and it performed superbly. So thats what my 45cc going into when i finally get round to putting it together.
Norbert
_____________________________
Gashanger UK
Hide Signatures
(in reply to maxime chamberland)
       Post #: 1115
RE: Copperhead Aviation Venom 45-30 - 10/8/2007 11:03 PM
CopperheadAV
Score: 100
Last Login: 5/13/2008
Status: offline
I agree, I think the 45cc would be a better match with some fire wall strengthening. I'm not sure about Funtana either.
Cheers,
Tim
Tim - Ohio Model Products / Copperhead Aviation
www.ohiomodelplanes.com
www.copperheadaviation.com
www.rcmanufacturing.com
Hide Signatures
(in reply to norbert001)
       Post #: 1116
RE: Copperhead Aviation Venom 45-30 - 10/8/2007 11:07 PM
CopperheadAV
Score: 100
Status: offline
Over the past year I’ve had a lot of guys ask me about engine standoffs. It took me a while to find good hardware I was satisfied with but I finally had the time to complete them. I only have these in red anodized and they will fit most engines.
Standoff Link
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to CopperheadAV)
       Post #: 1117
RE: Copperhead Aviation Venom 45-30 - 10/8/2007 11:24 PM
Flyer Freq
Score: 100
Last Login: 12/3/2012
Status: offline
quote:
ORIGINAL: maxime chamberland
Hello
ultra giles 202 29%
A guy in our club, who is real 3D wiz, has a Zenoah G20 in the Funtana X100. I am very impressed with the plane with a 20CC gas in it, so I am sure that one of Tim's 30CC engines would be a blast!
Andy
Lose not thy airspeed, lest the ground rise up and smite thee!
If you want to make God laugh, tell Him your plans
Hide Signatures
       Post #: 1118
RE: Copperhead Aviation Venom 45-30 - 10/9/2007 11:53 AM
maxime chamberland
Score: 100
Status: offline
Hello
I want to know if the venom 30 have more power of the evolution 26Gt2 without pipe? because at the airfield someone have a 73" Yak 54 ARF with a evolution 26 he can make hover but the airplane need a little more power!
Maxime Chamberland
Hide Signatures
(in reply to Flyer Freq)
       Post #: 1119
RE: Copperhead Aviation Venom 45-30 - 10/10/2007 2:44 PM
mfuess
Score: 100
Status: offline
Hello
I want to know if the venom 30 have more power than the evolution 26Gt2 without pipe? because at the airfield someone have a 73" Yak 54 ARF with a evolution 26 he can make hover but the airplane needs a little more power!
Maxime Chamberland
It does, however the Venom 30 is on hold the last I heard. You will have to check with Tim to see what the status of the V30 is. There are lots of choices available to you for that size aircraft.
Hide Signatures
       Post #: 1120
RE: Copperhead Aviation Venom 45-30 - 10/10/2007 3:03 PM
The Big Kahuna
Score: 100
Last Login: 12/30/2012
Status: offline
Hi Mark, my Venom45 cut out on me when I was landing. Normally I have to hit the ignition kill switch to stop it. Would this happen if the idle was set too low and therefore creating a lean mixture? Any suggestions?
Hide Signatures
       Post #: 1121
RE: Copperhead Aviation Venom 45-30 - 10/10/2007 4:04 PM
mfuess
Score: 100
Status: offline
It's most likely too low of an idle. When you say cut-out, as in four stroking, or stalling?
Hide Signatures
(in reply to The Big Kahuna)
       Post #: 1122
RE: Copperhead Aviation Venom 45-30 - 10/10/2007 4:56 PM
The Big Kahuna
Score: 100
Status: offline
Stop dead, fan no move - stall may be the better terminology. But why? It's never done it before.
Hide Signatures
       Post #: 1123
RE: Copperhead Aviation Venom 45-30 - 10/10/2007 7:30 PM
mfuess
Score: 100
Status: offline
Several things "could" cause this. Idle too low, engine too hot, lowend too lean, or any combination there of. Your internal screen may be dirty.<---- this is very common.
Hide Signatures
       Post #: 1124
RE: Copperhead Aviation Venom 45-30 - 10/14/2007 6:37 PM
Mike Miller
Score: 100
Last Login: 5/18/2013
Status: offline
Mark Fuess,
I sent you a Pm asking for some advice on propeller selection. If you think that the question/answer is pertinent to add to the forum, then make it so. If not, just tell me I am a pain in the keester and to stop asking these damn stupid questions.
Some day I am going to surprise you and make a trip down to your country to visit your flying field. But don't hold your breath, it is not in the new future.
Too much power is just right!
Hide Signatures
       Post #: 1125
All Forums >> Glow Engines, Gas Engines, Fuel &amp; Mfg Support Forums >> Gas Engines >> RE: Copperhead Aviation Venom 45-30
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.344RCU1
