antiquefer
Joined: 12/6/2006 From: Southworth, WA, USA Status: offline
If you are not proficiant with rudder, leave it home, till you are. Takeoff is fairly easy, point it into the wind and firewall it. Should be off in about 6 feet. The landing is probably the hardest part. Flying from grass is the best. Mine doesnt seem to tip stall at slow speed so I can land with very little rollout. The longer it rolls the more likely it will ground loop, drag a wing tip, and noseover. INSTALL WING SKIDS!
