RE: NITRO FOKKER DR1
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> ARF or RTF >> NitroModels Support >> RE: NITRO FOKKER DR1
Page: <<   < prev  1 2 3 4 5 6 7 8 [9] 10   next >   >>
Login
RE: NITRO FOKKER DR1 - 7/14/2008 5:24:08 PM
highflyer66
Status: offline
This is my finshed..FOKKER DR-I..Badbrad for the LOLA! Blue sky's..No wind up up and way!! It is a hand full to fly.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by highflyer66 -- 7/14/2008 5:27:39 PM >
(in reply to john cirri)
       Post #: 201
RE: NITRO FOKKER DR1 - 7/14/2008 11:08:09 PM
john cirri
Status: offline
No hole's, You gotta make um', Mount it any way you want, Vertical is best with a Box type Muff pointing down, I use a Dubro remote Ignition plug I mounted in the cockpit, The only hole you make in the cowl is the needle valve Very clean.
(in reply to jab2of3)
       Post #: 202
RE: NITRO FOKKER DR1 - 7/15/2008 2:59:25 AM
antiquefer
Status: offline
I mounted mine (Saito 91) in about the 8 oclock position to line up with the dummy engine. This putes the needle valve out the bottom of the cowel I like to put a 1/8" hole to access the low end adjustment. I then make up a guide tube (outer nyrod tube) glued in place on the firewall which keeps the screwdriver perfectly aligned. I use a remote glow driver also, which you can put anywhere you want. I aligned the crankshaft with the center of the hole in firewall and it came out dead center of the cowel.
       Post #: 203
RE: NITRO FOKKER DR1 - 7/15/2008 4:45:20 AM
carlosmalone
Status: offline
HighFlyer,
Thanks for sharing the really nice photos. If you don't mind my asking, where did you get the LoLa! graphics?...very cool. Could you elaborate on your first flights? Any advice? I hope to maiden mine in this weekend.
Carl
(in reply to antiquefer)
       Post #: 204
RE: NITRO FOKKER DR1 - 7/15/2008 4:47:16 AM
john cirri
Status: offline
I cut the LOLA from a white monokote trim sheet.
(in reply to carlosmalone)
       Post #: 205
RE: NITRO FOKKER DR1 - 7/15/2008 4:03:36 PM
carlosmalone
Status: offline
Thanks John. Did you draw a template first or just freehand it? I suppose they were painted freehand on the real thing.
Carl
       Post #: 206
RE: NITRO FOKKER DR1 - 7/15/2008 4:10:00 PM
john cirri
Status: offline
I have a copy of "The Great Waldo Pepper" movie and paused it, Yes freehand.
       Post #: 207
RE: NITRO FOKKER DR1 - 7/15/2008 4:27:03 PM
carlosmalone
Status: offline
John,
Ok, sounds easy enough. Time to give it a go.
This is a great youtube clip from Waldo... http://www.youtube.com/watch?v=xzKQpxBoo58&feature=related
I'm ready to see this thing in the air. :_)
Carl
       Post #: 208
RE: NITRO FOKKER DR1 - 7/15/2008 4:35:52 PM
john cirri
Status: offline
Great, It only takes 15min to cut out, Just trace the 2nd from the first, It was too windy last Saturday here for the Maiden Flight, I'm V.P and grass cutter of our club, I'll take it with me Friday when i cut, The weather looks good, I'll have Pic's.
       Post #: 209
RE: NITRO FOKKER DR1 - 7/15/2008 10:09:31 PM
antiquefer
Status: offline
Carl. If you fixed the wing incedence problem ,and have the CG in the correct spot (measured on top wing) the first flights will be a piece of cake. Point it into the wend, and roll on the power. It will be airborn in just a few feet. Once you get used to it you will be able to make more scalelike takeoffs. The landing is the hardest part. Get it as slow as you dare to shorten rollout. Practice this up high to feel out its behaveyor. Much rollout at all will produce a groundloop, and probably a noseover. It is much easier from grass. I think highflyer got the lola from Badbrad graphics....................................antiquefer.
       Post #: 210
RE: NITRO FOKKER DR1 - 7/15/2008 10:26:15 PM
FOKKERFREAK
Status: offline
hey antiquefer,
i'm building mine now and have got into the wing incidence problem. do you think it would be worthwhile to buy a wing incidence meter to set it up, or can you eyeball it and get it close? never had to deal with incidence before, but want to learn. any help is appreciated. i have all wings on, nothing glued and it looks straight on the bottom and mid wing.
       Post #: 211
RE: NITRO FOKKER DR1 - 7/16/2008 12:35:03 AM
highflyer66
Status: offline
Carlosmalone
go to Badbradgraphics@aol.com I think he will have them on file. Both for $7. And they are vinal very nice. (LOLA) or (LOLA!) I flew my today..Working on that flat turn..Flying not so bad..Landing. It's a hand full.
Don't for get to say the pilots pray::: O Lord please don't let me F this up......Happy fly in
< Message edited by highflyer66 -- 7/16/2008 12:36:26 AM >
(in reply to FOKKERFREAK)
       Post #: 212
RE: NITRO FOKKER DR1 - 7/17/2008 5:50:25 AM
antiquefer
Status: offline
FOKKERFREAK. You can do it without an incadence meter. Tape a stick to the bottom of the bottom wing with a few inches sticking out past the leading and trailing edges. Level the plane so that both ends of the stick measure the same distance to the work surface. With another stick on the bottom of the top wing, adjust the wing till the ends of the stick measure the same from the work surface. This will make the wings the same at least. The NM DR1 has a flat bottom airfoil so this method will work. If you still need to you can redrill the holes in the bottom end of the front cabane struts to allow them to mount lower which will bring the leading edge down some more. If you do decide to get an incadence meter the Hanger Nine digital meter is the one you want. I have learned the hard way that some of the less expensive arfs dont always have things inline..................................antiquefer.
(in reply to highflyer66)
       Post #: 213
RE: NITRO FOKKER DR1 - 7/17/2008 5:54:14 AM
antiquefer
Status: offline
Highflyer66!!! Yomama!!!.........................antiquef.
       Post #: 214
RE: NITRO FOKKER DR1 - 7/17/2008 12:54:19 PM
FOKKERFREAK
Status: offline
sounds great. i'll give it a try. thanks for the info.
       Post #: 215
RE: NITRO FOKKER DR1 - 7/19/2008 4:24:15 AM
highflyer66
Status: offline
Be one with the sky. You no fyling hack!! (antiquer)!! To be real he is one of the best pilot and builder I know. But I don't know that much? Carlosmalone..Did you give brad a call? It been a little to windy here lately for the DR-I. I don't mind just a little wind. But when that wind sock is staight out. No thank you.
< Message edited by highflyer66 -- 7/19/2008 4:44:38 AM >
