Hinging EPP Foam
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> 3D Electric Flying! >> Hinging EPP Foam Page: [1]
Login
Hinging EPP Foam - 1/7/2007 5:15:33 PM
ZO6MAN
Status: offline
I have built two EPP foam Extra 300's. I cut the ailerons, rudder, elevator hinged edge at an angle to facilitate the flexing of the control surfaces. I'm not sure what I should use to hinge the surfaces. CA hinges seem to be to short & also seem to be binding. I would appreciate any ideas. Pics are attached. Thanks Todd
Click to see fullsize image.
Click for fullsize
Click for fullsize
       Post #: 1
RE: Hinging EPP Foam - 1/7/2007 5:36:41 PM
rmenke
Status: offline
ZO6MAN:
Use the Dubro small hinges with the metal pins and install with epoxie. They take a little more time than the CA hinges, but work freely and do not put resistance on the surfaces to slow or work your servos hard like the CA hinges do. ENJOY
(in reply to ZO6MAN)
       Post #: 2
RE: Hinging EPP Foam - 1/9/2007 1:11:57 AM
flyingace451
Status: offline
My all time favorite hinges are rectangles cut from old floppy disk material. Works like a charm, just put a drop of CA on each side, slide it into a slot, and spray kicker in from both sides. The kicker doesn't screw up the material at all, and they just rock on small foamies.
Anything bigger than a small foamy (40+ inch wingspan) deserves pin hinges as mentioned above, however.
_____________________________
As I lay in bed at night I look up at the stars and think to myself, "Where the heck is the ceiling!?"
(in reply to rmenke)
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.281RCU1
