kaosfan
CA, USA Status: offline
quote:
ORIGINAL: skorman I've had my RV-4 for about 6 months and I've enjoyed it very much. I am disappointed with the OS 91 Surpass II as its power plant. On this plane, it is just not enough power for me. I am thinking of putting in a 1.20 to 1.50 4 stroke engine in its place. Has anyone put a larger than recommended engine in this plane? Other than cutting up the cowl, are there any considerations I should be taking into account? Thanks in advance for anyones input. Fuel tank size may be an issue, at least when the engine is new. I can't believe how much fuel my first four stroker (just recently even-after 27 years of modeling) went through when it was new. My buddy had the same problem with a new Saito 1.80 in a Great Planes Giant Big Stik. He had to put a larger tank into it. Until we felt comfortable with leaning them the flight times were about 5 minutes. Maybe I am a wuss, but I would rather run a new one kind of rich at first. I also am going to add some triangle stock around the firewall box area too. I have not finished mine yet. I am going with the .91 Surpass. What kind of flight times are you getting from the stock tank? As far as the .75AX, I think it would work. Heck, Great Planes says this model will fly on the .61FX. I initially started to put mine in this model just to see if it would work. But then I decided I wanted the 4 stroke sound. Then again, I have a YS 1.20 also. Whooee!
