Why discharge a LiPo?    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Why discharge a LiPo? Page: [1]
Login
Why discharge a LiPo? - 1/8/2007 10:20 PM
zulugogogo
Score: 100
Last Login: 4/26/2013
Status: offline
Why discharge a LiPo, I can undrstand why for NiCd but not LiPo.
Hide Signatures
       Post #: 1
RE: Why discharge a LiPo? - 1/8/2007 11:17 PM
guver
Score: 174
Last Login: 5/21/2013
Status: offline
Only for using or testing or long term storage perhaps.
_____________________________
and airplanes were in
Hide Signatures
(in reply to zulugogogo)
       Post #: 2
RE: Why discharge a LiPo? - 1/8/2007 11:46 PM
zulugogogo
Score: 100
Status: offline
ok thanks, as it is on the charger but i could not think of a decent reason to use it.
Hide Signatures
       Post #: 3
RE: Why discharge a LiPo? - 1/13/2007 8:59 AM
Tram
Score: 105
Last Login: 5/16/2011
Status: offline
And.. if you plan to store it, don't discharge it down past say 3.8 a cell.
Hide Signatures
       Post #: 4
RE: Why discharge a LiPo? - 1/14/2007 9:18 PM
jstrattwilson
Score: 100
Last Login: 8/11/2008
Status: offline
It is just there so that you can check the capacity of the battery. i.e. discharge, and then charge to see how many MAH's it will hold.
Don't discharge to store. You should store LIPO's at 80% of its capacity.
Hide Signatures
       Post #: 5
RE: Why discharge a LiPo? - 1/16/2007 3:24 AM
GeraldRosebery
Score: 100
Last Login: 4/13/2012
Status: offline
BTW - LiPo's are shipped from the factory with a 30% - 50% charge in them. The reason is stability. DO NOT discharge LiPo's to store them. Store them with about a 1/2 charge. You can do that with - YOUR DISCHARGER!
Gerry Rosebery
Niagara-on-the-Lake, Ontario
Hide Signatures
       Post #: 6
RE: Why discharge a LiPo? - 3/4/2007 7:37 AM
Tram
Score: 105
Status: offline
YOu could also just discharge them with a flight.
Hide Signatures
(in reply to GeraldRosebery)
       Post #: 7
RE: Why discharge a LiPo? - 3/4/2007 7:05 PM
Time Pilot
Score: 100
Last Login: 10/26/2009
Status: offline
deleted...
Hide Signatures
(in reply to Tram)
       Post #: 8
RE: Why discharge a LiPo? - 5/8/2007 4:31 AM
y7deluxe
Score: 100
Last Login: 1/30/2010
Status: offline
one person recommend to discharge them to 80% the other recommended to discharge to 50%, which is correct? Also, I have read that you are supposed to discharge if you aren't using them for longer than a week, is this true because somebody in this thread said you shouldn't discharge unless you are not using them for long-term. My definition of long-term is anything longer than a year , what is his? Thanks.
EDIT: Also, how fast should you discharge the battery? My charger allows me to pick anywhere between .1 and 2.0 amps. I have a 6000mah 2s2p 7.4volt battery pack. Thanks.
< Message edited by y7deluxe -- 5/8/2007 4:33 AM >
Hide Signatures
(in reply to Time Pilot)
       Post #: 9
RE: Why discharge a LiPo? - 5/8/2007 6:25 AM
Tram
Score: 105
Status: offline
You should store them at a voltage of about 3.8v per cell..
You should charge them at 1C..
A 6000mah pack at 1C would be 6 amps..
A 2100mah pack at 1C would be 2.1 amps..
A 3850mah pack at 1C would be 3.8 amps...
You always charge at 1C.. With your charger on a 6000mah pack, looks like you'll charge it at 2 amps..
Jeff
Hide Signatures
(in reply to y7deluxe)
       Post #: 10
RE: Why discharge a LiPo? - 5/8/2007 6:56 AM
y7deluxe
Score: 100
Status: offline
My charger charges at 10amps. It only discharges at 2amps. So I was just curious, is it safe or recommend to discharge at 2amps or should I discharge at a lower amperage?
Hide Signatures
(in reply to Tram)
       Post #: 11
RE: Why discharge a LiPo? - 5/8/2007 8:18 AM
guver
Score: 174
Status: offline
You can discharge at a far higher rate than charge so the max 2 amps is fine. Your 6000 can probably take at least 30 amps.
Hide Signatures
       Post #: 12
RE: Why discharge a LiPo? - 5/8/2007 9:20 PM
Tram
Score: 105
Status: offline
Man, I should really read the question better..
I thought you were asking how fast to CHARGE a battery..
guver is correct, you can charge far faster than you can charge..
Just curious - Why do you want to discharge them? For long term storage?
Hide Signatures
(in reply to guver)
       Post #: 13
RE: Why discharge a LiPo? - 5/9/2007 10:22 AM
mrasmm
Score: 105
Last Login: 3/10/2011
Status: offline
I think "long term" storage when it comes to lipos is something like 3 months or longer =)
I say stay with the 3.8v per cell and 2a discharge rate that has already been recommended, just watch your charger and make sure that it doesn't get too hot while discharging (27watts power dissapation at 7.4v and 2A)
I don't always check every thread I respond to, so feel free to PM me
Hide Signatures
(in reply to Tram)
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.719RCU1
