jaofos
OK, I got the ends confused then. I thought the positive end was the one with the blue dot and the rivet I'm talking about. The smaller cap on the negative end is the only thing that turns when you twist it, and it looks like it's twisting on whatever holds that small cap to the end, which inside the cell holds the braid material, which should stay in place. I wouldn't think that turning the small cap would break the seal as it's inside the rivet, nor damage the braid inside. But hey, if A123 says not to.. there's gotta be a reason.
